#$%*!@ WD HD crap!
  • WNG
    • Sep 2006
    • 354
    #$%*!@ WD HD crap!
    Sorry for ranting!
    Damn, I just discovered a "D" data drive in one of my PCs had shit-canned itself 4 days ago. I tried to access it over my network via VNC and kept erring.
    Viewing the logs, it never booted up when I powered up the PC. No warning, no reason. Worked fine up to now, and used sparingly. The only suspect item was that Power Saving setting under Windoze was set to spin down drives after 15 min. to save power and reduce heat.
    It was a WD 40 GB PATA factory replacement almost 2 years old. So it's a refurb.
    It was fully packed with videos...WRC, MotoGP, F1, TouringCar of which I haven't watched yet. DAMN!
    I can't figure out what killed it. Never saw SMART warnings, transfered Gigs off it a week before. Wasn't even running hot since it's not spinning.
    Just cold boot dead.
    Must be due to it being a WD POS refurb. It's only a 40GB, but I hate the loss of data without warning.
    Sadly, I still have (2) 80, an older 120, and a WD rebadged 160 GB. Haven't had a WD failure until now...actually a HDD failure until now. Guess I'm no longer a virgin.
    I've seen IBMs, Maxtors, WDs fail (none of my own). Too many Maxtor failures to ever buy another one.
    I was about to order a WD 400 GB SATA, now I'm leary.
    That only leaves Seagate. I only have one that I bought this year...so that isn't enough to go on to draw any conclusions. So far it's good, but I have noticed its (SMART) temps have risen since new. And this is with a dedicated 80mm fan cooling it.
    What's the worst brand you guys have come across failure wise?
    I guess I'll try the freezer trick on the WD, nothing to lose now.
    “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
    We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
  • starfury1
    • May 2006
    • 1256
    Re: #$%*!@ WD HD crap!
    Sorry to hear the WNG
    humm well it depends (as you know on the type of failure) you suspect....you could possibly use the same model drive pcb if you can find one.
    I never had to use the freezer trick (yet and hope I never have to)
    but from what I read its really one shot affair, so if it works grab as much as you can and don't dilly dally...anyway that the story from what I understand you first shot is your best...if its a failure of the mechanical type.
    leave this open for others to comment on...best method to get your stuff back.
    Yeah "backup" is the magic word but I guess at times we all could stand accused of not doing it with something we really want...although I guess there are those that treat it as a religion (and maybe rightly so)
    HDD failures seems no brand is safe totally from it and I think they have all had a dud model at one point or other.
    Its a mechanical device so prone to failure at some point I guess even if the electronics will last for years
    (and there has been issues with some of that too with some models)
    I have read that failures are becoming more common with all. so its now more then ever BACKUP is important. (if what I read is true)
    I suspect since the drive market is so cut throat (and when you look at prices you see why) being made as cheap as possible etc with minimum profit on them (compared to the old day) I guess has got to increase failure rates.
    Yours was way old and a refurb at that, so I wouldn't have put much faith in it and only used it as temp storage of stuff I had backed up
    (this doesn't mean a brand new one isn't just as liable to die...they do)
    I have had seagates fail (20GB and 40GB) out of box and my personal 10gb went way ward I think my 40GB WD is a bit suspect
    (I have a funny feeling this is an IBM rebage some how not sure on the story)
    Yes it would be a interesting to see what others here have had die on them.
    Id be really interested in the failures form those that process a lot of drive like system builders etc
    Repairers here could offer a good spectrum of knowledge on failures too.
    but anyones opinions would be welcomed.
    Oddly enough I have a WD SATA 400GB (KS) coming if it ever gets here.
    best thing is to google it and see what falls out, if you see failures with a common thread then probably safer to avoid it I guess.
    I didn't but WD have been mostly good so wet finger in the air and Hope.
    (in a hurry, price wasn't too bad but I really should have done some research on it)
    Just my thought on it
    CHeers
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Originally posted by WNG
      I can't figure out what killed it. Never saw SMART warnings, transfered Gigs off it a week before. Wasn't even running hot since it's not spinning. Just cold boot dead. Must be due to it being a WD POS refurb.
      every wd i have seen fail did exactly that. actually i have never received any useful smart warning for any hard disk, the most important thing i believe is to listen to hdds and any abnormal sound like whining, pings....backup and replace immediately.
      there were a few well known hdd turds but with seagate, wd i have had mixed experience, if they were crap i would realise that from office experience, but i am not of that opinion. sure i get some early fails which suggest that manufacturing tolerances/ qc is not perfect
      sorry to hear about your data. problem now is that everybody i am sure has so much data that its not really possible to backup everything properly.
      • starfury1
        • May 2006
        • 1256
        Humm yeah Will....I agree ....thats the problem.....a HDD is much larger then DVD's so things tend not to get backed up
        I try hard to keep personal stuff backed up like photos and home vid's etc...the things you really cant replace
        • gastorgrab
          • May 2007
          • 320
          I no longer buy WD hard drives.
          • gonzo0815
            • Feb 2006
            • 1600
            I still only trust the WD Raptor like series, nothing else from them.
