Samsung UN55EH6000F Power issue
  • R_J
    • Jun 2012
    • 9588
    Re: Samsung UN55EH6000F Power issue
    Originally posted by CraigR
    Zero volts 5 nor 13 when when PS_ON/OFF jumped to ground.
    You will not get B5V or B13V but you should get A5V (JP809) with the board turned off
    • CraigR
      • Dec 2013
      • 965
      Ok, yes I get 5v on JP809 with it jumped.
      • R_J
        • Jun 2012
        • 9588
        when you remove the jumper does the A5V stay at 5volts? or does it drop? If it drops I suspect the standby circuit is not supplying enough voltage to keep itself and the pfc circuit working.
        • CraigR
          • Dec 2013
          • 965
          Yes, it stays at 5v
          • CraigR
            • Dec 2013
            • 965
            I'm now just guessing at things and tested this resistor RP820 and out of circuit it's 0.11 but I can not find a chart online that the colors work with. Under the scope it looks black, gold, black, gray, black. but this comes as an error on the calculators.
            • R_J
              • Jun 2012
              • 9588
              with power supply on, Check the voltage across the main filter capacitor CP806
              This voltage should be around 165vdc in standby and go to around 300vdc when the power supply is on.
              • R_J
                • Jun 2012
                • 9588
                The resistor is ok. That is the source resistor for the pfc mosfet.
                • CraigR
                  • Dec 2013
                  • 965
                  172v in standby and 386v on.
                  • R_J
                    • Jun 2012
                    • 9588
                    If the PFC voltage 386vdc is steady, that means the standby circuit and the pFC circuit are working as they should.
                    • CraigR
                      • Dec 2013
                      • 965
                      Ok, so now what can I check?
                      • R_J
                        • Jun 2012
                        • 9588
                        I don't have a schematic, I am using the pictures of the board. I would try grounding the BLU_ON/OFF pin CNM803 pin6 and see if the B5v and B13v stay up
                        It might be that the backlight drive circuit is killing the B13v?
                        • CraigR
                          • Dec 2013
                          • 965
                          They do! they stay normal now.
                          • R_J
                            • Jun 2012
                            • 9588
                            So when the backlight circuit is turned on there is too much load on the supply, Back to post 1 where the two mosfets were replaced, It could be that they are being turned on hard and killing the supply. There are also a pair of dual diodes, DL851 & DL852, I would check them as well
                            This is a guess but it might be caused by open led's in the panel and the board is shutting down due to an over voltage on the led supply.
                            • CraigR
                              • Dec 2013
                              • 965
                              Just pulled them and checked with component tester and good.
                              • R_J
                                • Jun 2012
                                • 9588
                                What voltage do you get on JP840 when the backlight circuit is enabled (BLU_ON/OFF ground removed) Does it jump up to 300vdc? or is it higher? If it jumps up higher, connect the backlights and check the voltage again.
                                • CraigR
                                  • Dec 2013
                                  • 965
                                  On JP840 I get voltage up and down. but with BLU_ON/OFF jumped to ground I get no volt. Is that what you wanted to know?
                                  • R_J
                                    • Jun 2012
                                    • 9588
                                    Yes, when you say you get voltage up and down can you give a number?
                                    • CraigR
                                      • Dec 2013
                                      • 965
                                      from 54v to 11v constant fluctuation.
                                      • R_J
                                        • Jun 2012
                                        • 9588
                                        That is way too low, I suspect there is still a problem with the mosfets QL801 & QL802 or there gate drive circuit.
                                        • CraigR
                                          • Dec 2013
                                          • 965
                                          QL801 and QL802 are new.
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • Cookybaby
                                            Samsung UN60ES6500FXZA Power Supply Issue
                                            by Cookybaby
                                            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                            Make: Samsung
                                            Model: UN60ES6500FXZA
                                            Power Supply P/N: BN44-00525A
                                            Symptoms: The TV was...
                                            08-20-2023, 12:26 PM
                                          • Drewwol11
                                            Samsung QN49Q70RAFXZA Power Cycling Issue
                                            by Drewwol11
                                            My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
                                            I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...
                                            08-31-2021, 09:32 AM
                                          • lp20th
                                            Samsung Plasma TV Power Supply Issue
                                            by lp20th
                                            I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                            11-28-2023, 10:28 AM
                                          • mrtek
                                            Samsung UN43NU6950FXZA No power
                                            by mrtek
                                            Hi
                                            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                            Main fuse = OK
                                            Back light LED = OK. Power them with aux power source
                                            LED output = OK 156V
                                            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                            07-20-2025, 08:06 PM
