Half rule broken
  • Fir3Chi3f
    • Mar 2011
    • 32
    Half rule broken
    Howdy everyone!
    I've read that when replacing lytics with polys the fraud value should be about halved. https://www.badcaps.net/forum/showthread.php?t=8679
    But I recently fixed a monitor before reading such, http://www.overclock.net/monitors-di...l#post12759917. So, what can I expect in the long run? The monitor seems to work fine.
    Cheers
    Fun needs a full tank of gas
  • yyonline
    • Jul 2009
    • 692
    Re: Half rule broken
    Well...the capacitors you replaced are on a power supply board. Generally, you want to stick close to the original specs there are far as ESR and ripple. Polymer capacitors have much lower ESR compared to electrolytic capacitors. Those who understand electronic theory better than I do say that changing ESR too drastically can throw things out of tune. The ideal replacement would have been an electrolytic capacitor with similar specs from a more reliable manufacturer.
    Reducing capacitance when decreasing ESR only applies to certain areas of a PC motherboard. On a power supply, keeping the capacitance the same was the right call.
    I wouldn't worry too much about the reliability of the ones you just replaced. What I might worry about - I see that there are other Capxon on the board you did not replace, as well as what look like Taicon. These brands are unreliable, and I would have replaced all of them while the monitor was apart.
    All things considered, good job with the repair
    • Fir3Chi3f
      • Mar 2011
      • 32
      Thanks yyonline, I have a couple of motherboards and another monitor to fix and I wanted to make sure I understood these things to some extent before continuing.
      Mind if I quote you for the tutorial on overclock.net? (I might redo the whole thing with the other broke monitor now knowing a bit more) I don't make a tutorial here because most here seem to understand these things a bit more than those at overclock
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        The thing about very different ESR is that it can change the power supply's transfer function a lot, enough for the control loop to start oscillating and not maintain proper voltage regulation anymore.
        However, if the caps are low enough ESR and high enough capacitance (they always are high enough capacitance, with standard aluminum electros you have to use a lot more capacitance than needed just to get the required ESR), it may not matter if the control loop is oscillating. A monitor is a device that consumes a steady amount of power. When there are no transients, the control loop will behave even if it's not compensated properly. Regardless, if it were an issue you would have seen the effect by now.
        A working TV? How boring!
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Nice work, Fir3Chi3f! I like the pictures with the stick figure in your thread - very cool .
          Like yyonline suggested, though, you should replace the rest of the CapXons as well, along with the Taicon caps.
          Besides the capacitor brand name, capacitors also have a series marking (usually a 2 or 3 letter code). Different series have different characteristics (such as ESR/impedance and Ripple Current). For example, you can have two 220uF 25v caps, but one may have a different ESR and Ripple Current rating from the other cap. The brand of the capacitor, along with the series will allow you to chose proper replacements. Capacitors datasheets can usually be found online (if not, ask here ).
          Ideally, you want your replacement caps to have the same or higher Ripple Current rating and same or lower ESR/impedance.
          In your case, you have CapXon. The most commonly used CapXon series in monitors are usually KF and GL (and sometimes KM). Yours are black, so I would guess either KF or KM series. Based on the datasheets:
          - If KF series, replace with any of the following:
          Rubycon ZL, Nichicon HD, United Chemicon KZE, Panasonic FM and FR.
          These will also likely work, even though they are not up to spec with CapXon KF:
          Nichicon HE, United Chemicon KY
          - For KM, replace with any of the following:
          idealy: Rubycon YXB, Nichicon PW and PM, United Chemicon LXY and LXZ, Panasonic FC
          also fine: Rubycon YXG, Nichicon HE, United Chemicon KY, Panasonic FR, Sanyo WX
          As for the solid caps you used - they have much better specs than the CapXons. If you did this on a regular computer power supply, this might have been a problem, like Th3_uN1Qu3 described. Monitor power supplies, however, don't seem to mind that much. Part of this is due to the lack of large inductors and steady power draw. With that said, you can leave the solid polymers you originally installed. In fact, I think it's good to have them there since they can take heat abuse much better - and most of these monitor power supplies do get quite hot.
          By the way, one more thing - the capacitance is not measured in fraud but in Farads (F) (on those CapXons, though, it may as well say FRAUD ). The μ in front means micro, or 10^-6.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            When it was first created [HERE BTW] the "1/2 Rule" was improperly applied by many and bad info got spread all over the web.
            It is based on what is said in a tech document for a VRM controller chip and outside of a VRM it does not apply.
            If you are not working on a VRM there is nothing at all that actually says it's okay to reduce uF.
            Mann-Made Global Warming.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Originally posted by momaka
              By the way, one more thing - the capacitance is not measured in fraud ....
              Except when you buy them on eBay.
              - Dr Seuss
              • Toasty
                • Jul 2007
                • 4171
                +2
                veritas odium parit
                • Fir3Chi3f
                  • Mar 2011
                  • 32
                  Ahh! Info-gasm! I'll need some time to pick through this, but I'm sure I'll have more questions in a bit. Thanks everyone!
                  Well aren't my cheeks red, typos and spell checker are a funny mix
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    But the shipping is soooo fast! Don't you ever read the feedback?
                    Hey, at least you used spell check .
