Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
  • Cooperr
    • Oct 2025
    • US
    I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
    The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board and power cycling it with the on/off button, which doesn't change the result. Am I missing something simple here?
    I've checked quite a few components on the power board following all the posts and videos I can find online, but I haven't found anything which measured wrong with my multimeter. There are two FETs in the PFC circuit (QP802 and QP804) that seem to be the most common failure, I removed them to test and they looked okay. Is it possible for them to be bad anyways?
    This video in particular is good and I followed everything in it (https://www.youtube.com/watch?v=dswtNRiZwN8), his method to check the FETs is at 4:40 which is what I did.
    Any and all feedback would be greatly appreciated! The attached schematic is for BN44-00445C, but is nearly identical to the A version I have.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4562
    • Italy - Milan
    Seeing certain voltages means that you placed a jumper to turn on all the board also without a thing connected at output, right? The electrolytic caps must be tested by a special meter , they cam show good shape but being bad also can explode from bottom rubber
    • iam5
      Intermittent USB-C / USB-A issues + Trackpad Freezes — T14s Gen2 (11th-gen Intel) — Seeking Board-Level Advice
      by iam5
      I’m looking for advice on board-level troubleshooting and potential component-level repairs for a Lenovo ThinkPad T14s Gen2 Intel (i7-1185G7) showing multi-domain instability. Hoping someone familiar with this platform (or the related X1 Carbon Gen9/Gen10, X13 Gen2, X1 Nano Gen1/2) can point me toward the right section of the board to inspect, and whether any of the known fixes apply. Symptoms:
      1. Trackpad (CS21 module) intermittently freezes during active use
      • Not tied to lid open/close
      • External USB mouse continues working
      • Sometimes recovers with sleep/wake
      • Looks like
      11-25-2025, 09:29 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • andrui742
      AMD FM2+ Board - Suspected Dead RAM Slot B1 - Seeking Diagnosis Advice
      by andrui742
      I'm helping a friend diagnose a desktop PC that is showing clear signs of a RAM slot failure. I would greatly appreciate your insights and experience on potential causes and any final diagnostic steps I might have missed. System Specifications:
      • Motherboard: ASRock FM2A58M-VG3+ R2.0
      • CPU: AMD A4-4000
      • Chipset: AMD A58 (Hudson D2)
      • RAM: Kingston 4GB DDR3-1333 (KVR13N9S8/4) - Two identical modules.
      Observed Failure Progression & Symptoms:
      1. Initial Intermittent Failure: The system would randomly BSOD in Windows 10 with a DRIVER_IRQL_NOT_LESS_OR_EQUAL error in
      11-28-2025, 06:49 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
