![Click image for larger version
Name: Seasonic B12 BC-550 [A551bcafh] (1).jpg
Name: Seasonic B12 BC-550 [A551bcafh] (3).jpg
Name: Seasonic B12 BC-550 [A551bcafh] (2).jpg
https://www.badcaps.net/filedata/fetch?id=3591773
All in all, it seems like a decent Seasonic unit. Of course, if I'm making a post about it, you can bet there has to be something that isn't quite right with it… something that I was able to spot through the vents at the time of sale.
(Some of you can probably tell where this is going.) But for $5 after almost no bargaining, I couldn't pass it up. So let's open it and see what was wrong.
Name: Seasonic B12 BC-550 [A551bcafh] (4).jpg
https://www.badcaps.net/filedata/fetch?id=3591774
Name: Seasonic B12 BC-550 [A551bcafh] (5).jpg
https://www.badcaps.net/filedata/fetch?id=3591775
Name: Seasonic B12 BC-550 [A551bcafh] (6).jpg
https://www.badcaps.net/filedata/fetch?id=3591776
Well, there you have it - bad caps in a supposedly good brand PSU… and in 2024 no less! One might think that good manufacturers like Seasonic would have learned their lesson by now. But I guess nothing's given.
The bad caps are all from Asia'X (i.e. Fuhjyjin Electronic Co.). And looking at the middle picture above, these caps have date codes of “2209” and similar. I don't know if the last two numbers represent the production month or production week – one would specify the later half of 2022 and the other somewhere in early 2022. Regardless, the fact that the caps were made in 2022 and have already gone bad is a BIG SHAME! That's barely over the 2 year mark… and I'm not sure if they even made it that far, because I got the PSU a few months (around late October 2024) with the caps bulging as seen above. So they could have gone bad before then.
Here's the rest of the pictures of the PSU:
Name: Seasonic B12 BC-550 [A551bcafh] (8).jpg
https://www.badcaps.net/filedata/fetch?id=3591777
Name: Seasonic B12 BC-550 [A551bcafh] (9).jpg
https://www.badcaps.net/filedata/fetch?id=3591778
Name: Seasonic B12 BC-550 [A551bcafh] (10).jpg
https://www.badcaps.net/filedata/fetch?id=3591779
Name: Seasonic B12 BC-550 [A551bcafh] (7).jpg
https://www.badcaps.net/filedata/fetch?id=3591780
Also, if anyone has this unit and damaged SMD parts (either due to physical damage or something gone wrong with the PSU), let me know – I have some high-resolution pictures that appear to capture a good deal of them. I can upload them upon request (saving the forum some server space, if these are not necessary.)
Now back to discussing the PSU… the electrolytic caps aside, this appears to be a pretty good build.
It's a modern half-bridge LLC resonant topology (note the lack of an output toroid) with synchronous rectification on the output (a single 12V rail). Filtering is provided by a bunch of 16V 470 uF polymer capacitors (not sure of the brand or series) followed by a few (bulged
) 16V 2200 uF electrolytic capacitors. The 3.3V and 5V rails use DC-DC buck-converter circuits (the two small daughterboards.) Jumping back to the primary side… there's two MOSFETs for the LLC resonator, along with two MOSFETs and a diode for the APFC. There is also a relay to bypass the NTC thermistor once the unit is ON for further efficiency improvement (and I personally don't like to see the NTC thermistor as the sole link between the output of the APFC and the primary side electrolytic filter cap, since a blown/open thermistor there can cause the APFC MOSFETs to go *POW*
.) Next, the EMI/RFI filtering – it's all complete, of course, as would be expected from a competent manufacturer like Seasonic.
For the Google/search engine bots, PCB has the following info written on it:
YL ATX0500GQ(TC) Rev1.6
2021/08/02
Now if you are wondering, why did I open this PSU and not send it for a warranty repair… that's because I got my screw driver out and opened the PSU before I even thought about checking the model number online for anything like that. As it turns out, this PSU has a 5-year warranty on it. Even the serial number shows it. So I guess we can say I screwed myself out of that.
