The Hall of Shame - Badcaps Photo Montage
This is a sticky topic.
  • cruzinforit
    Rin is my waifu
    • Apr 2015
    • 22
    Re: The Hall of Shame - Badcaps Photo Montage
    I don't yet have pictures, I'll get them later, but on one of those optiplex 320s that had the non-failed rubycons, I grabbed one to mess around with, and after installing ubuntu I realized the power supply fan had completely seized- and it probably had been that way for a while. This prescott powered computer had had a failed power supply fan for sometime and it was still working! I pulled the old Dell power supply and am going to stick an older good bestec in it. Out of curiosity, I opened it up to see if any of the caps had failed. Not unexpectedly, it was full of bulging Ltec and Teapos.
    In other words, not only had those Rubycon MCZs survived the heat of the prescott that killed every board with KZJs, but it also survived what had to be significantly elevated ripple from the power supply too.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      A Bestec? *cringes*
      The increased temps from the bad fan probably caused the caps to fail. It seems Delta (if this is a Delta made PSU, it might also be Hipro) manages to use Ltec caps with a moderately low failure rate.
      Muh-soggy-knee
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        STOP!!!! DO NOT PUT A BESTEC IN THERE AT ALL!!!!! THOSE BESTECS HAVE BEEN KNOWN TO KILL MOTHERBOARDS WITH THE 5VSB VOLTAGE GOING SKY-HIGH!!! AGAIN, DO NOT EVER, EVER, EVER INSTALL A BESTEC PSU WITHOUT REMOVING THIS ISSUE!!!
        /endwarning
        Permanently Retired Systems:
        Kooky and Kool Systems
        sigpic
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          #644
          The power supply was likely a Hipro with a seized ADDA (or maybe Suppered or Sunon?) fan if Ltecs and Teapos were present and bulged inside the unit (likely LZP, LZG, or LXY, and SC series). And the only way to really know if those MCZs are still good is to pull them and measure them on an ESR meter. Capacitors can fail without any signs evident to the sensory as well.
          /endwarning
          Umm... only one Bestec PSU has that "issue" by default and that's the ATX-250-12E. Pretty sure that's not the model he used in that SFF system.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            It's a shame the ATX-250-12E tainted their name forever. Overall, Bestec designs very good PSUs. It's just the tan glue that ruins them. The newer ones use the white glue and are excellent for recapping, because they come with 100% CapXon.
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              #646
              ^ What those two quotes say is 100% true.
              Only the ATX-250-12E is a motherboard killer. The ATX-250-12Z and ATX-300-12E (similar looking models, aren't they? ) are both solid performers.
              They do indeed. However, the two I worked on had Chemicon KZE on the 5VSB. Go figure. I bet Bestec knows why. The rest was, CapXon, unfortunately... or fortunately??
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #647
                and even the atx250-12e is fine with a simple recap.
                i use a 22@50 fc on the "death cap".
                have one in 24/7 now for 5 years.that cap is still in spec.
                a bit of carb cleaner softens the yellow/brown glue so i can pick it off.
                these units contributed to the bad name of emachines no doubt!
                maybe this was their failed attempt to test acceptance of the "dixie cup pc".
                use it a year and throw it away.
                • steviewonder
                  • Dec 2013
                  • 183
                  • england
                  #648
                  Ahh E-Machines?
                  That explains why I used to come across so many with fried motherboards a few years ago now...you learn something new every day !
                  • kevin!
                    recapping PCB.
                    • Jul 2013
                    • 195
                    • España
                    #649
                    /endwarning
                    Bestec is synonymous with quality, .
                    That is the worst source I've seen. I have not seen any fry a computer, but to stop sending voltage yes.
                    I do not know if Bestec designs good sources, but I have seen, all without exception have been damaged ... and have not killed by swollen capacitors. I do not recommend it as a manufacturer so bad it is.
                    Here in Spain they are usually put in HP.
                    off topic,
                    For me as a Fotron, there is none. I have one with almost nine years, and many years working.
                    Bye
                    Gaming pc:
                    nVidia RTX 3080 TI, Corsair RM750I.
                    Workshop PC:
                    Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
                    Server:
                    • Behemot
                      • 4845
                      • CZ
                      #650
                      Fortrons go regularly bad because of bad caps. After recap quite decent units though, I have many on stock to refurbish. Got caps available for them, if you need, just let me know.
                      • Simpletek
                        • Mar 2011
                        • 35
                        • Italy
                        #651
                        My contribute..... Facon 10000uf 100 VDC from Montarbo w20a amplified speaker
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Hahah, good one!
                          "Facon"
                          Fake-capacitor? xD
                          I bet it made a mess though :S
                          -Ben
                          Muh-soggy-knee
                          • Simpletek
                            • Mar 2011
                            • 35
                            • Italy
                            #653
                            Originally posted by ben7
                            Hahah, good one!
                            "Facon"
                            Fake-capacitor? xD
                            -Ben
                            seems to be real http://facon.com/
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              My 2003 Antec True 430 1.0 has the dreaded brown glue!
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              Arc A770 16 GB
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                                master hoarder
                                • May 2008
                                • 12170
                                • Bulgaria
                                #655
                                "Facon"
                                Fake-capacitor? xD
                                I read it more like "fuck-on"... which is about right IMO - i.e. f--- those capacitors
                                • kevin!
                                  recapping PCB.
                                  • Jul 2013
                                  • 195
                                  • España
                                  #656
                                  Power supply brand Airis with badcap canicon low ESR. (Capacitor, SC and GL Quality Unknown):
                                  SC capacitor:
                                  Bye
                                  Gaming pc:
                                  Workshop PC:
                                  Server:
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    #657
                                    K mex is the OEM. Can you post a photo of the transformers?
                                    • kevin!
                                      recapping PCB.
                                      • Jul 2013
                                      • 195
                                      • España
                                      #658
                                      Here you go:
                                      Capacitor HEC (trash XD):
                                      Yes, it is k mex, because they are equal.
                                      Gaming pc:
                                      Workshop PC:
                                      Server:
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        That's a very old power supply. I'm pretty sure Canicon (Horng Jang) went out of business, or changed their name in 2007. GoldLink and CS (12kuang Jin) are also low quality. With "best" to worst CS>Canicon>GL
                                        Definitely KME, Ever-Power on the transformer, and they often use that style of label
                                        • kevin!
                                          recapping PCB.
                                          • Jul 2013
                                          • 195
                                          • España
                                          #660
                                          Surely it will be a source of KME rename. Airis is a Spanish brand that is dedicated to assemble PCs and laptops, and other components, and rename.
                                          Airis plates often use poor quality, for example Matsonic ms9147c (this board is unable to pass from FSB 400), then low quality PSU (KME), etc ... and it's no wonder the quality of this horrible PSU.
                                          Gaming pc:
                                          Workshop PC:
                                          Server:
