HISENSE 65E7KQ PRO - no boot
  • Sus256
    • Sep 2024
    • Russia
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    Replaced emmc.
    Terminal log
    UART
    AC_ON
    E-B
    FDE enabled
    layout pattern onebin by SAR7,0
    [ETT_Main]MIU_ver 20230313-7218697-OneBin-V11.0
    [DRAMC] AC ON-0
    [FAST_K]
    [MOBF] Gen SW key
    [FAST_K]
    dispatch to 1 EMI 2 CH
    MIUP set area: 3GB
    EMI bist: M0 pass
    EMI bist: M2 pass
    fake engine: pass[00000000]
    fake engine: pass[00000001]
    u4dram_info=0x2406
    TEELOADER_VERSION=0x00000000
    optee teeloader entry
    Part not found
    Part not found
    Load Onebin header failed!
    Load armfw failed,ret=0x00000005
    Cleaning DRAM...
    ARMFW_VERSION=0x00000000
    OPTEE_VERSION=0x00000000
    OPTEECUST_VERSION=0x00000000
    SecureStor Key is not written!
    REELOADER_VERSION=0x00000000
    ns_uboot_boot
    ree_entry
    Check WDT....
    UBOOT_VERSION=0x00000000
    RPMB_ROLLBACK is DISABLED
    This is not all, but it swears at rpmb.
    The manufacturer has provided the update file usb_MTK_9618_EU_2.bin. By serial number. Can anyone tell me how to extract mboot from it? In donor dumps mboot is encrypted.
    When writing mboot_a mboot_b to emmc and boot1 and trying to install software via USB with the cu -full command, I received the log:
    hs>>power-on
    hs>>power-on
    hs>>power-on
    hs>>power-on
    hs>>power-on
    hs>>power-on
    Saving Environment to EXT4...
    ** Unable to use mmc 0:3 for saveenv **
    Failed (1)
    hs>>in-upgrade
    hs>>in-upgrade
    hs>>in-upgrade
    USB0: MTK XHCI version: 2021-12-06
    [MTK] number of Available phy 4
    [MTK] xhci_mtk_ssusb_init u2p:3, u3p:1
    Register 400010f NbrPorts 4
    Starting the controller
    USB XHCI 1.10
    scanning bus 0 for devices... 2 USB Device(s) found
    USB1: MTK XHCI version: 2021-12-06
    [MTK] number of Available phy 2
    [MTK] xhci_mtk_ssusb_init u2p:1, u3p:1
    Register 200010f NbrPorts 2
    USB XHCI 1.10
    scanning bus 1 for devices... 1 USB Device(s) found
    scanning usb for storage devices... 1 Storage Device(s) found
    lvgl enable
    USB XHCI 1.10
    USB XHCI 1.10
    part_get_info_efi: Invalid Argument(s)
    Can usb 0:1 for fatload
    usb devno:0, partno:1
    [INFO]cmd: hisusbfatls usb 0:1 0x5bcbcee0 51200
    2 file(s), 0 dir(s)
    System Volume Information
    upgrade_image.pkg
    [do_getforcepkgfile] find 0 file(s)
    upgrade file upgrade_image.pkg was found
    get usb force upgrade filename name:upgrade_image.pkg
    [ERROR] _convert_ab_name:134: [ERROR] Get ab selection fail, get_ab_selection_result return 2
    [ERROR] get_partition_info:394: [ERROR] Convert ab name fail
    [ERROR] read_storage_file_to_memory:1060: Error: sys_get_storage_info failure
    [ERROR] get_panel_dlg_info:923: Read ini file to DRAM failure
    Error: Read panel gamma bin failure
    bootargs is NULL, Active Standby Mode FALSE =====
    [ERROR] dataindex_get_info:277: cannot find project_id.ini
    [ERROR] dataindex_get_handle:308: cannot get dataindex information
    [ERROR] standby_init:79: cannot get Standby:m_pStandbyMode_File from dataindex file
    [ERROR] do_partition:104: do_partition error!
