Sorry for ranting!
Damn, I just discovered a "D" data drive in one of my PCs had shit-canned itself 4 days ago. I tried to access it over my network via VNC and kept erring.
Viewing the logs, it never booted up when I powered up the PC. No warning, no reason. Worked fine up to now, and used sparingly. The only suspect item was that Power Saving setting under Windoze was set to spin down drives after 15 min. to save power and reduce heat.
It was a WD 40 GB PATA factory replacement almost 2 years old. So it's a refurb.
It was fully packed with videos...WRC, MotoGP, F1, TouringCar of which I haven't watched yet. DAMN!
I can't figure out what killed it. Never saw SMART warnings, transfered Gigs off it a week before. Wasn't even running hot since it's not spinning.
Just cold boot dead.
Must be due to it being a WD POS refurb. It's only a 40GB, but I hate the loss of data without warning.
Sadly, I still have (2) 80, an older 120, and a WD rebadged 160 GB. Haven't had a WD failure until now...actually a HDD failure until now. Guess I'm no longer a virgin.
I've seen IBMs, Maxtors, WDs fail (none of my own). Too many Maxtor failures to ever buy another one.
I was about to order a WD 400 GB SATA, now I'm leary.
That only leaves Seagate. I only have one that I bought this year...so that isn't enough to go on to draw any conclusions. So far it's good, but I have noticed its (SMART) temps have risen since new. And this is with a dedicated 80mm fan cooling it.
What's the worst brand you guys have come across failure wise?
I guess I'll try the freezer trick on the WD, nothing to lose now.
