LG 32lc46 totaly dead
Re: LG 32lc46 totaly dead
hi just managed to borrow a neighbours camera took 4 pics before recharable battery went flat (sods law) anyway these are the best i could get so if at all possible could you point out which the controller ic is you think thats faulty giving me no voltages etc. then i will try to get part number of the ic for you to help me locate one if possible. cheers guys
edit!! just spoke to my local scrap metal man who comes around he says he has a few lcd tvs hes been keeping with smashed screens etc so going around to see him to see if theres a lg lcd there or anything with the same power board numbers etc will update soon.Last edited by vinceroger69; 03-15-2012, 05:28 AM.Comment
Hi Vince,
Its difficult to see anything with those pic's unfortunately.
Hopefully you have borrowed the charger so that you can have another go. We need both sides of the full board. It looks like you didnt have your camera set to macro which you need to do for the close up shots. Macro is the little flower symbol on your camera.Comment
will do doubt if that camera will have that setting lol it was a praktica digipix 524 i think just a cheap job. but willl look just in case.Comment
What Panasonic caps did you use?
Also, what is the part # on U200 and U201... the two devices near each other, on the primary side.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
in pic 8 you mean u100 and u101 well u 101 cant read at all (part number is on it just worn to bad to read even under magnifier) u100 looks like 0001-h26
all caps were panasonic 105c rated. cant seem to find a power supply circuit diagram/parts list? it says on the board . REV 1.2
07.5.7
EAX31845201/13Comment
u100
001
H26
u101
MIC
44287YM
06492
these are the 2 on the primary side would these if faulty stop the rail voltages i have missing just retested board still only have the 2x 5volts presentLast edited by vinceroger69; 03-16-2012, 06:11 AM.Comment
07.5.7
EAX31845201/13
I get no hit for the MIC44287; it's quite possible it's a custom LG IC (this has been seen before on Samsung TVs.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
looks like fc to me
so any idea about the chip do you think its the problem? anyidea where to locate one from.
also before the M IN MIC there could be another leter or number just cant read it yet will try again now.
EDIT!! just re check looks like a funny then so its mMIC
4428YM
06492
http://search.digikey.com/uk/en/prod...6-5-ND/1029922
is this it do you thinkLast edited by vinceroger69; 03-16-2012, 07:47 AM.Comment
does this look the right one to you guys cant seem to find any cheaper due to companys high postage costs when only needing 1
http://www.ebay.co.uk/itm/MICREL-SEM...25064840687652Comment
sorry tom66 just read your post right
U200 is a
U3037M
705523
next to it is Q205 is a
62T03GH
725504
U600 is a
5501A
1D07725
u101 is a
MIC
4428YM
06492Last edited by vinceroger69; 03-16-2012, 12:28 PM.Comment
Any readable number on U100?
U101 drives the MOSFET device; U100 probably controls this driver IC.
However, even if you can't read the number... there's a capacitor C123 which is probably the start up capacitor. If this is bad then the controller will not start up.
Do you think you can test the voltage across this capacitor?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
yes got a better magnifer u100 is a 0001 h26
c123 0 volts across it
c123 is a 50v 1ufLast edited by vinceroger69; 03-16-2012, 02:11 PM.Comment
C123 is your problem - assuming that was taken with power applied?Last edited by tom66; 03-16-2012, 02:24 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
power applied board turned over black lead cap- red lead cap+ power turned on 0 volts dmm set to dc volts
EDIT!!!! just changed that cap again still no voltage across it?Last edited by vinceroger69; 03-16-2012, 02:52 PM.Comment
Check the DC resistance between the cap positive and negative, with the TV off.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by AcnologiaHere is a pretty crazy one.
Step 1.
Laptop was brought to me as dead not working. Removed everything , cleared everything.
Step 2.
Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
Step 3.
Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
Step 4.
Lets ,dive into the board. I see the edp cable on the... -
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... -
Hello.
Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
Here is what happened:
At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...10-08-2025, 07:33 AM -
by disorderhello guys,
i need help to repair a edm-033 ps2
history : as always hdmi port and usb ports destroyed after unplugged
after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
so i changed it
now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
i don't see any projection of liquid metal on pcb.
Hi there, I need help with the diagnostic on this board (NM-D563 Rev2.0).
I could not find schematics nor boardview for it.
The laptop was working, playing game when it suddenly crashed. Thermal paste is good and fans are clean. Since then, when power gets plugged in the laptop tries to come on (led lights light up, on off button lights up CPU and GPU warm up) for a minute or so before shutting down. No Display, no beeps no flashing led
There's no liquid damage. I've checked the board under the microscope and can't find any damaged components. I've checked...06-24-2025, 04:26 AM - Loading...
