Samsung ue49mu6120
This topic is closed.
  • mano115
    • Jul 2014
    • 6
    • EEUU
    #321
    Re: Samsung ue49mu6120
    Hi Lotas,
    please fix my dump original tv: not standby led no power
    UN49mu6400FXZX
    bn94-11930C
    bn41-02568A
    • lotas
      • Jan 2016
      • 4598
      • Russia
      #322
      Hi, try.
      • mano115
        • Jul 2014
        • 6
        • EEUU
        #323
        Thanks you Lotas. It's works perfect!
        • lotas
          • Jan 2016
          • 4598
          • Russia
          #324
          Ok!
          • rayden04
            • Feb 2022
            • 3
            • Cuba
            #325
            Hello Lotas, I have a problem with a Samsung un49mu6290fxza television that does not turn on the standby light or anything, I tried some dumps uploaded by you and now it stays on a red standby LED.
            • lotas
              • Jan 2016
              • 4598
              • Russia
              #326
              Post your own faulty dump here, I will fix it.
              • rayden04
                • Feb 2022
                • 3
                • Cuba
                #327
                this is
                • lotas
                  • Jan 2016
                  • 4598
                  • Russia
                  #328
                  this is
                  Try.
                  • rayden04
                    • Feb 2022
                    • 3
                    • Cuba
                    #329
                    Try.
                    Perfect, thanks you
                    • lotas
                      • Jan 2016
                      • 4598
                      • Russia
                      #330
                      Perfect, thanks you
                      Ok!
                      • dani.m
                        • Nov 2023
                        • 12
                        • italy
                        #331
                        Hello, I would like to replace the main of a UE55MU6120KXZT with a MAIN of a UE55MU6199UXZG to have the SAT input as well, is it possible?thanks
                        • dani.m
                          • Nov 2023
                          • 12
                          • italy
                          #332
                          If needed, the panel codes are CY-GM055HGHV3H
                          SK09BN9504562AS004JBX0938 JW48
                          2017.11.29 55S6AUVM
                          I already have the CH341A pen and I have already saved the various files
                          • lotas
                            • Jan 2016
                            • 4598
                            • Russia
                            #333
                            If their panels are different, then you will probably have to transfer dump 25Q80 from the original board to the new one.
                            • dani.m
                              • Nov 2023
                              • 12
                              • italy
                              #334
                              grazie per la risposta,ho provato a farlo ma il Tv si comporta allo stesso modo(schermo a righe)forse non ho fatto la procedura giusta nel modificare SREG oppure neoprogrammer mi da nell'elenco la memoria 25q80BV invece di 25q80DV che ho sulla scheda
                              • dani.m
                                • Nov 2023
                                • 12
                                • italy
                                #335
                                thanks for the answer, I tried to do it but the TV behaves in the same way (lined screen) perhaps I didn't follow the right procedure when modifying SREG or neoprogrammer gives me the 25q80BV memory in the list instead of the 25q80DV that I have on the card
                                • lotas
                                  • Jan 2016
                                  • 4598
                                  • Russia
                                  #336
                                  Try changing the panel model to yours in service mode.
                                  • dani.m
                                    • Nov 2023
                                    • 12
                                    • italy
                                    #337
                                    I can't enter service mode, because the screen is unusable with the UE55MU6199 board
                                    the file in the 25q80DV I should have written it in the right way, the only doubt is the list of chips present in neoprogrammer that gives me available a 25q80"BV"and not DV as in my board
                                    • lotas
                                      • Jan 2016
                                      • 4598
                                      • Russia
                                      #338
                                      Download the AsProgrammer program, your flash is there.
                                      • dani.m
                                        • Nov 2023
                                        • 12
                                        • italy
                                        #339
                                        Excuse my ignorance,but I can't find the "detect" button in asprogrammer
                                        • lotas
                                          • Jan 2016
                                          • 4598
                                          • Russia
                                          #340
                                          “detect” what, where? What are you writing about, what button?
                                          1. - IC.
                                          2. - SPI.
                                          3.- WINBOND.
                                          4. - W25Q80DV.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            09-06-2024, 06:20 PM