No regrets, though.
Sending the PSU in for warranty from where I am right now (Eastern Europe) might cost more than what the PSU is worth new. And for what, to send me a new/refurbished PSU likely with the same crappy caps inside? I highly doubt Seasonic has any repair centers where someone will bother to sit down and repair the actual problem. More likely, they just have warranty depots to send new units out. If that's likely to be the case, I would rather fix the problem myself. Actually, I'm glad I did as I have some interesting findings to show. But I'll detail those in the next post below. This one will just end it with summary of the parts inside.
ICs:
CM6502UHHX (APFC), CM6901X (LLC PWM ctrl.), Welltrend WT7527V (supervisor), [STR-]A6069h (5VSB PWM-FET IC), two APW7073 (buck PWM ctrl., 1x for each DC-DC daughterboard)
Wiring:
Input side: 600V, 18 AWG
Output side: 300V, 18 AWG
Output connectors: 20+4pin ATX, 4+4-pin 12V CPU, 2x 6+2-pin PCI-E, 4x SATA, 3x Molex
Transformers:
35 mm wide main; 19 mm wide 5VSB
Primary Side:
* three 0.22 uF X2 caps, three 332M Y2 caps, two 102 Y2 caps, three CM chokes, one 14d511k MOV between L-N
* MF72 10d15 NTC + 10A125V relay
* 0.5 uF 500VDC metal film cap (APFC input), 2x 683J 1000V film caps (LLC resonator)
* APFC section: 2x ST16N50AF MOSFETs + 1x LTTH806SDFW diode, all in TO-220FP cases; T106-45 inductor core (toroid)
* LLC/main PS switching: 2x ST16N50AF MOSFETs
* Ltec HP, 420V, 390 uF, 25x46 mm, 105°C
* C61: Asia'X TMX, 35V, 220 uF, 8x16 mm (primary aux. supply filter)
* C66: Asia'X TNX, 50V, 47 uF, 6.3x11 mm (5VSB startup cap)
Secondary Side:
* 5VSB
*** 1x Asia'X TMX, 16V, 2200 uF, 10x20 mm before PI coil
*** 1x Asia'X TMX, 16V, 1000 uF, 8x18 mm after PI coil
*** PI coil: 1R5 (7-turns, 24-AWG, 2.5-3 mm core)
*** 45R20s SMD rectifying diode
* 12V Rail
*** 4x polymers, 16V, 470 uF, 10x11 mm before PI coil
*** 2x Asia'X TMX, 16V, 2200 uF, 10x20 mm after PI coil
*** 2x free 10 mm dia. Spots
*** 4x total, 2x on each DC-DC daughterboard: polymers, 16V, 330 uF, 5x11 mm
*** PI coil(s): 2x 3-turn, 16 AWG, 5 mm rod core
*** 2x(?) 044R5NT MOSFETs for sync. rectification
* -12V Rail
*** 1x ChengX GR, 25V, 1000 uF, 10x20 mm before 7912 linear regulator
*** 1x Asia'X TMX, 16V, 2200 uF, 10x20 mm after 7912 linear regulator
*** SS26 SMD rectifying diode
* 3.3V Rail
*** 2x polymers, 16V, 330 uF, 5x11 mm (on output of DC-DC daughterboard)
*** 1x polymer, 16V, 330 uF, 5x11 mm, close to wires
*** PI coil provisioned but not installed
*** 3N5R0 + 3NA3R4 MOSFETs for DC-DC buck circuit
* 5V Rail
Same exact configuration as 3.3V rail above
* other electrolytic caps:
*** C72: Asia'X TMX, 35V, 220 uF, 8x16 mm (secondary aux. supply)
*** C60: Asia'X TMX, 16V, 220 uF, 6.3x11 mm (fan filter)
2021/08/02
ICs:
Wiring:
Transformers:
Primary Side:
Secondary Side:
* 5VSB
* 12V Rail
* -12V Rail
* 3.3V Rail
* 5V Rail
