LG 32lc46 totaly dead
  • sabre504
    • May 2010
    • 449
    #101
    Re: LG 32lc46 totaly dead
    Sm
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #102
      cheers mate for that
      • sabre504
        • May 2010
        • 449
        #103
        Pt 2
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #104
          could someone look at the pdf page 27 standby circuit 1c903
          these are the voltages i am getting
          pin 1 3.29
          pin 2 3.29
          pin 3 gnd
          pin 4 1.17
          pin 5 0.78
          its a sc156515m-1 8tr
          have checked c912 +have 3.12 volts
          right ic902
          with tab at the top
          pin 1 left 0.00
          centre 0.11
          pin 3 4.66
          az1117h-2.5tr/e1
          just worked out pin 1 is gnd
          pin 2 is output
          pin 3 is input
          still got no ledS on the front of set at all ?
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #105
            any idea what ic902 does just looked at pdf looks like output should be 2.5 volts?
            so it looks like i have
            4.66 input
            0.11 output
            output goes to +2.5v ddr-ctz whats that?
            also where does the voltage to light the leds come from?
            • sabre504
              • May 2010
              • 449
              #106
              p 27
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #107
                right whilst i am trying to locate the correct main board i thought i would sort out the old power supply as in post 53 which budm was helping me test voltages etc right accros the capacitor as in your pdf test ponts its 13.8 volts and between the other two test points its 2.4v
                i have checked and the board still has the 2x5volts present nothing else on any of the out put voltages even with a 1k resistor as a load.
                also i cant locate the correct main board with the same ebr number on but i have found a lg42lc46 mines a lg32lc46 would you guys take a gamble on it working ok?
                as its out of a 10inch larger lcd would the picture still be ok? could i alter it in the sets on board service mode?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #108
                  regarding my posts 104/105/106 has anyone got any ideas what to check now cant locate the correct mainboard at all at the minute
                    Mainboard should be okay if model & panel is the same. Is your LCD panel an LG Philips?
                    Is there an ACD pin?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #110
                      now your asking will take back of the set again and look for you
                      yes ac-det pin on main psu/mainboard connectors
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #111
                        tom66 not sure what the lcd panel is does not seem to say but have tested the ac-det pin 5.10 volts.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #112
                          right new mainboard has just arrived put it into set now i have the red standby light come on i press the remote changes to green after flashing 6 times nothing on the screen whatsoever no sound only a slight speaker pop as it comes out of standby any ideas guys all voltages on board are spot on as per board markings screen does not even flash any idea what 6 green led flashes mean?
                          this board is out of the exact model even same ebr numbers.
                            My TV flashes LED five times when it switches on, I think that just means "warming up" or something, so try checking all your connectors are good e.g. backlight cables, T-con, power.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #114
                              will go and try and leave it on green standby for a bit see if it comes on with time will remove all connectors and re seat them
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #115
                                still nothing just rechecked voltages one says 3.4-on on the psu reads 0 volts in standby 2.00 volts when green light stops flashing this is the only voltage on the psu reading low
                                  This probably your problem check soldering for cap 2200u 10V(?)
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #117
                                    remember tom66 this is not my own psu this is one i purchased so this one i am using now still got old samyoung caps in although none look bulging i will get my old unrepairable psu and swop to the panasonic ones which i put in it.
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #118
                                      I have been looking at the main board - there are two switches and a large jumper
                                      - any idea what these do - does it say on the case back or inside the case back.
                                      Could not spot anything in the SM
                                      • Jasgriff
                                        • Feb 2012
                                        • 578
                                        Hi Vince,
                                        I wouldnt go swapping your parts over just yet until you have properly found out what it supplying to your mainboard. If you have bought it as working then the last thing you want to do is end up with 2 power supply's in bits
                                        Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
                                        How to resize your pictures guide click HERE
                                        Retiredcaps Ideal post example click HERE
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #120
                                          cant see a jumper? the 2 switches no sure but bottom 1 when pressed justs seems to reset the set (starts red flashes green 5 times then nothing on screen) my old psu was no good ie only 2x5 volts present none others just swopped all caps over now just going to try it.
                                          • Acnologia
                                            Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                                            by Acnologia
                                            Here is a pretty crazy one.
                                            Step 1.
                                            Laptop was brought to me as dead not working. Removed everything , cleared everything.
                                            Step 2.
                                            Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                                            Step 3.
                                            Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                                            Step 4.
                                            Lets ,dive into the board. I see the edp cable on the...
                                            05-07-2025, 07:16 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • hoarderteks_kyriakos
                                            Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
                                            by hoarderteks_kyriakos
                                            Hello.
                                            Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
                                            Here is what happened:
                                            At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
                                            10-08-2025, 07:33 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • eastcoastcomputing
                                            Lenovo Legion7 16ACHg6 no post
                                            by eastcoastcomputing
                                            Hi there, I need help with the diagnostic on this board (NM-D563 Rev2.0).
                                            I could not find schematics nor boardview for it.
                                            The laptop was working, playing game when it suddenly crashed. Thermal paste is good and fans are clean. Since then, when power gets plugged in the laptop tries to come on (led lights light up, on off button lights up CPU and GPU warm up) for a minute or so before shutting down. No Display, no beeps no flashing led
                                            There's no liquid damage. I've checked the board under the microscope and can't find any damaged components. I've checked...
                                            06-24-2025, 04:26 AM
