Sony xbr65x900c sound yes, no backlight or image.
  • vinceroger69
    • Mar 2012
    • 6714
    #81
    Re: Sony xbr65x900c sound yes, no backlight or image.
    This video is worth a watch
    https://www.youtube.com/watch?v=zK8oNhFaRdM
      • 12272
      • U.S.
      #82
      Thanks VR69 you
      • vinceroger69
        • Mar 2012
        • 6714
        #83
        Thanks VR69 you
        so easy to forget how to test things at times even more so as i get older lol.
          • 12272
          • U.S.
          #84
          I hear that, I'm sooo glad I didn't go into brain surgery, as fast as I forget things, I would've been turning all my patients into zombies.
            • 12272
            • U.S.
            #85
            This is the beast I'm dealing with, sj pic: https://www.shopjimmy.com/sony-1-474...-supply-board/
              • 12272
              • U.S.
              #86
              BR is ok, in stby I get 165 on main filter cap, with 3-bl-on, 5-stby and 9 power-on jumped, it's 275, with just 5 and 9 jumped it's the same 275, here's a question, I know the boosted pfc is suppose to be around 400 volts, so I wonder if it's only 275 v. because I have a 450 volt main cap in for testing, where the ones I blew up and took out totaled 1140 v. or if I messed up the pfc when they blew up? or if I have to jumper still some other pin to get the boosted pfc voltage? thanks.
                • 12272
                • U.S.
                #87
                Which part number is the pfc transformer? is it T901? thanks.
                  • 12272
                  • U.S.
                  #88
                  It's a a6069h, I think this is the equivalent: https://datasheetspdf.com/datasheet/STR-A6069H.html
                  Ok, on this IC901 three of the legs read short, beep in diode mode that is, I think only one is suppose to though, trying to figure this out bit by bit, trying to avoid taking the mosfets out of circuit, the designers of this board just HAD to make it as low profile as they could, which means torture for whoever has to deal with those mosfets.
                    • 12272
                    • U.S.
                    #89
                    None of the fets test short from gate to source, in circuit.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      #90
                      Trying to remember I had a problem with a TV, I believe was backlight problem. It had low PFC voltage. It had a string of resistors going to PFC controller which were out of spec. Replacing bad ones brought up voltage to 390 and fixed the problem.
                      Here is thread title. DYNEX DX55L-150A11 Randomly turns off
                        • 12272
                        • U.S.
                        #91
                        Thanks Dskall, that makes perfect sense, I'll try to trace those resistors, I have that one zener diode ZD909 that reads short in circuit but is ok ooc, I'm almost positive that I checked it along with the rest of the 2 legged diodes before the main caps blew up and none read short in circuit.
                          • 12272
                          • U.S.
                          #92
                          A little more on IC901, the BR pin is reading short, it seems wrong??: https://www.semicon.sanken-ele.co.jp...uct=STR-A6069H
                            • 12272
                            • U.S.
                            #93
                            There's a tiny diode D600 on underside of board that reads 99 both ways, seems strange.
                              • 12272
                              • U.S.
                              #94
                              Anyone know what could make the zener 909 read short in circuit but good ooc, I think I can solve this mystery if I can track this short down, pic. in post #85 IC901 tests good I think, 17 v on vcc and I'm getting the 275 same as the main cap on the start pin.
                              • Diah
                                • Feb 2013
                                • 6435
                                Plus when ZD909 is installed it reads short but is ok out of circuit, well .972 one way and 1 the other.
                                not good
                                  • 12272
                                  • U.S.
                                  #96
                                  Ok, thanks, I'm gonna take that pos out and kill it again, LOL.
                                    • 12272
                                    • U.S.
                                    #97
                                    Crap my bad, it reads 848 out of circuit, there's seven more on the board they read 682, 704, 828, 799, 863, 676, 803 in circuit but don't read short on diode test.
                                      • 12272
                                      • U.S.
                                      #98
                                      Clipped diode, still getting short across the contacts.
                                        • 12272
                                        • U.S.
                                        #99
                                        Tiny zener, how do I know what to replace it with, is there some tiny writing on it?
                                        • Diah
                                          • Feb 2013
                                          • 6435
                                          for zener 676 / 704 are acceptable value .. mybe yours DMM drunk !!!
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • iglitare
                                            by iglitare
                                            09-04-2025, 07:13 AM
                                          • Kartowl
                                            philips 47pfl6158k/12 image faded away, sound still coming from TV
                                            by Kartowl
                                            Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                                            04-23-2024, 12:57 AM