            Have had a few WD 40 and 80gb drives which failed on me.
            For anythings else i still using and buying mostly Samsung drives.
            Recently i tried some Hitachi ones too.
            It`s always a gamble with IDE HDD`s, but if a vendor served me well, it stick to it until the inevitable happens and they screwed it up.
            • stevo1210
              • Oct 2006
              • 4156
              Every WD hard drive i've had has either died or come up with bad sectors. I bought a WD WB1600JB IDE drive last year and within 2 months, returned it and traded it in for a Seagate SATA drive. It had a bunch of bad sectors and Windows didn't want to boot at times either.
              I have one WD hard drive remaining now and it's a 20GB IDE WD drive, it's also about to die. Everytime I turn my PC on, it makes clicking noises for a 10-15 seconds and then goes back to the normal whining noise it usually makes.
              I never buy WD hard drives now, I only use Seagate and also Samsung drives. I have used Hitachi hard drives and they are good too. I've had good luck with my 40Gb IBM Deskstar also, there hasn't been any issues with it yet.
              • Junk Parts
                Court Jester
                • Jun 2006
                • 8953
                I have a three year old WD 7200rpm 40 Gig IDE in my junk, and a new WD 80 Gig 7200rpm IDE in the wifes junk too. Her first new WD lasted a month then just went away as yours did. It was replaced by WD with a new one. No problems so far. In the past I have put many WD drive in the trash bin. Quantums also ride the magic trash bin here often too. I did learn that with some of the WD drives its best to use the drive setup disk that comes with them. Both of the 80 gigs were slow as hell until first being setup with the WD utillity. I don't know why. All in all I don't think WD makes the cut these days. I have used Maxtors with good luck for the most part in the past. I have had two maxtor failures and these drives were in the four to five year old range. I was able to boot these drives as slaves, and recover the customers personal data. Sorry but with the cost cutting going today we are lucky is any of this crap we buy works at all. I wonder if these WD drives are being made in China now?
                Mark Twain
                John Paul Jones
                Rod Serling
                • PedroDaGr8
                  • Oct 2006
                  • 130
                  Sorry for ranting!
                  Don't forget Samsung, I love their drives, quiet and fast.
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    bwahahaha quantum is owning the magic trash bin
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      i see a ton of bad maxtors with wd in second place.
                      does that wd spin?is it clicking?
                      unless the heads and platters ground up i can get the data from most with a board swap or head stack swap.
                      dont overlook the stupid shit.
                      had a customer bring in a wd for data recovery.3 shops told him it was hopeless.
                      set the jumper for the recovery board and fired it up.
                      nothing wrong or intermittant?
                      recovered everything before powering off.customer comes in and i ask how it was configured in his box.
                      he said only 1 drive in system.no opticals either(drive was from a cnc machine)
                      when it came in jumper was on master.wd drives use no jumper for single drive.
                      who moved it?his wannabe pc tech.
                      real issue was a bad psu.
                      • Maxxarcade
                        • Jul 2006
                        • 973
                        Knock on wood, I've had two 320GB WD's in my NAS bought new over a year ago, still going strong. Also have a 320GB Seagate.
                        Maxtors I am scared of. I have a stack of about 30 dead Fireball 3 and a few Fireball CX. Seen a few dead WD's, but nowhere near the amount of Maxtor. I do have a WD800 80GB that runs but is very slow and has a ton of bad sectors.
                        Ironically I've had two 160GB Maxtors in my main PC for years and they still work fine. Maybe the quality of the PSU and the amount of cooling affects it.
                        I am scared of Hitachi also, since they are just rebadged IBM's for the most part, and after the 75GXP series I don't want to go back. Also bought a new 30GB travelstar for my laptop years ago, and it always made random clicking noises. Now I have a Samsung 160GB in my lappy and it's great
                        Overall the most reliable drives I've seen are probably Samsung and Seagate.
                        • linuxguru
                          • Apr 2005
                          • 1564
                          The real issue is bad PSUs, especially the quality of the +12v rail. Even the so-called IBM 60GXP and 75GXP 'Death Stars' have very low failure rates with good IBM (Delta OEM) PSUs. All four of my 60GXPs purchased new in 2000 are still functional, though one has some bad sectors. In systems powered by Deer or Powmax PSUs, the story is very different. High ripple on +12v is definitely one cause of failure, aggravated by poor cooling.
                          For notebooks, the Seagate Momentus 5400.2 and 5400.3 are very good - I haven't had a chance to try out the 7200 series yet.
                          • Newbie2
                            • Sep 2005
                            • 885
                            In 2003, I had a Seagate 60GB ST360012A PATA hard drive in a then-new HP Pavilion 514n PC, and that Seagate hard drive crashed. I was unprepared for a hard drive crash at that time, so I lost a lot of data.
                            Got the hard drive replaced under warranty, same Seagate hard drive. It has been transferred to 2 PCs (my current main PC, then my backup PC), and its still going strong.
                            The POS PSU in my old HP Pavilion was a Bestec PS3-size 200W power supply. This info might support linuxguru's theory about having a POS PSU along with a HD.
