Samsung QN49Q70RAFXZA Power Cycling Issue
  • Drewwol11
    • Aug 2021
    My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
    I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the power supply, and when I plugged it in the backlight would come on and stay on (implying that the power supply board is working). Next I reconnected the main board to the power supply board and disconnected the flat cables to the panel, and the power would stay on and I could hear audio through the tv and navigate with the remote buttons (although it would power off if I tried to load an app like Netflix with the button on the remote).
    Based on the above troubleshooting steps, I think I've narrowed it down to an issue with the main board, the panel, or the cable connections, but I don't know how to diagnose any further. I've talked to a couple electronic repair stores in my area and have gotten very inconsistent advice, but it seems like it's pretty likely that it's simply a bad panel and can't be repaired. The last thing I want to do is bring it into a shop, have them charge me for 2 hours of labor, just for them to tell me that it's irreparable.
    I also tried to purchase a replacement main board on eBay but the seller contacted me and said that the issue I'm having is common for the model and indicates a bad panel, so we agreed to cancel the order.
    I'd appreciate any suggestions for how to further diagnose and troubleshoot this issue! I have a DMM and soldering kit if needed.
    Thanks!
    Drew
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • notallbad
    TCL 55RP620K power board issue
    by notallbad
    Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
    0% p_dim at 1.65v and a_dim at 1v
    50% p_dim at 3.3v and a_dim at 1.65v
    100% p_dim at 3.3v and a_dim at 2.88v
    Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
    Leds are 2 rows of 15 6v leds.
    On inspection of the power board found diode MBR3200 shorted so replaced with...
    07-12-2025, 05:45 AM
  • C152Heavy
    Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
    by C152Heavy
    Summary for TL-DR readers:
    • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
    • Have obtained Samsung schematic & service documents - Can upload if helpful.
    • Have read ALL applicable threads
    • C1818 and CP820 replaced as low hanging fruit
    • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
    • VCC pin (18) of PFC...
    01-11-2023, 02:53 PM
  • Nicktronic
    Samsung Power Supply Board BN44-00874F
    by Nicktronic
    Hey everyone,
    This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
    Anybody...
    03-17-2025, 06:20 AM
  • Asraf Atb
    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
    by Asraf Atb
    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
    01-27-2025, 05:02 PM
