Ps4 1215a hdmi diode readings good everything good but no pic??
  • irepair559
    • Dec 2022
    • 136
    PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys
  • Boardview and Schematic Bot
    iPhone 11, 11 Pro, 11 Pro Max Boardview & Diode values
    iPhone 11 A surface.cad
    iPhone 11 BC surface.cad
    iPhone 11 PRO.cad
    iPhone 11 Pro & Pro MAX boardview Diode value.cad
    iPhone 11 Pro & Pro MAX PCB layer.cad
    iPhone 11 AP+BB boardview Diode value.cad
    iPhone 11 AP+BB PCB layer.cad
    iPhone 11 Common problems.cad...
    10-07-2026, 03:16 PM
  • Apoco_ lips
    gigabyte x870i aorus pro ice stuck on dram light, ddr5 power good voltage 0 when ram stick installed
    by Apoco_ lips
    I have a gigabyte x870i board I am attempting to repair. I have a working board as well to reference. The board is stuck on the dram light, wont post and I found the power good pin has 0 volts when powered on with a stick of ram installed. With out the ram it is 3.3v. Another weird issue with the board is when trying to use qflash to update the bios, the qflash light blinks for about 15 seconds then turns off for 30-45 seconds and then turns back on solid for about 3 minutes. My working reference board will flash the qflash led for about 15 seconds, turn off for a few seconds then turn back on...
    06-30-2026, 04:15 PM
  • bendeg
    Need explanations about DMM diode mode
    by bendeg
    I recently viewed videos on DMM diode mode (Louis Rossmann, Sorin from Electronics Repair School).
    I don't fully understand how it works...
    I know what diode mode is when it comes to test a diode or a transistor (any component with P-N junction). That I can understand.
    But when it comes to test any points in a circuit in diode mode instead of continuity mode, that's where I'm a bit lost...
    For example, in one of his video, if I remember well, Sorin explains how to check a charger port in continuity mode first, which is quite...
    08-20-2026, 02:07 AM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • Jay12345
    Ps4 white light but no display
    by Jay12345
    Hey, can I get some suggestions on what I'm missing if anything?
    A customer sent me a PS4 slim (SAF 005)saying it needs the HDMI IC replaced. I measured in diode mode and readings around the IC were slightly lower than usual but not completely out of spec. In any case, when turned it on, it goes to a white light and the screen is black with some flashes at startup and then completely black again.
    Here's what I did:
    Replaced HDMI IC: now it's permanently black, no flashes. Also the measurements are nominal.
    Replaced port. Even tho it seemed good...
    10-15-2026, 03:09 PM
