Re: The Hall of Shame - Badcaps Photo Montage
Cool links. Thanks!
That's exactly what I mean.
Basically what the manufacturers are saying is you should expect about 15 years of trouble-free life... or thereabouts if the caps weren't abused (obviously the life should be derated according to operating conditions). It's a "recommendation", not requirement.
So in a setting with parts that have critical tasks - like industrial gear, for example, then you should expect to change any parts with electrolytic caps about every 15 years or less if you want pretty much guaranteed trouble-free operation.
But in consumer gear, we can see from field results (old computers, for example) that on average, *many* caps will last much longer than 15 years without problems whatsoever. In fact, even 20-25 years is not uncommon. By that time, typically the consumer item has been replaced a long time ago.
They also tend to have worse ESR specs.
My guess would be that the process that bends the leads and smashes them so the caps become SMD is weakening the seals/bungs of the caps. Hence they dry out quicker. But that is just a speculation on my part.
The soldering process may also have something to do with it as well. I think through-hole caps tend to be exposed to less heat during soldering than SMD.
Cool links. Thanks!
Half of the computer problems is caused by bad contacts
