LG 32lc46 totaly dead
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #61
    Re: LG 32lc46 totaly dead
    Originally posted by tom66
    That's a bridge rectifier. It can be replaced with a 600V 4A device, such as GBU4J.
    like this tom66
    http://www.ebay.co.uk/sch/i.html?_tr...GBU4J&_sacat=0
      That would do fine.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #63
        can the small UF1007 diode which is the other item short be replaced with IN1007 as i have loads also going to order the correct fuse for the power board is it a fast blow type? or slow blow type?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #64
          should of said can the uf1007 diode be replaced with in4007 as got loads of these here.
            No - "UF" means "Ultra-Fast". 1N4007 is a "slow" diode. You need to replace it with a fast recovery diode.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #66
              found 1 thanks
                We are so close to find out why you are not getting the VCC to the PFC IC. Hopefully not much more damage is done to the original problem.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #68
                  ordered the 2 items bridge rectifyer and 1 diode will put in as soon as they come and retest the supply.
                    found 1 thanks
                    Make sure it's a 1000V one.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #70
                      yes they are double checked.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #71
                        before i order some fuses for the power supply are they fast or slow blow type?
                          That is normal. A regulator needs to be tested with an applied voltage. Replace it on the power supply board and test it later when the bridge rectifier arrives.
                            You should use a "T" type fuse - Time Delay.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #74
                              cheers tom
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #75
                                right a little update still have problems i managed to get a good working psu of a member on here but still have problems this is what i have done reassembled the set up with new power supply still dead no led on front nothing removed all connectors on the psu board except the mains lead put a 1k resistor on the stby 5.volt and ps 0n and got all the correct voltages on the psu board ie 12 volt 24 volt and a few other different volts but all spot on with board markings so now i persume the fault is on the main board? the one with the tuner on. will get some pics tomorrow for you. any ideas guys what to check next?
                                  So what DC voltage do you get on PS_ON pin when you turnn the TV on?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #77
                                    just to confirm i am testing this by placing a 1 k resistor as a load on the stby 5 volt pin and the ps on pin on the psu connector with no other connector connected just the mains lead i will take a voltage check in a min for you.
                                    so i am not turning the tv on these voltages are from just the 1k resistor link across the pins
                                    reads 2.92 volts
                                      No resistor attached, we just need to find out if you are getting the PS_ON signal from the main board, which I thought in the earlier post we had the PS_ON signal when you tested it. So you need to connect eveything back together.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #79
                                        0 volts just re read what you had put so just tested it.
                                        how i tested the new psu was just to connect a 1k resistor at pin 5 volt stby and ps on tested all voltage points at the psu connectors marked 24 volts 12 volts etc etc all correct.
                                        so we are not getting the ps on signal from the main board
                                        cant post pics up untill tommorow when i get mates camera but tell me what you want tested i will try to do it will post a pic up from my old camera as a idea of the main board for you
                                          The 1k resistor from 5Vstby to PS_ON test is to verify if the power supply is OK, which from your reports, the power supply is OK. Now you need to find out whay you are not getting the 3.3~5VDC from the main board to feed the PS_ON pin on the power supply.
                                          Time to check the voltage regulators in the main board next.
                                          • Acnologia
                                            Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                                            by Acnologia
                                            Here is a pretty crazy one.
                                            Step 1.
                                            Laptop was brought to me as dead not working. Removed everything , cleared everything.
                                            Step 2.
                                            Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                                            Step 3.
                                            Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                                            Step 4.
                                            Lets ,dive into the board. I see the edp cable on the...
                                            05-07-2025, 07:16 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • hoarderteks_kyriakos
                                            Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
                                            by hoarderteks_kyriakos
                                            Hello.
                                            Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
                                            Here is what happened:
                                            At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
                                            10-08-2025, 07:33 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • eastcoastcomputing
                                            Lenovo Legion7 16ACHg6 no post
                                            by eastcoastcomputing
                                            Hi there, I need help with the diagnostic on this board (NM-D563 Rev2.0).
                                            I could not find schematics nor boardview for it.
                                            The laptop was working, playing game when it suddenly crashed. Thermal paste is good and fans are clean. Since then, when power gets plugged in the laptop tries to come on (led lights light up, on off button lights up CPU and GPU warm up) for a minute or so before shutting down. No Display, no beeps no flashing led
                                            There's no liquid damage. I've checked the board under the microscope and can't find any damaged components. I've checked...
                                            06-24-2025, 04:26 AM
