ugh.......dirty
Re: ugh.......dirty
Yecch. I saw a 1995 Packard Bell that was about as bad as that. What sort of machine is it?Comment
Re: ugh.......dirty
nope i think its car exhaust. it was in a room next to the main road on the 3rd floor. kinda makes you think about what you are breathing. i see only machines in the city with this black dust.
I don't mean to one-up you, but I've cleaned far worse than that.
mice living in the dlt changer.wasps in the top of the case.
junk sticking out of non running fans.ok i think i will remain in the city, thanks
dunno what to do with it yet though. the scsi disks have been whining for a long time so i wont use them. i was running it out of production until they died but got bored waiting, quantum scsi are definitely better than the ide. it was installed in 1999 so it is older than i thought. i will definitely clean it. It would be nice to serve archive data using pci sata. a gig of ram and some new procs would be nice...........sad to shut it down, i will miss novell.
replaced by HP DL380 G4, 3.4ghz xeon, 1gb, 3x72gb u160 hardware raid-5 + hot spare, redundant psu, redundant fan kit. RHEL 4Last edited by willawake; 03-24-2006, 04:41 PM.Comment
Re: ugh.......dirty
All parts cleaned and ready for assembly
doh! there is only one 8.2 vrm so no dual possible unless we find one.
hdd caddys. if you buy an HP server secondhand, make sure it has enough of these and not just blanking plates.
acbel psu API-6127 350w
psu interior
all panels onComment
Last edited by Per Hansson; 05-11-2014, 08:42 AM. Reason: Offsite images uploaded due to problems with host"The one who says it cannot be done should never interrupt the one who is doing it."Comment
Re: ugh.......dirty
looks interesting, i dont know if it would be compatible though. what do the other stickers say.
situation with the server at the moment is the psu is playing up. i had problems to start before one time when i had to down it a while ago. now it was starting then restarting repeatedly with no cdrom/hdds attached.
eventually started properly so i shut it down again and i reattached them and got it up. the hdds sound like shit now. i am not suprised, when you take elderly servers out of service for a while and then start them again big problems start.
anyway the hdds are for the trash i know anyway. what about the psu though? the caps are chemicon and look ok. any ideas? i will take it apart and check it with the esr meter to see whats up. but anything else i should check except for the caps? need to refurb psu otherwise it is all no use,Last edited by willawake; 03-24-2006, 01:45 PM.Comment
Re: ugh.......dirty
Odd, And I looked at that PSU and thought, ahh, old nice servers always use good powersupplies, oh well
Regarding the VRM, I was only teasing you, I need it myself
A friend to me shutdown a Netware 3.11 server at a place, it had 6 years uptime, the HDD's never spun again after that... Of Course he was wise enough to actually make a backup before "down":ing it, because he was kind of expecting it with that kind of uptime"The one who says it cannot be done should never interrupt the one who is doing it."Comment
Re: ugh.......dirty
it looks like a good psu, just needs some work. dont worry about the vrm, ebay is calling. actually i need ram more than cpus.
lol, your friend made a good call. ctrl+alt+esc and your life flashes before you along with various other text lol. i guess if my server had been running anything else it would have not looked like that. look what the designers have to take into account, the overclock boys who nuke it quickly or the server boys who give it a slow death. (actually it might be the accountants who do that)Last edited by willawake; 03-24-2006, 04:43 PM.Comment
Re: ugh.......dirty
Originally posted by Per HanssonOdd, And I looked at that PSU and thought, ahh, old nice servers always use good powersupplies, oh well
A friend to me shutdown a Netware 3.11 server at a place, it had 6 years uptime, the HDD's never spun again after that... Of Course he was wise enough to actually make a backup before "down":ing it, because he was kind of expecting it with that kind of uptimeASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Re: ugh.......dirty
Yup - the AcBel PSU is not as good as the earlier (?) Delta OEM units that HP was using. It should be fine after a recap, though. Give a shot of TV tuner cleaner or switch cleaner to all the power connectors, as well.
I'm not sure about this particular system, but if it's a i440BX chipset, it may be capable of supporting Cumines in slotkets with a VRM upgrade to 8.4 and a BIOS upgrade (for Cumine microcodes). I was able to do that to a HP Kayak XU that originally had a Deschutes PII/350. Another option (even more iffy) is a Tualatin-conversion Slotket.Comment
Re: ugh.......dirty
yeah it must be a bx, i see a fw82443bx
good call.Comment
Re: ugh.......dirty
I just noticed you replaced the PSU fan backwards. The label side should be facing away form the components.Comment
Re: ugh.......dirty
Originally posted by Chris1992I just noticed you replaced the PSU fan backwards. The label side should be facing away form the components.
Notice the location of the PSU - at the very bottom of the case. It is therefore logical, coolingwise, that this should be an air intake, not an exhaust.Comment
Re: ugh.......dirty
both fans are backwards. i fixed them after uploading the pix. original for the psu was for exhaust so i continue original designComment
Re: ugh.......dirty
like me when i fix somebody else's prebuilt. When I fix my own, I do lots of little cooling and silencing tweaks.Comment
Re: ugh.......dirty
i am new to this forum anyway once i opened my pc to install some more ram i saw everything extremly dusty and somehow a noodle packet inside and i dont remember putting it there when i changed the heatsink but a noodle packet! something you dont see every day now how the hell could THAT have gotten in?!Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by flibidyI have here a Magnum IA.100 which belongs to my parents.
The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
What Ive done........8 Photos-
01-01-2025, 01:26 PM -
by ZixuTechI am dealing with this LA-G341P, which had heavy liquid damage around the Audio board, Battery charging circuit. I went and cleaned liquid areas and left the audio board disconnected.
It had blown PQ1900/02/3 as well as a trace on PU1900. I replaced all 4, and now it turns on and switches off. With a connected battery, it turns on and stays on for a while, even loading the system, then cuts off suddenly.
Charger only - without a battery, the PQ201/PD200 area gets hot. I can see the chipset and CPU also warm up for a second trying to pull up to 2A, then cust off.... -
by SMDFleaCopying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....-
Channel: BIOS Requests ONLY!
- Loading...
