Corsair K70 LUX RGB dying LEDs
  • Pipolups
    HW eng.
    • Jul 2024
    • France
    Hi there !
    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄
    So any one here know which kind of LEDs they used for that specific keyboard ? I don't know if it's some basic RGB LEDs or if it's fancy digital ones, nor which kind of package they are in.
    I was wishing to order them before starting to disassembly my keyboard and thus reduce the maintenance time of that great mech keyboard.
    Thanks for any information I can obtain here !
  • madyoyo
    Samsung 48h6200: circular spots after replacing leds
    by madyoyo
    Hi. I repaired a Samsung 48h6200 with a bad backlight (most leds turned blue and lost their diffuser. But after reassembling, I notice circular "shadows" around each kedsespecially on "flat"picture. Couch I have done something wrong when changing the leds? Or maybe the new leds are faulty or bad quality? They are from aliexpress...
    07-12-2026, 02:54 PM
  • h0m3w0rk
    Random Shutdowns/Startup Failure with Corsair SFX 450
    by h0m3w0rk
    I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
    For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
    02-09-2025, 03:19 AM
  • Green Probe
    Lenovo Legion 7 16ACHg6, Only Rear LEDs Light Up
    by Green Probe
    Hello friends,
    I have a
    MTM: 82N600DRUS
    When the power button is pressed only the LEDs toward the rear of the case light up. No power LED, LCD backlight, or any other signs of life. Holding the power button will turn off the rear LEDs. The 20v, 5v, 3.3v, 1.8v (and 0.75v?) rails are present. The BIOS and vBIOS chips have 1.8v and 3.3v. Is this possibly a corrupted BIOS?
    Thanks in advance!
    04-08-2026, 07:23 PM
  • Ukdigger
    Samsung UE65KU6400UXXU Should it have Blue LEDs
    by Ukdigger
    Power Supply Board - BN44-00073A (LPF5G-6LM)
    Main board BN94-10777A
    TV was only showing faint picture at the left and right edges with nothing in the middle.
    Took the TV appart and found that the plastic defuser sheet was cracked and burnt on the left and right edges. The LED strips are on the left and right edges. I managed to get a scrap TV with the same size defuser sheet in good condition. The LEDs were blue, all the TVs I've done before have white LEDs so I thought I needed new ones. I ordered some new ones from Aliexpress and they were blue....
    01-28-2026, 10:08 AM
  • pni
    Backlight panel diffuser melt by backlight leds broken
    by pni
    Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
    10-12-2025, 12:08 AM
