Half rule broken
  • Fir3Chi3f
    • Mar 2011
    • 32
    Re: Half rule broken
    Although it's a little late, I found a thread on the exact monitor I've been working on. https://www.badcaps.net/forum/showth...?t=7900&page=2 In it mouser and Toasty both recommend replacement caps... I don't think I order one in common with the two.
    Moving on, here is what I've ordered for each replacement:
    Originals:
    All CapXon GL
    47uF 50v 11x6.3mm Ripple: 240-250 ESR: 0.44-0.65
    680uF 25v 16x10mm Ripple: 920 ESR: 0.074
    330uF 25v 13x10mm Ripple: ~722 ESR: ~0.095 (My own guessdimasion)
    820uF 25v 10x20mm Ripple: 1280 ESR: ~0.052 (If I understood PCBONEZ correctly)
    Replacements:
    Rubycon 33uF 35V 5mm ZL Series Ripple: 250 ESR: 0.30
    Samxon 470uF 25v 10mm GT Series Ripple: 1050 ESR: 0.069
    Rubycon 220uF 25v 8mm ZLG Series Ripple: 1000 ESR: 0.036
    Rubycon 680uF 16v 8mm ZL Series Ripple: 1250 ESR: 0.041
    Value ranges are based off of data sheet estimates as the specific value wasn't listed. I don't think I'm going to replace those darn taicons just yet as I couldn't find any data sheets on them (although I'm sure someone here can prove me otherwise).
    Fun needs a full tank of gas
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Research the Samxon GT.
      There are a couple of older Samxon series that are problematic.
      I don't recall what they are for sure but GT sounds familiar.
      [Or someone that remembers can pipe-up.]
      Mann-Made Global Warming.
      - Dr Seuss
        master hoarder
        • May 2008
        • 12170
        What particular series are you looking for?
        If I remember correctly, most of the Taicon series should correspond directly to Nichicon series since Taicon claims to be a subdivision of the Nichicon family. Not sure how much of that is true, but their series names do match indeed. For example, both Taicon and Nichicon have HD, PM, PW, and HE series. I do remember a discussion somewhere on this forum about Taicon and Nichicon and now their series were equivalent. Of course, Taicon is made in Taiwan and China so the quality is obviously not the same.
        But in any case, if you just use Rubycon ZL for those, everything should be fine. At least from my experience, it seems that most LCD monitor PSUs don't seem to care that much what caps you put in them, as long as their ESR is the same or better than the original ones. That's why your poly caps didn't cause a problem. In computer PSUs, however, the ESR must be the same or at least very close.
        Samxon GF have been problematic. I remember seeing them in quite a few threads here in the past. I don't recall anything about GT, though.
        Searching for Samxon GF shows quite a few threads where they were bad.
        Searching for Samxon GT doesn't.
        Plus, I doubt Topcat would be selling bad caps. Otherwise I'm sure one of his customers would have complained by now.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Yes, Taicon is in cahoots with Nichicon.
          So if you see a Taicon series name and there is a Nichicon with the same series name you can look at the Nichicon data sheet.
          - I do not mean to imply that their quality is the same. It isn't.
          Their specs & design are the same but Taicon uses cheap Chinese materials and Nichicon uses Japaneses materials.
          I also remember a Saxon GL that had issues.
          Think those are obsolete so no data.
          I didn't know TC sold Samxon GT.
          Only Samxon I buy often are the RS series for PSUs.
          - Dr Seuss
          • Fir3Chi3f
            • Mar 2011
            • 32
            I finally posted the tutorial, I'm still adding more - Including some direct quotes and shout-outs to a few of you here that have helped me out. Word of warning though, I've embedded most of the pictures into the thread and I know that annoys some.
            http://www.overclock.net/monitors-di...l#post14362120
            Let me know what you think!
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Interesting style you have there.
              You might wanna add RS Components as a source of parts for those folks across the big pond.
              - Dr Seuss
              • Fir3Chi3f
                • Mar 2011
                • 32
                #27
                Thanks PCBONEZ, gotta keep things interesting
                Thanks for the suggestion, source has been added.
                  master hoarder
                  • May 2008
                  • 12170
                  #28
                  Awesome pictures, Fir3Chi3f. It made the tutorial quite enjoyable to read .
                  In your tutorial, though, I wouldn't say that the caps should be chosen mostly based on ESR and ripple current. It's better to keep the capacitance and voltage rating the same as the original caps. In fact, it's not recommended to go down in voltage (unless you've checked the circuit voltage already and you know the new lower-voltage caps are rated higher than that circuit voltage). Capacitance you can vary, but try to stay to within one level of the original caps, which is %20 (going %20 higher is usually better than going %20 lower). With all that said, ESR and ripple rating are still very important, but don't go *just* by those. Also, for the replacement caps, you can go with whatever can size you want (as long as ESR and ripple current match the original caps) - just make sure you can fit them on the circuit board and that the monitor lid can close properly afterwards.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    In SMPS Filters:
                    In so far as filtering out Ripple Frequencies the ESR and Ripple are more important.
                    In so far as Transient Response (keeping the DC voltage steady with load changes) the uF is more important.
                    As the frequency needing filtered goes up [as in filters for EMI instead of SMPS Ripple] at some point the uF becomes more important but there is an area in between [roughly over 100 kHz to about 1Mhz] where ESR and uF share the 'responsibility' [as it were].
                    This is because at 100kHz the Z = ESR but, as Frequencies go up, the ESR goes up and the Xc goes down. The one with the most affect on Z is the one that is lowest at the Frequency being filtered.
                    If you don't know exactly what the circuit is up to then it's best to stick to the original values.
                    - Dr Seuss
                      by momaka
                      03-15-2023, 10:17 PM
                    • ArchangelGabriel
                      Aorus 17G YD laptop, broken display, could not switch to external monitor
                      by ArchangelGabriel
                      Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
                      11-23-2023, 03:55 AM
                    • wattage
                      by wattage
                      Hello Badcaps Community,
                      Yesterday, 04:41 PM
                    • kalemaroni
                      MAG274QRF-QD 27" gaming monitor half backlight shadow
                      by kalemaroni
                      A customer called me up and said that half the screen was like a shadow - presumably the backlight has partially gone. I've never done a repair like this on a monitor, only circuit board based repair on Macbooks etc - is it something that's doable or generally not?
                      04-23-2024, 03:52 PM
                    • ant3202
                      HP 27es - LED monitor - Monitor Flashing On - Off
                      by ant3202
                      Hi Everyone
                      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                      https://www.badcaps.net/forum/troubl...lashing-on-off
                      The monitor is HP 27es LED Monitor
                      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                      The monitor will randomly blackout and display no signal and will recover again.
                      Sometimes need to power and off again to restore the display but...
                      03-20-2025, 07:30 PM
