Good brands of run capacitor for house heat hump
  • cook
    Quiet observer
    • May 2010
    • 101
    Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
    Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
  • dmill89
    • Dec 2011
    • 2546
    Amrad, Titan HD (not Titan Pro), Mars (only the USA made ones). Generally any of the US made brands are decent (compared to the Chinese/Mexican stuff) which all of the listed brands are, however none of them last as long as they did before the PCB phaseout.
    • cook
      Quiet observer
      • May 2010
      • 101
      Great info. "...the PCB phaseout" - - So that is what has caused them to not last as long. I was wondering why they did not last as long as these days.
      Thank you
      • RukyCon
        A Fake Rubycon
        • Jan 2017
        • 819
        • Electronics & Lighting (Mostly Vintage Lighting)
        I hear Aerovox are pretty good, seen them used a lot with HID ballasts and haven't really seen/heard of many, if any failures. But yeah, oil filled capacitors as a whole suffered a lot during the PCB ban, as those older capacitors were really stable and held up really well, even to this day.
        I'm not a expert, I'm just doing my best.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8820
          I use Cornell Dubilier and Amrad with good success. Anywhere from an electric wood splitter, to deep well pumps. So far so good.
          • Apoco_ lips
            gigabyte x870i aorus pro ice stuck on dram light, ddr5 power good voltage 0 when ram stick installed
            by Apoco_ lips
            I have a gigabyte x870i board I am attempting to repair. I have a working board as well to reference. The board is stuck on the dram light, wont post and I found the power good pin has 0 volts when powered on with a stick of ram installed. With out the ram it is 3.3v. Another weird issue with the board is when trying to use qflash to update the bios, the qflash light blinks for about 15 seconds then turns off for 30-45 seconds and then turns back on solid for about 3 minutes. My working reference board will flash the qflash led for about 15 seconds, turn off for a few seconds then turn back on...
            06-30-2026, 04:15 PM
          • Boardview and Schematic Bot
            Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
            The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
            Securing a good thermal interface between...
            10-07-2024, 04:35 AM
          • Tesla
            Need recommendations for a good chip-programmer please
            by Tesla
            Well, my account here still works. I still remember those days … replacing the caps to save a motherboard. Back before our current disposable-mentality really took-hold. I’ve looked around at the recent threads … it’s really cool how yall help each other. I’ve still been upgrading and fixing desktops and laptops. Replace a laptop-MB, install a NVMe-SSD, new thermal compound apply, pull a coin-battery to clear-cmos (that kind of thing).
            Now that we apparently have to try to build laptops like phones (solder almost everything to the motherboard) looks like the idea of repairing...
            03-15-2026, 06:39 PM
          • irepair559
            Ps4 1215a hdmi diode readings good everything good but no pic??
            by irepair559
            PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
            01-05-2023, 12:32 AM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
