Wiping hard drives
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Wiping hard drives
    Whats a good utility out there for obliterating data on a hard disk (sata) these days? I haven't had the need to do this since the SCSI days, and back then, I'd do a low-level format on them from the controller BIOS, which always did the trick....but that's not an option today apparently.
    The reason I ask, I'm cycling out a bunch of drives, and will be pretty much giving them away.....so it's rather obvious why I want to make sure all the data is destroyed.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • TVRepairNoobie
    • Feb 2015
    • 158
    Re: Wiping hard drives
    Hi Topcat,
    I formatted a bunch of IDE Seagate HDD (60+) using SeaTools from Seagate.
    80GB took 30-45 minutes to format.
    You could also try Active @ KillDisk free version. I think it might take longer to format each drive.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      DBAN if your hosting Personally identifiable info on the drives. Otherwise with the data densities of the newish disk just zero it out. dd if=/dev/zero of= /dev/ad0 with *BSD
      Follow the white rabbit.
      • dmill89
        • Dec 2011
        • 2534
        X2 on DBAN it's free and gives you several different wiping options.
          • 31048
          DD for user data,
          but with modern drives there is so much redundant suface area in them that you can never be sure all the data is really gone.
          you wont protect it from a recovery company with it's own firmware.
          • Compgeke
            • Feb 2014
            • 524
            DBAN is what I've always used. It's good enough we were able to use it on government surplus computers no problem. Also free and supports doing massive amounts of drives at once (we had a system setup to hold 12 disks for wiping but there's no real limit).
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              awesome fellas, thanks!
              Team : 49813
              Join in!!
              Team Stats
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Originally posted by Topcat
                Whats a good utility out there for obliterating data on a hard disk (sata) these days? I haven't had the need to do this since the SCSI days, and back then, I'd do a low-level format on them, which always did the trick....but that's not an option today apparently.
                Are those the 74GB Raptors?
                As for the formatting, DD does a good job... If keeping the drives didn't matter, I'd suggest your truck or perhaps a winchester, Remington, or browning shotgun
                sigpic
                (Insert witty quote here)
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16956
                  Actually, it does include those. I have 4 of them. When I'm finished with the swapout, you're welcome to them.
                  They are still very usable, don't want to destroy them....otherwise, yes, they would become clay pigeons.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • noppa
                    • 41
                    MHDD!
                    But any other tool that can write a pattern from 0 to MAXLAB
                    will do the job.
                    http://hddscan.com/
                    http://hddguru.com/software/HDD-LLF-...l-Format-Tool/
                    http://www.majorgeeks.com/files/deta...r_windows.html
                    multiple passes are just a WASTE of time on modern (magnetic) disk,
                    if disk is healty a single pass will delete anything.
                    another option is internal secure erase, but is buggy on some disk.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      I'll be in STL this April... so if they're ready by then, I'll claim them then (if not, whenever they're ready I'll pay shipping). Now to find four other drives to put in my main rig (at least to do what I want to do, which requires 8 drives, and I already have 4 74GB's in said rig).
                      sigpic
                      • fzabkar
                        • Mar 2009
                        • 772
                        Originally posted by stj
                        DD for user data,
                        Nonsense. The only data that may be recoverable are those in reallocated sectors. Even so, an ATA Enhanced Secure Erase will wipe those, too.
                          • 31048
                          most people cant do a firmware based security reset.
                          most motherboard sata controllers wont pass those commands to the drive.
                          you can buy microcontroller based "dongles" for doing it, but they are actually intended for recovering drives with a forgotten hardware password.
                          • fzabkar
                            • Mar 2009
                            • 772
                            That's just more nonsense. The Enhanced Secure Erase command is part of the ATA standard. It has nothing to do with Vendor Specific Commands. A freeware tool such as the following will do it for you:
                            http://cmrr.ucsd.edu/people/Hughes/secure-erase.html
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              Yup, either DBAN or the drives internal secure erase command.
                              The latter if support is better since it also will clear hidden HPA areas like reallocated sectors etc.
                              The tool fzabkar linked above can be quite fnicky with what hardware it likes to run on though.
                              Tools like the excellent HDAT2 will also allow secure erase to be performed, along with showing all SMART statistics and what more might be of interest.
                              Or HDPARM if you are on Linux...
                              • fzabkar
                                • Mar 2009
                                • 772
                                Beware - When SECURE ERASE doesn't erase at all :
                                http://www.hddoracle.com/viewtopic.php?f=56&t=1412
                                More secure erase bugs ...
                                https://cdn.badcaps-static.com/pdfs/...79eb060c40.pdf
                                Remember that simply zero-filling a flash drive or SSD won't touch the over-provisioned area. Wear levelling moves your data around so you will be very dependent on the drive's secure erase function or cryptoerase, if your drive supports it. SED HDDs also support cryptoerase, which means that your data are instantly erased by discarding the security key.
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  i often just use minitool partition wizard.use the zero fill.
                                  unless you are a tla its good enough for a hdd.ssd are a bit tougher...
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16956
                                    yup, dban works quite nicely. Thanks for the recommendation.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      You can always use a gentle cloth with isopropyl alcohol
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16956
                                        or a really strong magnet
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • madura2010
                                          DAY11AM6E0 hard disk drive and optical disk drive not detected
                                          by madura2010
                                          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                          i checked the connectivity of ribbon=good communication with hard and motherboard
                                          changed hard disk and checked=3f0 error persist
                                          sata power=+5v available
                                          Then checked data capacitors=all good
                                          Then checked data lines path connectivity to pch=all good
                                          reflashed...
                                          03-12-2023, 09:09 AM
                                        • eccerr0r
                                          failing hard drives after sitting for years...
                                          by eccerr0r
                                          With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                                          Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                                          Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                                          03-02-2023, 10:33 AM
                                        • Eleways
                                          Apple Macbook A1707 Hard disk
                                          by Eleways
                                          Hi
                                          I've an Apple macbook A1707 with Hdd defect.
                                          This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
                                          My question is:
                                          Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
                                          Can i replace with a different one (es 500 gb instead of 250 gb)
                                          This Macbook has T1 security check.
                                          Thanks and best regards
                                          Luca
                                          02-18-2022, 04:23 AM
                                        • Zentech
                                          Laptop Hard Disk Not Recognized By Computer
                                          by Zentech
                                          I have a laptop hard drive that I've plugged into different computers and it is not getting recognized. I'm using a usb connector/sata adapter to use it as usb storage, but "Disk Manager" is not giving me the Initialize disk option. I can scan the disk for error, I tried in Windows and Linux with same result. Is this a problem with the hard drive hardware? has anyone repair a hard drive before?...
                                          04-19-2021, 09:29 AM
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
