Of that batch of 13 I got of these cards, I poly modded most of them. I recapped a couple in lytics, insured they were working properly, and then measured voltages to see what I could do as far as poly modding them. The pic below shows what voltage is on each, and what polies to use.
These cards are drilled for both 3.5mm and 5mm lead spacing on all caps, so there was no cramming to make the 10mm polies fit in the positions for 8mm lytics, and visa versa with 8mm polies fitting into positions for 10mm lytics.
Here's a few pics of the finished product:
Good luck if you try this.
