Wiping hard drives
    • 31294
    Re: Wiping hard drives
    if you use a magnet on a modern drive it's probably only good for the magnets afterwards.
    you will erase the calibration data and config table. (size serial number etc.)
    • fzabkar
      • Mar 2009
      • 772
      The Urban Legend of Multipass Hard Disk Overwrite:
      http://www.infosecisland.com/blogvie...Overwrite.html
      • fzabkar
        • Mar 2009
        • 772
        Originally posted by Topcat
        or a really strong magnet
        One of the professionals at HDD Guru placed neodymium magnets all over the case of a HDD and was still able to retrieve all the data from it. The again, I have a massive 15cm x 16cm x 17cm voice coil magnet from a very old Control Data drive which would likely destroy any HDD. I should try it someday.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          Sure would be nice if you could pop out the hard disk and use a degausser over it and then pop it back it.
            • 31294
            some drives have magnetic shields on the lid.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              So what I am reading is the drives can be recoverable with low level formatting, however you would have to have special equipment that the manufacturer has to do this. Seems like the servo codes get erased so the R/W head does not know where it is. I guess if you had the servo code you would be in business. That would be velocity/ acceleration/ position and a feedback for error correction. There is actually a mathematical formula for this. I have seen this done with just TTL ICs, no processor, no RAM, no ROM. Just TTY tape or Reel to Reel with TTL ICs
              • fzabkar
                • Mar 2009
                • 772
                This article was written by a former Seagate employee:
                http://hddscan.com/doc/HDD_Tracks_and_Zones.html
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  Question could one burn a spiral track going from the outer edge using and equation for a given HD disk, spiraling around until it reaches the inside edge and use this to tell where the disk is at, perhaps have the laser deflect a differently angle on this one spiral to change the pick up frequency of the laser frequency so it knows that this is different from the other data. So spinning from one revolution to the next would position the head by electrically detecting and correcting the error.
                  • fzabkar
                    • Mar 2009
                    • 772
                    HDDs use magnetic recording, not optical.
                    Heat Assisted Magnetic Recording (HAMR) is an emerging technology that augments magnetic recording by preheating the disc surface with a laser.
                    http://hddscan.blogspot.com.au/2011/...h-of-jedi.html
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Yes I know they use magnetic recording, but could they not use a laser and a track like I said for alignment of the just the R/W head. I got a little confused between the optical drive and the Hard drive in the previous post for data retrieval I forgot magnetic heads don't pick up bumps on the surface and operate by magnetic charge. I wounder what happens when one sends light through a magnetic charge.
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        Almost all the way through this article. Very interesting. Thanks fzabkar. It just seems there is a better way. I wonder if one had three disk one a read dish, one a write disk and in between a disk made up of read heads one side of this disk and on the other side a write head. This last disk would be the same size as the other two disk but would be loaded with R/W heads all over it. There would be no moving parts. Just a thought, which is what my mine constantly does, ask what if.
                        • fzabkar
                          • Mar 2009
                          • 772
                          Current technology uses Dual-Stage Actuators. A regular rotary voice coil handles the coarse positioning while a piezo element provides fine positioning.
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            Very interesting just adding 2 piezos create a small enough movement to create more accuracy.
                            I have been thinking about polarized laser light being applied to a dielectric causing a magnetic charge and having a magnetic wafer being magnetically charged to 1 bit and on the other side of the magnetic wafer is another dielectric that then interprets the magnetic charge and using a Xor in the input to output comparing to confirm the bit is a either a 0 or a 1.
                            • brethin
                              • Dec 2008
                              • 1907
                              Actually, it does include those. I have 4 of them. When I'm finished with the swapout, you're welcome to them.
                              They are still very usable, don't want to destroy them....otherwise, yes, they would become clay pigeons.
                              If you have any more SATA and SAS hard drives you consider clay pigeons please pop me a message, I am in need of these daily and would not expect them for free.
                              • madura2010
                                DAY11AM6E0 hard disk drive and optical disk drive not detected
                                by madura2010
                                Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                i checked the connectivity of ribbon=good communication with hard and motherboard
                                changed hard disk and checked=3f0 error persist
                                sata power=+5v available
                                Then checked data capacitors=all good
                                Then checked data lines path connectivity to pch=all good
                                reflashed...
                                03-12-2023, 09:09 AM
                              • eccerr0r
                                failing hard drives after sitting for years...
                                by eccerr0r
                                With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                                Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                                Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                                03-02-2023, 10:33 AM
                              • Eleways
                                Apple Macbook A1707 Hard disk
                                by Eleways
                                Hi
                                I've an Apple macbook A1707 with Hdd defect.
                                This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
                                My question is:
                                Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
                                Can i replace with a different one (es 500 gb instead of 250 gb)
                                This Macbook has T1 security check.
                                Thanks and best regards
                                Luca
                                02-18-2022, 04:23 AM
                              • Zentech
                                Laptop Hard Disk Not Recognized By Computer
                                by Zentech
                                I have a laptop hard drive that I've plugged into different computers and it is not getting recognized. I'm using a usb connector/sata adapter to use it as usb storage, but "Disk Manager" is not giving me the Initialize disk option. I can scan the disk for error, I tried in Windows and Linux with same result. Is this a problem with the hard drive hardware? has anyone repair a hard drive before?...
                                04-19-2021, 09:29 AM
                              • federalhouse
                                **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                by federalhouse
                                I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                **Background:**
                                I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                **What I've Tried So Far:**
                                1. I accessed
                                08-01-2024, 07:03 PM
