Samsung ue49mu6120
This topic is closed.
  • lotas
    • Jan 2016
    • 4819
    • Russia
    #401
    Originally posted by Jeffaas
    Thanks! The tv works again.
    respect! And many thanks!!!
    Ok!
    • toptib
      • Apr 2012
      • 18
      • ita
      #402
      Samsung UE40MU6400UXZT
      Hello, could you help me with my file please. Thank you.
      • lotas
        • Jan 2016
        • 4819
        • Russia
        #403
        Try.
        • toptib
          • Apr 2012
          • 18
          • ita
          #404
          Originally posted by lotas
          Try.
          Thanks for the quick reply.
          I programmed the IC1604 eprom with the supplied firmware, with the status register byte 0X88 and 0X42.
          Now the standby LED is on, If I try to turn it on the LED will turn off and come back on immediately. The main activates the power supply that supplies the 12 volts for 20 seconds and then returns to 8v and repeats this operation continuously.
          Strangely I find that at the output of the Q211 I find only 1.35 v while in the 2 outputs of Q209 I regularly find 12v.
          No voltage on the L400-UT.
          Unfortunately I can't find the schematic of the main board to investigate any hardwre problems or if it's the firmware still faulty.​
          • lotas
            • Jan 2016
            • 4819
            • Russia
            #405
            Is this dump original, or have you already tried to write something there without keeping it original?
            If the dump is not his native one, then it may turn out the way it is now, and the protection against panel malfunction may work (in this case, you need to disconnect the lvds cable from the motherboard...)
            You won’t find circuit diagrams for modern motherboards; they are not freely available, even in service centers.
            • toptib
              • Apr 2012
              • 18
              • ita
              #406
              You won't find circuit diagrams for modern motherboards; they are not freely available, even in service centers.
              The dump is original, I tried to disconnect the flat lvds but the problem persists​
              • toptib
                • Apr 2012
                • 18
                • ita
                #407
                Hello Lotas, thank you for your availability, unfortunately I don't find any hardware problems on the mainboard, could I try other firmware that you know of or something else ?
                • lotas
                  • Jan 2016
                  • 4819
                  • Russia
                  #408
                  The other one will not suit you, since others will already have different versions of the software, as you programmed your spi flash, you unsoldered it and programmed it through an adapter on a programmer or through a clothespin, you can read the dump again and post it here, I’ll look at it after I signed up data.
                  • toptib
                    • Apr 2012
                    • 18
                    • ita
                    #409
                    I did the dump by unsoldering the eprom and connecting it with adapter to the programmer, I'll send it back if you have time take a look at it. Thank you
                    • toptib
                      • Apr 2012
                      • 18
                      • ita
                      #410
                      Excuse me what I just sent is the original one I read the first time, maybe you meant to re-read what I wrote with what you sent me?
                      • lotas
                        • Jan 2016
                        • 4819
                        • Russia
                        #411
                        Yes.
                        • toptib
                          • Apr 2012
                          • 18
                          • ita
                          #412
                          un attimo
                          • toptib
                            • Apr 2012
                            • 18
                            • ita
                            #413
                            tI've read this now
                            • lotas
                              • Jan 2016
                              • 4819
                              • Russia
                              #414
                              Damaged in the middle of the dump, try again.
                              First, delete all status registers, then completely erase, write down my dump, check, then set the status register (0x88,0x42) and click Write.
                              How do you program, do you unsolder the chip from the board or program via a clothespin?​
                              • toptib
                                • Apr 2012
                                • 18
                                • ita
                                #415
                                I'll try again. I've always unsoldered the eprom, both to read it and to write it.
                                • lotas
                                  • Jan 2016
                                  • 4819
                                  • Russia
                                  #416
                                  When dismantling the flash, the resistors were not damaged or moved, check under a magnifying glass, if this time it does not help, try replacing the flash with a new one.
                                  • toptib
                                    • Apr 2012
                                    • 18
                                    • ita
                                    #417
                                    Nothing to do, always standby LED on and that's it.
                                    I tried several times to delete the eprom, verify it and write your firmware and always checked correctly by the programmer, but I always get the same result.
                                    Thank you for your patience.
                                    I'll see if I can find a used mainboard.​
                                    • lotas
                                      • Jan 2016
                                      • 4819
                                      • Russia
                                      #418
                                      Also check the signal lines on usb and hdmi relative to ground for resistance, it should not be short or low.
                                      • toptib
                                        • Apr 2012
                                        • 18
                                        • ita
                                        #419
                                        Check the data lines without finding any anomalies.
                                        Thank you​
                                        • lotas
                                          • Jan 2016
                                          • 4819
                                          • Russia
                                          #420
                                          Replace the chip (25Q40) with a new one.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
