I got in a Samsung UN55EH6000F with no power and blown fuse on the board (BN44-00499A) I found 3 bad mosfets and a blown resistor circled in the pictures. Now just putting power to the board and checking voltages I get what I need 13v then goes off and on over and over. I connected to TV and TV powers on with sound then off over and over again. I did not include pics of the TV since it is in the power board. So what would cause it to power on and off repeatedly? ?
Samsung UN55EH6000F Power issue
Re: Samsung UN55EH6000F Power issue
Check all the diodes and touch up any solder joints that look odd. -
Looks to be an NPN. If it is sot-23
WR 2PD602R Si-npn GP, Sw, 60V, 500mA, 250mW, B=120..240, >160MHz SOT-23
If you have a component tester, just remove the other one and check it.Last edited by dskall; 01-26-2022, 03:39 PM.I assume no responsibility for any stupid suggestions I might post.Comment
UPDATE: Same thing. 13v then zero just keeps doing it over and over. I was looking it all over again and see a tiny crack in the big green thermister wtr15d050 but I get 8.3 ohms cold so not sure if the crack means damage or not?Last edited by CraigR; 02-03-2022, 10:57 AM.Comment
Zero volts 5 nor 13 when when PS_ON/OFF jumped to ground.Comment
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by CookybabyHello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
Make: Samsung
Model: UN60ES6500FXZA
Power Supply P/N: BN44-00525A
Symptoms: The TV was... -
by Drewwol11Hi all,
My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...08-31-2021, 09:32 AM -
by lp20thI have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
by mrtekHi
Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
Main fuse = OK
Back light LED = OK. Power them with aux power source
LED output = OK 156V
I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on... - Loading...
