Lenovo X1 Carbon 9th Gen Black Screen
  • sikocan
    • Oct 2019
    • 346
    I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
    SN: PF3G1REP
    MODEL: 20KW-00J1AU
    PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
    Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
    ║ ME Analyzer v1.304.5 r343 ║
    ║ 20250625_113434_SVOD4-2-bottom one.bin (1/1) ║
    ║ Family │ CSE ME ║
    ║ Version │ 15.0.50.2633 ║
    ║ Release │ Production ║
    ║ Type │ Extracted ║
    ║ SKU │ Consumer LP ║
    ║ Chipset │ TGP-LP B ║
    ║ TCB Security Version Number │ 1 ║
    ║ ARB Security Version Number │ 6 ║
    ║ Version Control Number │ 42 ║
    ║ Production Ready │ Yes ║
    ║ OEM Configuration │ Yes ║
    ║ FWUpdate Support │ No ║
    ║ Date │ 2024-06-20 ║
    ║ File System State │ Error ║
    ║ Size │ 0xA9000 ║
    ║ Flash Image Tool │ 15.0.23.1706 ║
    ║ Power Management Controller ║
    ║ Family │ PMC ║
    ║ Version │ 150.1.20.1042 ║
    ║ Type │ Independent ║
    ║ Chipset SKU │ LP ║
    ║ Chipset Stepping │ C ║
    ║ TCB Security Version Number │ 0 ║
    ║ ARB Security Version Number │ 0 ║
    ║ Version Control Number │ 0 ║
    ║ Date │ 2022-11-04 ║
    ║ Size │ 0x40000 ║
    ║ Manifest Extension Utility │ 15.0.0.1282 ║
    ║ Chipset Support │ TGP ║
    ║ Family │ PMC ║
    ║ Size │ 0x40000 ║
    ║ Platform Controller Hub Configuration ║
    ║ Family │ PCHC ║
    ║ Version │ 15.0.0.1021 ║
    ║ Date │ 2021-04-28 ║
    ║ Size │ 0x1000 ║
    ║ Manifest Extension Utility │ 15.0.30.1716 ║
    ║ Family │ PCHC ║
    ║ Size │ 0x1000 ║
    ║ USB Type C Physical ║
    ║ Family │ PHY ║
    ║ Version │ 11.225.276.2043 ║
    ║ SKU │ N ║
    ║ Date │ 2022-03-29 ║
    ║ Size │ 0x10000 ║
    ║ Manifest Extension Utility │ 15.0.0.1224 ║
    ║ Family │ PHY ║
    ║ SKU │ N ║
    ║ Size │ 0x10000 ║
    Error: Skipped MFS partition at 0x1FFFF0, unrecognizable format!
    Error: Skipped EFS partition at 0x266FF0, unrecognizable format!
    Warning: Could not find any File System Platform, assuming 0x01 (ICP)!
    Warning: Could not find any File System Dictionary, assuming 0x0A!
    Note: This PMC TGP firmware is not in the database! You can help this
    project by sharing it at https://win-raid.com forum. Thank you!
    Note: This CSE ME firmware is not in the database! You can help this
    Note: Multiple (2) Intel Flash Partition Tables detected!
    Intel FIT Tool output:
    FIT version used to build the image: 15.0.21.1549
    Writing map file C:\Users\HP\Downloads\csme-15\CSME System Tools v15.0 r15\Flash Image Tool\WIN32\X1 Carbon 9th Gen Laptop (ThinkPad) - Type 20XX\X1 Carbon 9th Gen Laptop (ThinkPad) - Type 20XX.map
    Loading C:\Users\HP\Downloads\X1 Carbon 9th Gen Laptop (ThinkPad) - Type 20XX\20250625_113434_SVOD4-2-bottom one.bin (Chip 2)
    Error 237: Failed to load input file. Invalid input file type.
    Error 42: Failed to open with processed commands.
    Unable to open file: C:\Users\HP\Downloads\X1 Carbon 9th Gen Laptop (ThinkPad) - Type 20XX\20250625_113434_SVOD4-2-bottom one.bin. Reverting to default configuration.
    THANK YOU!
    • 22012
    It`s a 20XW not K . Your bios is too corrupt to repair, just use another one with clean ME firmware
    https://www.badcaps.net/forum/troubl...77#post3300577
    ,the 20XW, 20XX share the same bios
    https://pcsupport.lenovo.com/gb/en/p...earch=PF3G1REP
    • sikocan
      • Oct 2019
      • 346
      Thank you, I'll try.
      • sikocan
        • Oct 2019
        • 346
        Hmm... still not good. Touch cookies.
          • 22012
          Try another bios chip.
          • sikocan
            • Oct 2019
            • 346
            Thanks for your reply - I tried a new chip today, but I'm still encountering the same issue.
            What's interesting is that before I started working on the chips, the computer would turn on and display a black screen with the keyboard lights functioning, but there was no backlight, screen display, or external screen output - essentially like a zombie state. After working with the chips and restoring the original firmware, it won't boot at all anymore.
            I've spent considerable time checking the continuity of every pin back to their destinations, and they're all properly connected. Even with the original firmware restored, it won't power on.
            Component Details:
            • U49: Contains the Windows Product key and other related features
            • U89: Contains the Type-C Power delivery and other features. If this chip is not in properly or firmware is not correct, it won't reach 23V. (It's not the MOSFETs issues)
            I've tried the new chip on both locations after programming, but these chips were extremely difficult to remove due to the adhesive material used. I've manually scanned the entire board under a microscope on both sides and found nothing unusual, even used powerful torch to look up closely, nothing is odd.
            Current Status:
            • Power button signal is functioning properly
            • Orange light activates
            • 23V is present with 0.04 amps powering the LED
            • ThinkEngine IC is running at approximately 20 degrees, indicating it's active
            Despite all this, it still won't turn on. I suspect the issue might still be firmware-related, but I'm honestly at a loss after over five hours of troubleshooting.
              • 22012
              Chip1 is the recovery bios , chip2 the main bios. chip2 has the windows key,the DMI will be in the EC chip.
              • Maxpower3
                Brand name and Model Type for Lenovo error 2202 product name is invalid
                by Maxpower3
                Info for error 2202 LenovoThinkPad models and type
                Extract from ThinkPad Maintenance Utilities Configuration File
                plnsrv.ini Version 1.01
                Some information that may be useful
                There must also be missing models, add them to the list if you know of any.
                Code:
                brand name
                20B1=ThinkPad Edge E445
                20B2=ThinkPad Edge E545
                20BC=ThinkPad Edge E145
                20BM=ThinkPad X140e
                20BL=ThinkPad X140e
                20A3=ThinkPad X230s
                20AH=ThinkPad X230s
                20AK=ThinkPad X240s
                20AJ=ThinkPad X240s
                02-21-2024, 10:27 AM
                by Vesko356
                08-11-2023, 03:27 AM
                Lenovo ThinkPad X1 Carbon Notebook X Specification for Upgrade or Repair
                This specification for the Lenovo ThinkPad X1 Carbon Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon boardview and X1 Carbon schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                09-06-2024, 08:20 AM
                09-06-2024, 08:10 AM
                09-06-2024, 07:50 AM
