Back-UPS RS 800 Not charging
  • Agent24
    I see dead caps
    • Oct 2007
    • 4977
    • New Zealand
    Re: Back-UPS RS 800 Not charging
    Originally posted by canadaboy25
    Yes I am in the process of getting my hands on an ESR meter so that is why I was wondering if that would be a fair enough test.
    Going for the capacitance test first is more suited to non-polarized capacitors.
    ESR measurement is a better test for electrolytics most of the time. But some can fail with reduced capacitance while the ESR stays OK! Also you can get excess leakage current problems too...
    -David VanHorn
      You can use 2A 250V fuse in other from factor to test out the function first, this style of fuse can be found at Mouser or Digikey.
      • canadaboy25
        What is normal?
        • May 2013
        • 509
        I got a fuse and soldered two wires to where the fuse came from and attached the fuse to the wires with cables so I could replace it if it blew.
        There was no change in performance even with the new fuse. The fuse did not blow and you can see where the voltage is in the picture and it is slowly dropping.
        canadaboy25
        -Sometimes the light at the end of a tunnel is an on-coming train
          Great Sage ้ฝŠๅคฉๅคง่–
          • 31083
          you could have just soldered in the correct fuseholder.
          • canadaboy25
            What is normal?
            • May 2013
            • 509
            Yeah I know that but I live by a small town and I was searching to just find the correct rating. This is just for testing.
            canadaboy25
              So at what test point that you are showing the 23VDC? How about the voltage on cap #3 which has 1.1V on it.
              • canadaboy25
                What is normal?
                • May 2013
                • 509
                I have retested the voltages on the capacitors that you pointed out in this picture. All of the voltage tests were done with the replacement fuse connected while the board is on and connected to AC power. The batteries are also connected. These are the voltages I got from testing the two terminals on each capacitor with my multimeter set on DC volts.
                1 - 22 vdc
                2 - 6 vdc
                3 - 3.8 vdc
                It may also be worthwhile to add that the battery drops by 0.4 volts and starts dropping a considerably large amount faster if I disconnect the jumpers that are holding the fuse. The voltage also goes up about 0.4 volts and the speed of voltage drop also slows after I reconnect the fuse.
                canadaboy25
                  So far we do not see any 28~29V dc power source for charging the batteries yet, the highest one is the 22VDC, and we also do not get the charging voltage all the way to the fuses to charge the batteries either. This is not easy to trace out the connection.
                  • canadaboy25
                    What is normal?
                    • May 2013
                    • 509
                    Would me removing the transformer and getting clear shots of the traces help at all?
                    canadaboy25
                      I do not think so, what I need is to be able to see real closed up pictures that I can trace the connection from the two green fuses to see where it goes to. I look around at the computer recycling place and did not find any APC RS or CS 800, I found CS350, CS500 but the boards are not the same as yours. I will keep an eye for it.
                      • canadaboy25
                        What is normal?
                        • May 2013
                        • 509
                        What I need is to be able to see real close up pictures that I can trace the connection from the two green fuses to see where it goes to.
                        Well the traces go under the transformer and through the board to the other side so I will try my best to get some good pictures of the traces.
                        I looked around at the computer recycling place and did not find any APC RS or CS 800.
                        I wish I had one of those places near me.
                        canadaboy25
                        • canadaboy25
                          What is normal?
                          • May 2013
                          • 509
                          Well I fianally got the transformer removed and the main trace from the two fuses go straight to the large capacitor between the two heatsinks.
                          There are a few other small traces leading off to different places. If you need me to get pictures of those too let me know.
                          canadaboy25
                          • ThePCDoctor
                            Retired Tech.
                            • Sep 2011
                            • 59
                            Many years ago now, I was given an APC brand, 600VA, UPS with dead and leaking batteries. (2x 6vdc gel-cells).
                            APC brand is the only one I've tested that WILL accept much larger batteries, like car batteries.
                            My own replacement batteries for the above mentioned UPS.
                            In case of a short circuit inside the UPS, the UPS and batteries are protected by a 30A quick blow fuse, in-line. (as seen in the photo).
                            In the case of the 800, mentioned above, I'd just replace all questionable parts.
                            The total bill would still be less than $5.
                            If those original batteries are 6vdc each, they CAN be replaced with a single 12VDC battery. That's basically what I'm doing.
                            Good Luck!
                            The Doctor
                            Experience is truly the best teacher.
                            Backup! Backup! Backup! Ghost Rocks!
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              #34
                              looks like something i would do.oh wait id did that about 7 times here.
                              the newer apc units are junk.
                              old metal cased ones i hang on to.
                              in the o.p's case the charger got killed by a shorted battery.
                              wish i had one like it here to autopsy.probably easy fix.
                              • MarieShaw
                                • Jul 2014
                                • 3
                                • United State Of America
                                #35
                                Thanks For Solution.
                                • Kiriakos GR
                                  Banned
                                  • May 2012
                                  • 940
                                  • Greece
                                  #36
                                  All APC UPS always need fresh working batteries so the device to pass it self test (at boot up), and then it starts charging them.
                                  Simple as that.
                                  • brethin
                                    • Dec 2008
                                    • 1907
                                    Simple as that.
                                    Not all APC UPS do a self test. I have a few old APC UPS (metal cases) that will function fine with worn batteries, they will just not provide the backup time a new battery would.
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      #38
                                      all mine do.
                                      when you hit the power button it turns on the connected loads to the line then about 10 seconds later it goes to battery for a test.tells you if the batteries will hold up the load.
                                      if it fails you get an annoying beeping.
                                      • brethin
                                        • Dec 2008
                                        • 1907
                                        Originally posted by kc8adu
                                        all mine do.
                                        Then I would guess your units are not old. Like I said the old units I have don't care about the battery condition to work they just don't give much time when the unit inverts. I do have 7 newer units that do perform the self test and will not work with a degraded battery.
                                          Since it does the self test when it is first turn on, now once it is on, disconnect the batteries to simulate fail batteries or fail charging circuit to see how smart the system really is to see what kind of warning you will get.
                                          • carrzkiss
                                            Cyberpower cps1500avr not charging batteries
                                            by carrzkiss
                                            Hello, all.
                                            Cyberpower Battery Backup Unit.
                                            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                            Checking the voltage, it was down to 22v.
                                            I quickly removed everything...
                                            06-15-2024, 02:10 PM
                                          • Thomasraud
                                            Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                            by Thomasraud
                                            i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                            QUOTED
                                            -It works on charger (without battery connected-only charger)
                                            -It works on battery (without charger connected-only battery)
                                            -& it also works when plugged in battery & charger, but it's not charging the battery
                                            //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                            and..
                                            QUOTE
                                            The IC cannot maintain the input current level
                                            06-28-2022, 06:47 PM
                                          • Scoff
                                            HP Probook 470 G4 - Power and Charging Problem
                                            by Scoff
                                            Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                            Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                            07-03-2023, 09:28 AM
                                          • abrahim110
                                            [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
                                            by abrahim110
                                            ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
                                            I have an Acer Aspire 5 A517-52G-53NB laptop.
                                            The onboard (soldered) RAM was faulty, so I physically removed the chip.
                                            I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
                                            โœ… System status:
                                            • BIOS mod is done (SPD removed)
                                            • Laptop boots to Windows normally
                                            • RAM is detected and stable
                                            โŒ Problem:
                                            The battery is not charging:
                                            • Power adapter
                                            08-06-2025, 06:15 AM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
