LG 32lc46 totaly dead
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #121
    Re: LG 32lc46 totaly dead
    right just restested it still 2.00 volts board marking says 3.4-on so any ideas guys the remote turns it on and of ok light flashes when change channel button pressed etc screen does not flash on at all no sound only slight speaker pop when turned on.
    board came of flat tv parts co.uk all number match up.
    just to clarify its the mainboard i have now fitted which has solved the no led issues but now have no picture no sound looks like 24volts to inverter board is spot on just cant figure out why only have 2 volts on the 3.4-on board socket marking just going try with 1 k resistor as a load and see what the voltage is then
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #122
      right placed a 1k resistor as a load no voltage to that pin so voltage must come from the mainboard?
      page 27 in manual socket p900 number 13 in the power section if anyone can figure it out no good a following circuits lol
        No voltage comes from DC-DC on PSU. May be on bottom of PSU.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #124
          so are you saying i should have voltage when loaded with a 1k resistor also whats dc-dc on psu? there are 4 caps i have not changed in the primary side of the psu by the small ls-003 transformer could that be the problem?
            From the 42LC46 it's a synchronous buck converter, it has two MOSFETs on the bottom and an inductor and capacitor.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #126
              this psu defently out of a 32lc46 same as tv model could there be a difference in the 42lc46 your mentioning?
              bottom left in the picture is the underside of that area
                Big difference in 42LC46 (onboard inverters, bigger output power) but probably still has a dc-dc. Most older LG TVs do. Post clear pics of top & bottom.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #128
                  see pic above thats all i have at the minute.
                    Can't see anything in pic do you have a bigger one?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #130
                      edit sorry no camera at the minute but page 1 and page 2 have good pics i saved these pics i just posted wrong sorry
                      so are you saying this pin should have voltage to it when loaded with a resistor
                        If you find a camera let me know- can't really work with blurry photos.
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #132
                          Convinced myself it was a jumper but now not sure as I have noticed the connectors are numbered Jxxx
                            Jxxx means connector. I see it on boards sometimes, or "CN" or "CONN", depending on how the manufacturer is feeling, there seems to be no standard.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #134
                              right a little update as i was in a rush to fit the board yesterday i only glanced at the main board ebr numbers although the first 13 mumbers match up ok the end few dont
                              my new board is 7NEBR3702950812 the old board is 7NEBR37029508006 so this may be the issue i have just emailed the company to see if they have the correct board do you guys think because its the wrong ebr number thats my problem?
                              also whilst i have the boards out side by side i took some ohm readings from the regulators on both boards (what you guys thought was the initial problem eith my old board) i have 2 different readings on a voltage regulator old regulator is
                              pin 1
                              pin2
                              pin3 gnd
                              pin4 66.7
                              pin5
                              new board regulator
                              pin1
                              pin2
                              pin3gnd
                              pin4 01.8
                              pin5
                              both these items are sc156515m 0724 regulators do you guys think this is the problem on my old board if so anyone got any ideas where to get 1 from in the uk.cheers
                              http://pdf1.alldatasheet.com/datashe...CH/SC1565.html
                                Probably not. The 3.4V is your problem. Start by checking that with pull up on PSON.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #136
                                  Start by checking that with pull up on PSON. can you explain a bit more please.
                                    1k from 5Vstby to PSON.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #138
                                      yes done that 0 volts on that pin but are we sure it should have voltage on it or does it take its voltage from the mainboard says 3.4_on psu unit says 3.3_on the mainboard but when the tvs green leds on it has 2.0 volts to the pin thats whats making me think the voltage comes from the mainboard?
                                      cheers tom for your advice
                                        I expect it is a signal from mainboard to PSU.  There should also be a 3.4V output pin is this around 3.4V?
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #140
                                          yes that other 3.4 v pin is spot on cheers guys for your help i have just been offered a good price for just the screen i get to keep the invertor board psu and tcon so going to let the set go its a pity but have got a full refund for the mainboard coming so not out of pocket at all. but for a novice like me the procedure for testing items and fault finding has been great so thanks for all you help and advice guys be back soon with another project no doubt shortly as just of to my local recycling center may see what they have.
                                          • Acnologia
                                            Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                                            by Acnologia
                                            Here is a pretty crazy one.
                                            Step 1.
                                            Laptop was brought to me as dead not working. Removed everything , cleared everything.
                                            Step 2.
                                            Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                                            Step 3.
                                            Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                                            Step 4.
                                            Lets ,dive into the board. I see the edp cable on the...
                                            05-07-2025, 07:16 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • hoarderteks_kyriakos
                                            Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
                                            by hoarderteks_kyriakos
                                            Hello.
                                            Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
                                            Here is what happened:
                                            At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
                                            10-08-2025, 07:33 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • eastcoastcomputing
                                            Lenovo Legion7 16ACHg6 no post
                                            by eastcoastcomputing
                                            Hi there, I need help with the diagnostic on this board (NM-D563 Rev2.0).
                                            I could not find schematics nor boardview for it.
                                            The laptop was working, playing game when it suddenly crashed. Thermal paste is good and fans are clean. Since then, when power gets plugged in the laptop tries to come on (led lights light up, on off button lights up CPU and GPU warm up) for a minute or so before shutting down. No Display, no beeps no flashing led
                                            There's no liquid damage. I've checked the board under the microscope and can't find any damaged components. I've checked...
                                            06-24-2025, 04:26 AM
