LG 32lc46 totaly dead
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #81
    Re: LG 32lc46 totaly dead
    Originally posted by budm
    The 1k resistor from 5Vstby to PS_ON test is to verify if the power supply is OK, which from your reports, the power supply is OK. Now you need to find out whay you are not getting the 3.3~5VDC from the main board to feed the PS_ON pin on the power supply.
    Time to check the voltage regulators in the main board next.
    just posted some pics up not very good though will get better tomorow dont know if you can see voltage regs to point out to me?
    this is the exact board
    http://www.sendz.co.uk/lg-42lf65-zc-...n-av-405-p.asp
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #82
      another question even with this new power supply in connected up i am still not getting any leds lit when tv is plugged in is this normal? or is this because i am not getting the 3.3~5VDC from the main board to feed the PS_ON pin on the power supply
      • Jasgriff
        • Feb 2012
        • 578
        The LED's on the tv will be power from the mainboard. So you should have voltage going to the mainboard which should power up the LED and send an on signal back to the power supply to turn it on.
        Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
        How to resize your pictures guide click HERE
        Retiredcaps Ideal post example click HERE
          That is not normal, since the standby power supply is always on to run the micro controller, the 12v/24v power supplies are switched on when power switch is activated.
          So when you hit the power switch, nothing happens?
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #85
            no nothing both the 5 volts on the psu have 5 volts checked them twice now also on the very bottom of the main board it has 1 connector i have just tested the point on the board thats stamped 5 volts its there when the sets plugged in following this wire back it goes to the led borard on the bottom of the set and then by wires up to the power momentery switch board.
            just looked at the connection on the bottom of the main board they say
            led r
            led g
            stby 5v this i have when sets plugged in
            gnd
            ir
            gnd
            key2
            key1
            so not sure whats going on here
            • Jasgriff
              • Feb 2012
              • 578
              Have you tried pointing your remote at it and pressing some buttons to see if the light flashes?
              • Jasgriff
                • Feb 2012
                • 578
                The best way of seeing whats going on with your mainboard is to check the voltage regulators like Budm asked. The picture is not clear enough for us to really tell you where they are so if you take a look at the picture below. I think yours will look like this. Can you find them and let us know the numbers off them please.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #88
                  on the front of the board 2 x sc156515m 2x kia78r05f all 5 pins on each all of these are by the top sockets by where the psu to main board plugs go
                  2x kia 78r3ff by the tuner both 5 legs
                  and have tried pressing remote no light from led att all will try to get pics tomorrow miday for you will try to take four of each side
                  • Jasgriff
                    • Feb 2012
                    • 578
                    Ok these Voltage regulators supply the board with the different voltages that each different component needs. What we need to do is ensure that they all have power and they they are outputting the correct voltages for the circuits to work correctly.
                    Below is the spec sheet for the first number you provided. What we need you to do is to tell us what voltage you are getting on each of the pins. You can use the metal tab at the top of the regulator to put your black probe and then test each of the pins with your red probe.
                    sc156515m
                    http://pdf1.alldatasheet.com/datashe...CH/SC1565.html
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #90
                      will do this tomorrow after i have taken pics and put board back in for testing cheers guys
                      • Jasgriff
                        • Feb 2012
                        • 578
                        Ok do the same with the other regulators and then post your findings on here that might help work out what's going on.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #92
                          some pics will check voltages in a min
                          well some voltage tests done still no red or green led on the front tried remote as well no flashes nothing
                          all these regs have five pins i tested left to right
                          ic 505 by the tuner KIA 78R33F
                          pin 1 o volts
                          pin 2 1.08 volts
                          pin 3 o volts
                          pin 4 o volts
                          pin 5 o volts
                          1c903 SC158515M
                          pin 1 3.29 volts
                          pin 2 3.29 volts
                          pin 3 0 volts
                          pin 4 1.18 volts
                          pin 5 0.79 volts
                          1c 902 AEH14A 731J28
                          3 pin device
                          pin 1 0 volts
                          pin 2 o volts
                          pin 3 4.69 volts
                          all the other regs on the board 0 volts to all pns
                          • Jasgriff
                            • Feb 2012
                            • 578
                            Ok here is the Spec sheet for the KIA78R33F
                            http://www.alldatasheet.com/view.jsp?Searchword=78R33F
                            SC158515M I cant find this part number? is this correct was this writing all on one line?
                            AEH14A 731J28 cant seem to find this one either?
                            Can you retest the KIA78R33F using pin 5 as ground and tell us what you get.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #94
                              just retested KIA78R33F
                              pin 1 0 volts pin 2 0.86volts pin 3 0 volts pin 4 0 volts
                              sorry 1c 903 should be sc156515m
                              the one you sent the data sheet for already
                              1c902 is a EH14A 731J28
                              pin 1 0 volts
                              pin 2 0 volts
                              pin 3 4.69 volts
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #95
                                just saw this on ebay it says it for a 42 inch plasma although all the board part numbers match up 100% would this work as mines a 32 inch lcd?
                                http://www.ebay.co.uk/itm/2510195867...84.m1438.l2649
                                • sabre504
                                  • May 2010
                                  • 449
                                  #96
                                  I know that the samsungs can be changed in the service menu to tell the board what screen size to run but am not sure if the same can be done with this model .
                                  I am sure one of the more experienced posters will be able to tell you but have found a service manual which i have attached
                                  • sabre504
                                    • May 2010
                                    • 449
                                    #97
                                    Cant get it to upload will mail it to you
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #98
                                      cheers much appreciated
                                        The only problem you might have is the 32" LCD is 1366x768, but most older LG plasma displays are 1024x768. It might be good enough to enter a service menu, though.
                                        Enter the service menu by pressing MENU on the TV at the same time as MENU on the remote.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #100
                                          cheers tom not brought it yet still cant get set running new power supply all correct voltages when linked 5volt stby and ps on with 1 k resistor every voltage spot on remove link put all connectors back on power supply set dead no leds nothing.so persume its a main board fault? i have just been emailed the service manual with the circuit in but how can i upload the pages from it for you guys to help me fault find voltages on the main board? as could be a voltage reg issue on the main board tell me what to test i will but follow a circuit diagram thats another issue!
                                          • Acnologia
                                            Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                                            by Acnologia
                                            Here is a pretty crazy one.
                                            Step 1.
                                            Laptop was brought to me as dead not working. Removed everything , cleared everything.
                                            Step 2.
                                            Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                                            Step 3.
                                            Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                                            Step 4.
                                            Lets ,dive into the board. I see the edp cable on the...
                                            05-07-2025, 07:16 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • hoarderteks_kyriakos
                                            Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
                                            by hoarderteks_kyriakos
                                            Hello.
                                            Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
                                            Here is what happened:
                                            At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
                                            10-08-2025, 07:33 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • eastcoastcomputing
                                            Lenovo Legion7 16ACHg6 no post
                                            by eastcoastcomputing
                                            Hi there, I need help with the diagnostic on this board (NM-D563 Rev2.0).
                                            I could not find schematics nor boardview for it.
                                            The laptop was working, playing game when it suddenly crashed. Thermal paste is good and fans are clean. Since then, when power gets plugged in the laptop tries to come on (led lights light up, on off button lights up CPU and GPU warm up) for a minute or so before shutting down. No Display, no beeps no flashing led
                                            There's no liquid damage. I've checked the board under the microscope and can't find any damaged components. I've checked...
                                            06-24-2025, 04:26 AM
