LG 55UJ6300 Very Dim
  • dhoff024
    • Mar 2013
    • 96
    I am trying to diagnose my mother and father in laws TV. The TV has a picture and is functioning properly other than the screen is very dim. If you are in a bright sunny room you can't see anything but if you are in a dark room you can see the picture but you can tell it's not right. I don't know if it's an LED probably, I have had other LG's that had nothing but problems with the LED's but when those had problems the screen would be completely black. Would love some help diagnosing so I can get this fixed for them. Thanks in advance!
  • neilc6
    • Nov 2015
    • 1550
    Re: LG 55UJ6300 Very Dim
    Backlight issues are 99% the backlights themselves. On LGs, the protection circuitry usually kicks in to shut down the backlights but I have seen it a few times where it doesn't. https://techhometravel.com/lg-ln-ser...ed-backlights/
    • dhoff024
      • Mar 2013
      • 96
      Thank you, I suspected backlight was the problem since I have had that issue with other LG's but other would flash or just not light up this lights up but is very dim so wanted to get some opinions before I went ordering new LED's.
      • R_J
        • 9535
        Measure the voltage across the +/- on the plug going to the led's, it should be around 130vdc
        • dskall
          • Oct 2016
          • 2905
          • usa
          I repaired one that had 3 out of 16 strips working. And it still had a picture.
          • dhoff024
            • Mar 2013
            • 96
            I am coming up with 211 volts DC. Tested several times 211 each time.
            • dhoff024
              • Mar 2013
              • 96
              My gut tells me it's the LED's since it seems to be so common with these LG's but I have never seen one still have some backlight and a picture like all the ones i have done have had no backlight or it would flash then go out.
              • R_J
                • 9535
                211 volts seems high, I suspect some of the led's in the panel are bad, there is less current being drawn so the voltage goes up.
                Looking at shopjimmy, there are 10 strips with 4 led's on each, 40 x 3volt =120v total
                It looks like the backlight control circuit is quite simple and keeps operating if a few leds are bad, not like some circuits that will shut down if even one led is weak.
                • dhoff024
                  • Mar 2013
                  • 96
                  Ordered some LED's from shop Jimmy. Got the TV torn apart today and think I found the culprit as you can see in the photo. I will update once I get the parts and get it put back together.
                  • neilc6
                    • Nov 2015
                    • 1550
                    On that model the LEDs turn blue as well. Best to replace them all with the TV apart.
                    • sigmeyer
                      • Feb 2020
                      • 147
                      • Serbia
                      Yes , i can confirm i have repaired these sets before , 99% is the backlight , if you have some parts lying around and a 10Watt 33k-ish ohm resistor you can build a simple Backlight tester to save you the time of troubleshooting elsewhere.
                      • dhoff024
                        • Mar 2013
                        • 96
                        Ok so I replaced the backlight and all was good for a day now the backlight is completely out but picture can be seen with a flashlight could the backlight really be bad again or could the be a power supply problem?
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Again you will need to measure your backlight voltages.
                          • neilc6
                            • Nov 2015
                            • 1550
                            Did you replace all the strips with new or just the bad strip? Did you turn down the backlight level after the repair and check all inputs and apps?
                            • dhoff024
                              • Mar 2013
                              • 96
                              All strips were replaced with new ones from shop Jimmy. I just checked voltage and I am at 254 volts DC. I did not turn down the backlight or change anything just replaced the LED's and put it back together. Worked perfect for a day now no backlight at all.
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                I assume you don't have a backlight tester. You probably have an open circuit.
                                • dhoff024
                                  • Mar 2013
                                  • 96
                                  I found the culprit after tearing the TV back apart. Now I need to get the parts warrantied by shop jimmy.
                                    • 12172
                                    • U.S.
                                    did you test the new leds before installing them? is that burnout in the exact same place as the original fault?
                                    • dhoff024
                                      • Mar 2013
                                      • 96
                                      I did not test the new ones before installing. This burnout is not in the same spot.
                                      • Pipolups
                                        Corsair K70 LUX RGB dying LEDs
                                        by Pipolups
                                        Hi there !
                                        I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                        Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                        10-08-2024, 11:58 AM
                                      • jean luc ferre
                                        laptop hp g72 b52sf screen problems
                                        by jean luc ferre
                                        on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                        the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                        i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                        i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                        06-07-2025, 03:27 PM
                                      • HP32Sii
                                        Philips 50PUS6262/12 (chassis TMP17.7E LA) no picture
                                        by HP32Sii
                                        This is my first post on this forum, and my first attempted repair of a modern flat-screen LCD-TV (though I have repaired a few LCD-monitors, all with Elco-problems (high ESR). I have repaired my fair share of TV-sets and VCRs in the past ('90s) and was fairly familiar with the different Philips chassis (KT-3M, K12, K2, K3, K7 are some that come to mind). So I have a fair bit of experience on old sets. Obviously, modern TV sets are quite a different cup of tea.... no HOT or flyback-transformer inside, for starters....
                                        The set came into my possession by accident,...
                                        02-26-2023, 10:00 AM
                                      • Hondaman
                                        USB problems?
                                        by Hondaman
                                        Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                        (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                        I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                        08-12-2024, 03:26 PM
                                      • clabr
                                        Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                        by clabr
                                        Need help to solve some problems with this laptop.
                                        After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                        After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                        Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                        Before this had happened I observed some other problems:
                                        When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                        12-02-2021, 08:09 AM
