Samsung UN55EH6000F Power issue
  • CraigR
    • Dec 2013
    • 959
    I got in a Samsung UN55EH6000F with no power and blown fuse on the board (BN44-00499A) I found 3 bad mosfets and a blown resistor circled in the pictures. Now just putting power to the board and checking voltages I get what I need 13v then goes off and on over and over. I connected to TV and TV powers on with sound then off over and over again. I did not include pics of the TV since it is in the power board. So what would cause it to power on and off repeatedly? ?
    • 12123
    • U.S.
    Re: Samsung UN55EH6000F Power issue
    Check all the diodes and touch up any solder joints that look odd.
    • CraigR
      • Dec 2013
      • 959
      Yep, went through all that before posting.
      • R_J
        • 9535
        That looks like a gate drive resistor, I would check the zener diodes and the other resistors in that drive circuit.
        One of the components you have circled is the standby ic, was it replaced as well?
          • 12123
          • U.S.
          At least a few still look cracked to me.
          • CraigR
            • Dec 2013
            • 959
            Yes, it was replaced also.
            • CraigR
              • Dec 2013
              • 959
              I found this mosfet (2 legs gone now) with nothing going threw it compared to other one with same number. Anybody know how I can get a good number to get another? WR N7 not coming up with anything on google.
              • R_J
                • 9535
                What is the board location?
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Looks to be an NPN. If it is sot-23
                  WR 2PD602R Si-npn GP, Sw, 60V, 500mA, 250mW, B=120..240, >160MHz SOT-23
                  If you have a component tester, just remove the other one and check it.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    • CraigR
                      • Dec 2013
                      • 959
                      Might be 2SK322WR What is the board location?
                      ZDL802 so must be zener diode and not a mosfet? the N made me think N channel?
                      • lotas
                        • Jan 2016
                        • 4555
                        • Russia
                        Bzx84c24-au
                        • R_J
                          • 9535
                          That looks correct, let me guess, they are in the gate circuit.
                          • lotas
                            • Jan 2016
                            • 4555
                            • Russia
                            in the gate circuit
                            • CraigR
                              • Dec 2013
                              • 959
                              Yep. Thanks for the number! I will order some up and get back with how it goes.
                              • CraigR
                                • Dec 2013
                                • 959
                                UPDATE: Same thing. 13v then zero just keeps doing it over and over. I was looking it all over again and see a tiny crack in the big green thermister wtr15d050 but I get 8.3 ohms cold so not sure if the crack means damage or not?
                                • R_J
                                  • 9535
                                  What about the A5V is it changing as well?
                                  • CraigR
                                    • Dec 2013
                                    • 959
                                    Yes it is.
                                    • R_J
                                      • 9535
                                      Yes it is.
                                      The first thing I would try is to connect the PS_ON/OFF pin to ground, this should place the power supply in standby mode, then you can see if the standby voltage A5V is stable.
                                      CNM803 pin 14 is PS_ON/OFF
                                      • CraigR
                                        • Dec 2013
                                        • 959
                                        Zero volts 5 nor 13 when when PS_ON/OFF jumped to ground.
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Cookybaby
                                          Samsung UN60ES6500FXZA Power Supply Issue
                                          by Cookybaby
                                          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                          Make: Samsung
                                          Model: UN60ES6500FXZA
                                          Power Supply P/N: BN44-00525A
                                          Symptoms: The TV was...
                                          08-20-2023, 12:26 PM
                                        • Drewwol11
                                          Samsung QN49Q70RAFXZA Power Cycling Issue
                                          by Drewwol11
                                          My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
                                          I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...
                                          08-31-2021, 09:32 AM
                                        • lp20th
                                          Samsung Plasma TV Power Supply Issue
                                          by lp20th
                                          I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                          11-28-2023, 10:28 AM
                                        • justice171
                                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                          by justice171
                                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                          1. Verified that all critical voltages are present:
                                            • 3.3V and 5V are always present if DC is plugged.
                                            • 1.8V on the BIOS chip is present.
                                          2. Checked the power button functionality:
                                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                            • Confirmed connectivity is intact, ruling out issues
                                          11-26-2024, 12:39 AM
