Back-UPS RS 800 Not charging
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    #41
    Re: Back-UPS RS 800 Not charging
    just disconnected the anderson powerpole connector to the back of a connext(apc)700.
    chirping and replace battery came on.
    the battery probably could be totally worn out without tripping the warning.
    its an exide d31 agm.
      • 31300
      got a datecode stamped on them?
      you normally do.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        #43
        its modded with an external truck battery.
        if the date on the battery is what you are after its sometime mid 2013.
        no date on the ups.
        • vdubbus77
          • Dec 2015
          There are some terrific pictures in this thread that can be used to help with my situation so I will bump this old thread. I also have a blown f3 fuse, when I removed the fuse I jumped the fuse terminals and my batteries started charging. However, the resistor (r145) right next to it got so hot it melted the solder holding it in place. Any Ideas? Is the resistor No good?
          • Agent24
            I see dead caps
            • Oct 2007
            • 5095
            • New Zealand
            #45
            A resistor getting hot means it's passing too much current. Probably something downstream from that resistor is shorted - which makes sense considering the fuse blew.
            If the resistor wasn't bad already, it likely is now, if it got that hot. You should replace the resistor and you also need to find out where the short is that blew the fuse in the first place.
            -David VanHorn
            • vdubbus77
              • Dec 2015
              It seems one of the mosfets is shorted, Is there anyone that can tell me the value of the r145 resistor? Mine is a tad toasty and from the pictures I am coming up with .78 ohm which is proving difficult to source.
              • canadaboy25
                What is normal?
                • May 2013
                • 509
                So I figured I'd post an update in case anyone else happens to have the same problem. Since one person already has, it's probably likely.
                After using the UPS as a surge protector for the past 8 years and having my computer turn off after every little power flicker, I figured it was finally time to fix it.
                After a quick google search, I was able to find the schematic for this exact UPS complete with proper component designators and values. I don't know if I just previously did not look, or if the schematic has been uploaded since I worked on it last time. I will attach the schematic in case anyone else needs it.
                The 5th page of the schematic is conveniently labelled "Battery Charger Circuit". It didn't take long to trace the cause of the blown F3 fuse to a shorted MOSFET Q40. The part number of the MOSFET is 94-2358 which is some discontinued International Rectifier FET with no datasheet available. Since the schematic lists it as a 100V FET and the circuit runs through a 2A fuse, it shouldn't be too critical what replacement is used. I ended up using a 230V 25A FET that I had lying around from a salvaged plasma Y-Sus board. I'm sure this is overkill but it was handy and it had the correct footprint.
                After replacing the MOSFET and the fuse, the unit now charges my batteries just fine. I am using two large batteries from a mobility scooter and they seem to be working well.
                Hopefully this can help someone else out.
                canadaboy25
                -Sometimes the light at the end of a tunnel is an on-coming train
                • carrzkiss
                  Cyberpower cps1500avr not charging batteries
                  by carrzkiss
                  Hello, all.
                  Cyberpower Battery Backup Unit.
                  I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                  When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                  In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                  Checking the voltage, it was down to 22v.
                  I quickly removed everything...
                  06-15-2024, 02:10 PM
                • orientalsniper
                  LA-L246P Not Charging Batteries
                  by orientalsniper
                  Hello all, I've tried multiple batteries, replaced the charging IC (ISL95522AHRZ) and updated the BIOS.
                  It detects the power adapter (90W), so the DC IN jack is okay.
                  It shows "IDLE" instead of "Charging", battery health shows "Excellent" on the BIOS.
                  09-15-2025, 02:29 PM
                • coasterghost
                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                  by coasterghost
                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                  System Hardware:
                  Processor: AMD Ryzen 7 PRO 5850U
                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                  09-08-2025, 10:46 PM
                • Thomasraud
                  Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                  by Thomasraud
                  i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                  QUOTED
                  -It works on charger (without battery connected-only charger)
                  -It works on battery (without charger connected-only battery)
                  -& it also works when plugged in battery & charger, but it's not charging the battery
                  //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                  and..
                  QUOTE
                  The IC cannot maintain the input current level
                  06-28-2022, 06:47 PM
                • Scoff
                  HP Probook 470 G4 - Power and Charging Problem
                  by Scoff
                  Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                  Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                  07-03-2023, 09:28 AM