    [drvEEPROM.c EEPDTV_SetCfg 709] DtvCfg:[53 81 0 0 0 0 0 0 0 d4]
    [ERROR] _convert_ab_name:134: [ERROR] Get ab selection &ail, get_ab_selection_result return 2
    [ERROR]▒get_partition_info:394: [ERROR] Convert ab name fail
    "Synchronous Abort" handler, esr 0x96000004
    elr: 000000002754dfd0 lr : 000000002754df9c (reloc)
    elr: 000000005fe0afd0 lr : 000000005fe0af9c
    x0 : 0000000000000000 x1 : 00000027▒2563d48
    x2 : 0000000000000055 x3 : 000000005ff3c200
    x4 : 0000000000000004 x5 : 0000000000008020
    x6 : 0000000000000000 x7 : 000000005b94f7e0
    x8 : 00000000ffffffe8 x9 : 0000000000000001
    x10: 0000000000000000 x11: 000000005fe3a9e0
    x12: 000000000149c2dc x13: 000000000149c26c
    x14: 00000000ffffffff x15: 000000005b94f7c8
    x16: 00000000000010▒▒▒7: 000000001a040d48
    x18: 000000005bc9cdd8 x19: 000000005ff3c200
    x20: 00000000fba88e55 x21: 000000005bcb8eb0
    x22: 000000005bcb8eb0 x23: 000000005b94d518
    x24: 000000005b94e7d7 x25: 0000002752563d48
    x26: 0000000000000004 x27: 0000000000000001
    x28: 00000000002c7df0 x29: 000000005b94d440
    Resetting CPU ...
    resetting ..
    hs>>sys-reset
    hs>>sys-reset
    hs>>sys-reset
    please help
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4889
    • Italy - Milan
    Hi, few experience here in these restores but, have read rapidly all the log, how do you have restored UBOOT enviroment on new support? And is it possible that update routine cannot find the correct partitioning of the emmc so it cannot extract temporarily the update package? It is possible it is searching for a recovery partition maybe.. i think you need to take the update package and load it in a virtual disk on a PC equipped with Linux.. and examine the disk to find internal partitions.. No matters if TV is android, filesystems are the same, usually are EXT2/3/4 and FAT for user data.. bye...
    PS: have you read original EMMC with inline wires or detached on a socket?
    • 1centchips
      a2159 not able to revive, disconnects at step 4 of reviving
      by 1centchips
      Goes to recovery when plugged in with another Mac, shows in finder with a question mark and serial number. When revived fails at error 9 (the laptop turns off and on?) In the Apple Configurator when in dfu, gives error restores device removed before restore completed 0xFAA (4010). Tried in intel and m1 based Macs.
      History, came in with severe liquid damage and bubbly motherboard Transplanted t2/ recalled ram, u4730, all 4 nands and u4770.
      Below is the log from console, the usb meter negotiates at 19v and goes as high as 2.4A
      Apr 1 08:36:25 macs-MBP UARPUpdaterServiceDisplay[1440]:...
      04-01-2026, 11:38 AM
    • sushilachuthan
      APC UPS error P13
      by sushilachuthan
      one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
      the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
      The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
      We replaced the SCR with new device,, but the device is not power on as expected.
      Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
      09-26-2025, 09:00 AM
    • yoritomo
      Philips 40PFK4100/12 CI key fail error
      by yoritomo
      TV Philips 40PFK4100/12
      Chassis TPN15.E LA
      Hello everyone.
      I am facing a red message above the screen permanently, also the image is greyed and the TV is unusable as is in any sources.
      Of course I tried everything basic or a bit advanced, so I updated the firmware to version 2.550 which did not resolve the problem.
      Accessing the secret menu by I have access to 3 interesting parameters regarding this issue
      -DRM Warning
      -CIPlus Query
      -CIPlus update
      Obviously I tried to set DRM warning to OFF but this don't...
      08-17-2025, 12:27 PM
    • dragometin
      Hitachi 40HYC42
      by dragometin
      TV Model: Hitachi 40HYC42
      Power Supply: 17IPS71
      MainBoard: 17MB95M
      Panel: VES400UNDS-2D-NO3
      When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
      I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
      Is there any variants on 17IPS71 power supply's?
      UART output pins 10 and 12 on scart connector:
      Code:
      12:24:04.595
      08-08-2024, 05:53 AM
    • boticario
      Asus TUF Gaming A17 FA707NUR code 43 error
      by boticario
      Hi again,
      The first thanks, I’ve been able to keep progressing with the tests, and as of now, I don’t think the problem is in the EC or the VBIOS.
      My Bios request topic here -> https://www.badcaps.net/forum/troubl...ur#post3828581
      After running MATS with the correct version for AD107, the test completes, detects the GPU correctly, and the memory bus responds, but write errors appear consistently in...
      02-21-2026, 06:18 PM