                            My gaming PC:
                            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                            ASUS M4A77TD AMD 770 AM3 Motherboard
                            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                            ASUS Xonar DG 5.1 Channel PCI sound card
                            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                            Antec Three Hundred Mid-Tower Case
                            Microsoft Windows 10 Pro 64-bit
                            Microsoft Windows 7 Ultimate SP1 64-bit
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              Fujitsu or bust!
                              <--- Badcaps.net Founder
                              Badcaps.net Services:
                              Motherboard Repair Services
                              http://folding.stanford.edu/
                              Team : 49813
                              Join in!!
                              Team Stats
                              • starfury1
                                • May 2006
                                • 1256
                                yeah it does raise an interesting point
                                Re the PSU HDD relationship
                                "How often is a crap supply responsible for the demise (or early demise) of the HDD"
                                or guess the other side is "How well a HDD can handle a crap PSU"
                                Thank you all too for adding to the post
                                • WNG
                                  • Sep 2006
                                  • 354
                                  How strange is that!?! The original WD 40 GB came from a HP Pavilion 514! It slowly began to die with longer boot times and finally SMART warnings.
                                  I better go back and inspect that PC and confirm the BESTEC PSU. I have a few spares I can swap in for the owner.
                                  I retrurned the dead drive and got this one. I will assume my PSU wasn't the culprit. It's a 250W Delta.
                                  Heat may have been the issue, although the environment isn't hot, with an intake fan right beneath it. It's cool enough in there to sustain a slimline 30GB Maxtor. And those have one of the worst reps. That OS drive is backed up accordingly.
                                  It's true, with so many drives in so many boxes, backing up all becomes almost impossible. This one wasn't backed up as it was only video downloads and I assumed I'd be watching then deleting each file.
                                  Thanks for the feedback guys. I did forget Samsung, I have an old 20 GB that's still going after 9 years. No more WD for me.
                                  • acstech
                                    GrumpyModerator
                                    • Jul 2007
                                    • 1432
                                    QFT!!!
                                    The worst I've seen, and it was probably already mentioned, was the IBM Deskstar series. Every ****** one of them I knew about failed. Knock knock knock... ping ping... knock knock knock... ping ping...
                                    I've seen quite a few WD's fail too. Back in the day everyone used to say how wonderful they were. I dont see where they're any better than average. I did see one in a Dell recently though, where a bad cap in the PSU obviously caused the hard drive to crash. Fortunately the rest of the system was ok, and with a new HD and recapping on the PSU it went on it's merry way.
                                    A man convinced against his will is of the same opinion still.
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      In my lifetime I have only seen one maxtor drive fail me. Every other maxtor I have used were either slow or rock solid. I had one IBM drive go in my old mac SE but I think it was because I improperly installed it.
                                      As a matter of fact I have had more apple hard drives die than regular pc drives.
                                      Moving back to WD, I have NEVER seen one of their drives go bad unless you were really careless. and I have never had a seagate fail. My ST-225 is still purring along.
                                      Find Nedry!
                                      Check the Vending machines!!
                                      • PedroDaGr8
                                        • Oct 2006
                                        • 130
                                        Modern hitachis have nothing to do with IBM and haven't since not long after they took over IBMs DeathStar. THey were smart enough to realize that it was a POS and redesigned it from the ground up. Unfortunately, they still carry this stigma.
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          Replaced emmc.
                                          Terminal log
                                          UART
                                          AC_ON
                                          E-B
                                          FDE enabled
                                          06-01-2025, 02:11 AM
                                        • ctroxtell
                                          Carrier HK50AA063 display controller common failure help
                                          by ctroxtell
                                          I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                                          02-05-2025, 05:31 PM
                                        • Eniaro
                                          10 Amp switch 15 Amp fuse
                                          by Eniaro
                                          So, my VEVOR ultrasonic cleaner switch melted.
                                          I contacted VEVOR, they sent me a new one after almost a month of back-and-forth messages.
                                          Over the past few months, I've also replaced switches on heat presses (from various brands) with similar failures. What caught my attention is that the switches are always rated for 10 amps, but the fuses are always for 15 amps. this mismatch?
                                          I've started to second-guess my knowledge. Everything I've researched says exactly what's happening to these switches.
                                          This issue hits far too close to home. I'm concerned...
                                          12-30-2023, 08:12 PM
                                        • howardc64
                                          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                          by howardc64
                                          Problem
                                          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                          Model & Board Pics
                                          Conflicting Spec
                                          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                          https://www.shopjimmy.com/vizio-gj-2k1...
                                          10-10-2024, 01:16 PM
                                        • freakaftr8
                                          Asus a15 FA507RE-A15.R73050T failure
                                          by freakaftr8
                                          So this laptop seems to have some kind of failure. I bought it second hand and originally the previous owner said that they went to turn it on and it was presented with a quick flash of the power light the keyboard lit up and then the keyboard shut off and the power light went off as well but the battery indicator was white and after about 5 to 7 Seconds flashes orange really quick then shuts off and goes back to White. If the power button is pressed again the keyboard lights up really quick and then repeats. When I got it I could press the power button multiple times the keyboard light would...
                                          03-28-2024, 10:58 PM
