What version of Firefox is everyone running?
  • mob
    • Mar 2010
    • 5
    Re: What version of Firefox is everyone running?
    None. I don't like bloatware.
    • mariushm
      • May 2011
      • 3799
      I have Firefox 8 but I don't know what the big deal is about because the layout on screen remains the same with each version.
      Some time ago I made a backup of the profile before I reinstalled the operating system, started the new version of Firefox with ugly layout, closed it and I copied the backup over the profile generated by the new version.
      When I restarted the new version, it just read the screen layout from the old profile and now I have everything showing as the old versions.
      The only thing I was missing was the status bar, and I installed Status-4-Evar or whatever it's called and it got fixed.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Originally posted by yyonline
        You can make Firefox 8 look pretty much like 3.6 with less than 5 minutes of tweaking.
        First, right click an empty spot on the tab bar, and check the option for Menu Bar, and uncheck the option for Tabs on Top. (Image 1)
        Second, right click an empty spot on the tab bar again, and choose Customize this time. Drag the stop, reload, and home buttons from the right side of the toolbar to the appropriate locations. (Image 2)
        Third, type about:config in the URL bar. Agree to the warning. Search for the preference browser.urlbar.trimURLs and change it to False.
        Finally, download the extension Status-4-Evar from https://addons.mozilla.org/en-US/fir...status-4-evar/. This adds the status bar back to Firefox.
        Now Firefox 8 looks mostly like 3.6. The buttons are styled a bit differently, but all the functional bits are now in the familiar spots. (Image 3)
        You can add a preference in about:config called extensions.checkCompatibility.8.0 and set it to False to enable the loading of extensions that aren't tested with Firefox 8. I have a few extensions I use regularly that haven't been updated in a long time. For the most part, they all work fine with the newer Firefox versions.
        Way ahead of you. I had the button layout almost identical to 3.6. The fubar'd status bar was the reason for the upgrade back to 3.6, just couldn't get used to their icky new one. Ridiculous you have to install add-on's to bring back something that should have never been removed.... I may try it again later on...
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • ThePCDoctor
          Retired Tech.
          • Sep 2011
          • 59
          Ah yes the bastardized menu bar. Why scatter the icons all across the screen? It was so much easier to find things in the old 3.6.? versions.
          Still running 3.6.?? seems so Old School, that I decided to finally upgrade and see if I could make the REAL 8.0 release work for me. (no betas here)
          Well, I opened up the "Customize" window and drug all the icons from the menu bar down into the window, then I took them one by one and did a drag n drop back up to the left side of the menu bar, so they are all there together. It makes grabbing an icon much easier when they are all in one place.
          Other than that, all my PC's are running FF 8.0 very nicely. Any PC that can't run FF 8.0 has got to be a real dog! Eh? Maybe still running Win-98?
          I see FF 9.0 is out, in Beta. But Beta versions are for evaluation purposes only and not for Prime Time use. So I won't even bother with them.
          It's bad enough that I'm running Windows 8 DP, on a test PC.
          Since I'm not expecting too much from it, I'm not P'd off when I try something and it crashes on me.
          Experience is truly the best teacher.
          Backup! Backup! Backup! Ghost Rocks!
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Ha I run Windows 8 Developer Preview too
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Most are 3.6.x
              I think one is still 3.0.11.
              I keep IE6 functional but it only gets used for problem web pages coded by IE happy coders.
              I actually liked Opera back in the 90's but haven't used it since then.
              I tried one of the newer versions a while ago and it didn't do it for me.
              Mann-Made Global Warming.
              - Dr Seuss
              • ThePCDoctor
                Retired Tech.
                • Sep 2011
                • 59
                Shovenose,
                Are you running 8DP al' natural, or have you turned off the Metro UI?
                As a tech, one of these days, some of my customers will start buying new PC's with Win-8 on them and asking "what the heck is this?" when they see the Metro UI.
                I'm already starting my own "Windows 8 Stuff" folder on my Utilities disk.
                The registry script to shut off the Metro UI was the first entry.
                There is also a batch file to do that, but it caused some problems with the classic desktop.
                I'm finding that all my tweaks for Win-7 also work for Win-8.
                Like, Disable UAC, Take Ownership, Disable Hibernate, Show Hidden Files, etc.
                And even most of the performance tweaks I've been using since XP still work.
                Like, my Quick Shutdown shortcut, and the "Extended Disk Cleanup".
                Upgrading from Win-7 to Win-8 won't be bad at all. Nothing like the upgrade from XP to Vista.
                Happy Holidays Everyone!
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  I am also running Firefox 3.6.24 on all my computers. It just works the best for me and I don't really want to upgrade it...
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Shovenose,
                    I have Metro enabled - since it's the most interesting reason to run Windows 8
                    • Evil Lurker
                      Warranty Voider
                      • Feb 2011
                      • 454
                      #30
                      Im running FF8... dont know why it got updated but I cant use the bork bork bork plugin anymore.
                      Couple FF with adblock plus plugin = browsing bliss! Hell it even allows you to skip advertising in streaming video!
