a good free defragmentor?
  • Phaihn
    • Jan 2009
    • 842
    anything but defraggler uhg lol?
    any one know a good free defragmentor thats not packed with spyware?
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
  • uligli
    • Aug 2006
    • 139
    Re: a good free defragmentor?
    I use defraggler and no problems, if u dont like try Ultradefrag.
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      I've been using VoptXp 7.12. Works great and its quick. There are versions out there for Vista, and Windows 7. If you want it for Xp shoot me a pm with an email adress in it and I will send it to you. Below is a screen shot of
      Vopt 9. VoptXp 7.12 looks about the same.
      "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
      Mark Twain
      "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
      John Paul Jones
      There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
      Rod Serling
      • c_hegge
        • Sep 2009
        • 5219
        I never defragment. I find that it rarely makes any difference in performance.
        • digge
          • Apr 2006
          • 296
          Dont usually defrag myself since im on SSD, but on parents computer im using mydefrag (www.mydefrag.com) formerly known as jkdefrag. Does the job and have scheduling and all that stuff if you want to get advanced.
          • c_hegge
            • Sep 2009
            • 5219
            Should be more like don't EVER defrag. SSDs actually work better when the data is spread out. Defragging just uses up a read/write cycle when it's completely unnecessary.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              or flash drives and camera cards...
              for defrag, what is wrong with the one in xp? unless you really want to defrag system files ( for that, i plug the hd into another computer and defrag it that way. on my xp boxes, thats what i have used... and trust me, a defreg really does help. quicker access times. i once had one that was 80% fragged... it was sooo slow! a defrag helped it a lot.
              linux does not need it as it stores files in a non-fragmenting manner.
              sigpic
              (Insert witty quote here)
              • digge
                • Apr 2006
                • 296
                Sorry for bad wording, but thing is i have SSD and normal ones in computer. Never defrag the SSD but i do defrag the normal ones (seldom though, almost never) Maybe that didnt get through from what i wrote, sorry bout that.
                And to answer ratdude, whats wrong with the built in in XP, well basically nothing wrong with it, apart from it being overly slow and dont have at all as much settings and optimizations one might want. Like it doesnt order files on file usage, only bunch them up so they are not fragmented.
                • japlytic
                  • Oct 2005
                  • 2086
                  I use IObit Smart Defrag, and the latest version does SSD drives.
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    http://www.goldenbow.com/
                    This is for Vopt 7.12 and the newer one for Xp, Vista, and Windows 7. I think each has a thirty day evaluation period. Don't defrag your SSD.
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      When transferring a machanical HDD partition to a SSG I use Perfectdisk
                      Because it allows to move the MFT backup copy, the MFT is at the middle of the partition, and this is the reason a NTFS partition can be shrinked a max of 50%
                      So I first shrink it 50%, then run Perfectdisk so it moves the MFT that is now at the end of the partition to the "new" middle of the resized partition
                      Then rinse and repeat untill the partition have been shrunken enough so it can be moved with Drive Snapshot to the new SSD disk
                      (If only the SSD's would come down in price, then this would not be necessary )
                      As for the mechanical harddrives I use I barley ever defragment them
                      • c_hegge
                        • Sep 2009
                        • 5219
                        I once had one that was 80% fragged...
                        How on earth did you manage that? I just analysed my HDD. Volume fragmentation is 0%, File fragmentation is 1%. That's after a bit over a year of fairly heavy use. So assiming I get 1% file fragmentation per year, it would take me 80 years to get that!
                        • styxbound
                          • Aug 2010
                          • 91
                          I don't know of anything which can touch Auslogics for speed.
                          • AudioCraZ
                            • Sep 2009
                            • 147
                            I have used jkdefrag in the past, works great, not very pretty though. Just recently tried Defraggler, and yes, I don't like it. Too slow, and not a lot of options.
                            • smason
                              • 1652
                              Perfectdisk is really good. Not free, but quite good.
                              • Phaihn
                                • Jan 2009
                                • 842
                                the reason i ask is for my brother in laws laptop the built in xp defragger doesnt work right and he has defraggler and that barrely works id put diskkeeper on it for him if i had the money to pay for it.
                                My Computer.
                                • digge
                                  • Apr 2006
                                  • 296
                                  If im not mistaken at least the win2000 built in defragger is actually a stripped down diskkeeper defragger. Not sure about the XP one though, someone else here might know.
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    Digge; screenshot below from XP x64 defrag utility, so yup, it is Diskeeper
                                    www.execsoft.com
                                      • 31012
                                      http://ultradefrag.sourceforge.net/
                                        master hoarder
                                        • May 2008
                                        • 12170
                                        • Bulgaria
                                        Yes, I like that one too. Much quicker than anything else I've used.
                                        I don't defragment my hard drives anymore, though (at least not until the Windows XP defragmenter tells me I should).
                                        I think the more you fill the hard drive up, the faster it starts to fragment.
                                        Currently I'm sitting at 14% file fragmentation and 7% total (according to the Windows XP defragmenter). This is after about 5 years of use. My hard drive (80 GB) is filled up just a little more than halfway. Haven't checked my other computers.
