Back-UPS RS 800 Not charging
  • canadaboy25
    replied
    Re: Back-UPS RS 800 Not charging
    So I figured I'd post an update in case anyone else happens to have the same problem. Since one person already has, it's probably likely.
    After using the UPS as a surge protector for the past 8 years and having my computer turn off after every little power flicker, I figured it was finally time to fix it.
    After a quick google search, I was able to find the schematic for this exact UPS complete with proper component designators and values. I don't know if I just previously did not look, or if the schematic has been uploaded since I worked on it last time. I will attach the schematic in case anyone else needs it.
    The 5th page of the schematic is conveniently labelled "Battery Charger Circuit". It didn't take long to trace the cause of the blown F3 fuse to a shorted MOSFET Q40. The part number of the MOSFET is 94-2358 which is some discontinued International Rectifier FET with no datasheet available. Since the schematic lists it as a 100V FET and the circuit runs through a 2A fuse, it shouldn't be too critical what replacement is used. I ended up using a 230V 25A FET that I had lying around from a salvaged plasma Y-Sus board. I'm sure this is overkill but it was handy and it had the correct footprint.
    After replacing the MOSFET and the fuse, the unit now charges my batteries just fine. I am using two large batteries from a mobility scooter and they seem to be working well.
    Hopefully this can help someone else out.
  • vdubbus77
    replied
    It seems one of the mosfets is shorted, Is there anyone that can tell me the value of the r145 resistor? Mine is a tad toasty and from the pictures I am coming up with .78 ohm which is proving difficult to source.
  • Agent24
    replied
    A resistor getting hot means it's passing too much current. Probably something downstream from that resistor is shorted - which makes sense considering the fuse blew.
    If the resistor wasn't bad already, it likely is now, if it got that hot. You should replace the resistor and you also need to find out where the short is that blew the fuse in the first place.
  • vdubbus77
    replied
    There are some terrific pictures in this thread that can be used to help with my situation so I will bump this old thread. I also have a blown f3 fuse, when I removed the fuse I jumped the fuse terminals and my batteries started charging. However, the resistor (r145) right next to it got so hot it melted the solder holding it in place. Any Ideas? Is the resistor No good?
  • kc8adu
    replied
    its modded with an external truck battery.
    if the date on the battery is what you are after its sometime mid 2013.
    no date on the ups.
    replied
    got a datecode stamped on them?
    you normally do.
  • kc8adu
    replied
    just disconnected the anderson powerpole connector to the back of a connext(apc)700.
    chirping and replace battery came on.
    the battery probably could be totally worn out without tripping the warning.
    its an exide d31 agm.
    replied
    Since it does the self test when it is first turn on, now once it is on, disconnect the batteries to simulate fail batteries or fail charging circuit to see how smart the system really is to see what kind of warning you will get.
  • brethin
    replied
    Originally posted by kc8adu
    all mine do.
    when you hit the power button it turns on the connected loads to the line then about 10 seconds later it goes to battery for a test.tells you if the batteries will hold up the load.
    if it fails you get an annoying beeping.
    Then I would guess your units are not old. Like I said the old units I have don't care about the battery condition to work they just don't give much time when the unit inverts. I do have 7 newer units that do perform the self test and will not work with a degraded battery.
  • kc8adu
    replied
    all mine do.
  • brethin
    replied
    Originally posted by Kiriakos GR
    All APC UPS always need fresh working batteries so the device to pass it self test (at boot up), and then it starts charging them.
    Simple as that.
    Not all APC UPS do a self test. I have a few old APC UPS (metal cases) that will function fine with worn batteries, they will just not provide the backup time a new battery would.
  • Kiriakos GR
    replied
    Simple as that.
  • MarieShaw
    replied
    Thanks For Solution.
  • kc8adu
    replied
    looks like something i would do.oh wait id did that about 7 times here.
    the newer apc units are junk.
    old metal cased ones i hang on to.
    in the o.p's case the charger got killed by a shorted battery.
    wish i had one like it here to autopsy.probably easy fix.
  • ThePCDoctor
    replied
    Many years ago now, I was given an APC brand, 600VA, UPS with dead and leaking batteries. (2x 6vdc gel-cells).
    APC brand is the only one I've tested that WILL accept much larger batteries, like car batteries.
    My own replacement batteries for the above mentioned UPS.
    In case of a short circuit inside the UPS, the UPS and batteries are protected by a 30A quick blow fuse, in-line. (as seen in the photo).
    In the case of the 800, mentioned above, I'd just replace all questionable parts.
    The total bill would still be less than $5.
    If those original batteries are 6vdc each, they CAN be replaced with a single 12VDC battery. That's basically what I'm doing.
    Good Luck!
    The Doctor
  • canadaboy25
    replied
    Well I fianally got the transformer removed and the main trace from the two fuses go straight to the large capacitor between the two heatsinks.
    There are a few other small traces leading off to different places. If you need me to get pictures of those too let me know.
  • canadaboy25
    replied
    Originally posted by budm
    What I need is to be able to see real close up pictures that I can trace the connection from the two green fuses to see where it goes to.
    Well the traces go under the transformer and through the board to the other side so I will try my best to get some good pictures of the traces.
    I looked around at the computer recycling place and did not find any APC RS or CS 800.
    I wish I had one of those places near me.
    replied
    I do not think so, what I need is to be able to see real closed up pictures that I can trace the connection from the two green fuses to see where it goes to. I look around at the computer recycling place and did not find any APC RS or CS 800, I found CS350, CS500 but the boards are not the same as yours. I will keep an eye for it.
  • canadaboy25
    replied
    Would me removing the transformer and getting clear shots of the traces help at all?
    replied
    So far we do not see any 28~29V dc power source for charging the batteries yet, the highest one is the 22VDC, and we also do not get the charging voltage all the way to the fuses to charge the batteries either. This is not easy to trace out the connection.
  • carrzkiss
    Cyberpower cps1500avr not charging batteries
    by carrzkiss
    Hello, all.
    Cyberpower Battery Backup Unit.
    I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
    When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
    In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
    Checking the voltage, it was down to 22v.
    I quickly removed everything...
    06-15-2024, 02:10 PM
  • Thomasraud
    Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
    by Thomasraud
    i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
    QUOTED
    -It works on charger (without battery connected-only charger)
    -It works on battery (without charger connected-only battery)
    -& it also works when plugged in battery & charger, but it's not charging the battery
    //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
    and..
    QUOTE
    The IC cannot maintain the input current level
    06-28-2022, 06:47 PM
  • Scoff
    HP Probook 470 G4 - Power and Charging Problem
    by Scoff
    Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
    Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
    07-03-2023, 09:28 AM
  • abrahim110
    [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
    by abrahim110
    ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
    I have an Acer Aspire 5 A517-52G-53NB laptop.
    The onboard (soldered) RAM was faulty, so I physically removed the chip.
    I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
    โœ… System status:
    • BIOS mod is done (SPD removed)
    • Laptop boots to Windows normally
    • RAM is detected and stable
    โŒ Problem:
    The battery is not charging:
    • Power adapter
    08-06-2025, 06:15 AM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