                    • Fir3Chi3f
                      • Mar 2011
                      • 32
                      I was looking at the new broken monitor (because it's already open) and all the caps are CapXon GL. I was doing some googleing and couldn't find much on "CapXon GL" except for other blown cap tutorials/situations. http://pavel.kirkovsky.com/2009/03/s...r-204b-repair/ <- This guy miss-matches caps because he couldn't get the 820uf 25v.
                      So I don't have to keep coming here to ask what caps I need, Where can I find these data sheets?
                      Based off of voltage, farads and this chart I need Rubycon ZLK. Is this correct? I will be replacing all the caps this time.
                      I'll need to reopen the monitor to see what they are, thanks momaka! I actually gave that monitor to my little brother; I'll need to wait until he isn't using it.
                      And thanks everyone!
                      ps - this new broken monitor is a 22" Samsung 226BW and it will be going to my little sis when it is finished. She is using a 15" tube screen now.
                      edit: Yes, yes I did read the feedback and everyone else seemed so happy to give their money to him!
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        second link with Google search, boom!
                        I see your monitor also has the 820uF, 25v CapXon GL caps - check their size (dia. by height in mm). I've had both 25v 820uF and 25v 470uF CapXon GL caps, and both had the same 10mm x 20mm size.
                        Since the ESR and ripple current rating of a capacitor depends on its can size only (this is within the same series, of course), my 10mm x 20mm CapXons GLs were actually closer in spec to a 680uF 25v CapXon GL.
                        So keep that in mind when you're replacing yours, in case you have a hard time finding a replacement 820uF cap with those specs in that can size. The Rubycon ZLK you pointed may be a bit of an overkill (in terms of ESR and ripple), but they will more than likely work fine.
                        Ouch. 17" I can tolerate just fine, but 15"...
                        One reason I don't like using notebooks too much.
                        That 15" tube will probably work for many more years, though. Good to keep for a backup.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          +3
                          Except when you buy them from egekecu on eBay. I actually prefer him over here. His shipping is cheaper and they get here in half the time.
                          • pfrcom
                            Oldbie
                            • Jun 2006
                            • 1230
                            Originally posted by c_hegge
                            +3
                            Disagree with you there
                            Bought some Polymers from Badcaps because of Egekecu's uncompetitive pricing, and resigned myself for a long wait
                            Very pleasantly surprised when my shipment from Badcaps got to Melbourne in one week
                            Which was much quicker than my last purchase from Egekecu
                            better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              +3
                              I don't mean to sound like someones daddy
                              Or for that matter some promoter for Badcaps.net
                              However promoting an eBay seller over the excellent services offered by Topcat (Badcaps.net owner)
                              Or for that mater the services offered by Big Pope (Also a member of this site, selling Samxon caps from Hong Kong)
                              That just seems like a great disservice for Badcaps.net
                              The only reason this excellent forum exists with it's many knowledgeable members offering their advice for free is due to Badcaps.net services
                              • Fir3Chi3f
                                • Mar 2011
                                • 32
                                I found another source for that same info sheet:
                                I've hit something of a wall however, the dimensions on these sheets do not match the dimensions of the caps I have.
                                Specs on my blown caps:
                                820uF
                                25v
                                10mmX20mm
                                Closest match on the spreadsheet is 8mmX20mm
                                Overkill doesn't sound like a bad thing, any reason I shouldn't just replace these with Rubycon 820uF 25v ZLK 10mmX20mm that are available in the badcaps store?
                                @momaka - I did get the other monitor back, looks like they are KF series. I will replace the rest of the caps and perhaps take those polys out. Thank you.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  8x20 is very far off. Go by can size for Ripple and ESR - uF and volts don't matter for ESR.
                                  Use the dimensions on the cap you have in hand and the specs from closest the one in the data sheet with the same dimensions.
                                  [ESR and Ripple for whatever series are based on the can size.]
                                  In the GL data sheet the 820uF *25v* is 10x25mm with ESR=.043 Ripple=1460.
                                  Closest 10x20 is ESR=.052 and Ripple=1280.
                                  - Dr Seuss
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    The Ruby ZLK are close in specs to Panasonic FM, and from what I've seen, Panasonic FM has been used quite a bit for monitor repairs around here and it has always worked. So the Ruby ZLK should work fine, too.
                                    You can leave the polys.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Capxon KF are NOT polymers.
                                      Small lytics don't always have vents.
                                      - Dr Seuss
                                      • Fir3Chi3f
                                        • Mar 2011
                                        • 32
                                        Sorry pcbonez, I was talking about the polys I used in my first monitor repair before I was a member of this board. The picture below is taken from my tutorial on overclock.net
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • ArchangelGabriel
                                          Aorus 17G YD laptop, broken display, could not switch to external monitor
                                          by ArchangelGabriel
                                          Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
                                          11-23-2023, 03:55 AM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
                                        • kalemaroni
                                          MAG274QRF-QD 27" gaming monitor half backlight shadow
                                          by kalemaroni
                                          A customer called me up and said that half the screen was like a shadow - presumably the backlight has partially gone. I've never done a repair like this on a monitor, only circuit board based repair on Macbooks etc - is it something that's doable or generally not?
                                          04-23-2024, 03:52 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