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        Whoa, how do you skip those?
                        • Sparky
                          High voltage
                          • Jan 2007
                          • 234
                          Running 8. Nothing wrong with it IMO. The different interface that started in 4 took a little getting used to, but I moved a couple things around the toolbar and am happy now.
                          They changed the interface a bit from 1 > 2, and from 2 > 3, so changing again when going to 4 didn't surprise or bother me that much.
                          Oh, and adblock is amazing. I didn't even know that ads had started appearing in Youtube videos because apparently adblock stops them from showing. Sweet
                          I purposely don't block most of the ads on forums and such that I frequent a lot.
                          • lti
                            • May 2011
                            • 2557
                            AdBlock Plus just prevents the ad server from being accessed. Some videos will not play if the ad server is down or being blocked and others will just skip the ad and start playing the video.
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              That's what I thought. But I occasionally (rarely) get a YouTube or Pandora ad. Maybe those use ad servers that hadn't been listed...
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Firefox 8 here. I hate not having a menu bar in Chrome, and IE is too slow.
                                • Mad_Professor
                                  A Mech Warrior
                                  • Feb 2011
                                  • 1587
                                  #36
                                  I never upgraded my version even tho Mozilla occasionally threatens me about end-of-life and that I should upgrade. Frankly I'm happy with 3.6.24.
                                  The fact they are on "9" with no improvements over the last version, that had no improvements over it's predecessor either, kind of points out that the original developing team is no more. I don't think Firefox can taunt that it's more secure then Internet Explorer if they are milling out a release every three months with bugs and possible vulnerabilities.
                                  I had the pleasure to use ver. 4, 6, and 8 and I didn't like any of them, or how it looks.
                                  3.6 is clean, fast and simple with no bullshit.
                                  • stretch0069
                                    Screwed Up Super Moderator
                                    • Oct 2003
                                    • 2658
                                    • oooo ess aaaaaaaaa
                                    #37
                                    8 on all.
                                    "Its all about the boom....."
                                    Guns kill people like spoons made Rosie O'Donnell fat.
                                    We now return you to your regularly scheduled drinking.
                                    "Fear accompanies the possibility of death.....calm shepherds its certainty"
                                    Originally posted by Topcat
                                    AWD is just training wheels for RWD.
                                    • severach
                                      • Aug 2007
                                      • 1055
                                      FF is changing major versions too often which breaks addons. I got FF 6.01 all fixed up and I erased both app.update.certs.*.commonName so it claims to be up to date and won't bug me about updates.
                                      sig files are for morons
                                      • Ami Sapphire
                                        Extreme Lurker
                                        • Sep 2010
                                        • 180
                                        All I did was install Add-on Compatibility Reporter when I was on Firefox 5. That way, addons are already enabled, despite the incompatible message on an addon being present.
                                        Still using the old Screengrab addon!
                                        Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
                                        I have two v2s and one v1.
                                        I am still looking at these boards nearly every day.
                                        What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
                                          master hoarder
                                          • May 2008
                                          • 12175
                                          • Bulgaria
                                          #40
                                          Actually, not all of my computers use 3.6.23.... my download computer has 3.0.19. I'm starting to like that version even better than 3.6. Right now, I have 25 tabs open (all of which are Badcaps.net threads) and my RAM usage is less than 280 MB - that's even more efficient than IE6 on my other computer! If I'm installing FF again on any of my computers, I think I'll stick to this version instead. The only problem it has is there is no new tab button, but that's okay.
                                          • sikocan
                                            Lenovo X1 Carbon 9th Gen Black Screen
                                            by sikocan
                                            I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                                            SN: PF3G1REP
                                            MODEL: 20KW-00J1AU
                                            PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                                            Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                                            06-24-2025, 09:01 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • TJ65
                                            Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
                                            by TJ65
                                            i made out of two broken Samsung Galaxy Tabpro S one that works partially.
                                            The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
                                            I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
                                            The problem is, that the micom Version doesn't match with the bios version, see picture.
                                            How can i update the Micom Version? The Samsung bios update wont work.
                                            With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
                                            01-09-2025, 01:35 PM
                                          • Hondaman
                                            Firefox is now SATANIC
                                            by Hondaman
                                            Now that I have your attention:
                                            In the last few days, it looks like Firefox has changed their software terms so they are now evil and WILL sell your data.
                                            I already use Palemoon for Win7 sometimes. Looks like I'll be switching to librewolf as well, as Youtuber Louis Rossman suggests. Palemoon still supports Win7, but sometimes pages don't work properly. The Google Chrome browser might also still work for Win7.
                                            I will have no choice but to upgrade my Firefox, so that I can copy dozens of tabs into a document or spreadsheet, or go through the history to...
                                            03-05-2025, 04:41 PM
                                          • TheUser
                                            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                            by TheUser
                                            Hello to everyone ,
                                            This is my first post here, and i would like to share with you a small story in case you can help me.
                                            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                            02-10-2024, 02:07 PM
