VIZIO D60-F3 Wont Power ON, No Standby, No Picture, No Sound
  • rebelkustoms
    • Sep 2015
    • 150
    Re: VIZIO D60-F3 Wont Power ON, No Standby, No Picture, No Sound
    Damn I cant. I took like 10 pictures of it cant make it out. The poured resin over all the ICs and I think it absorbs some of the printing on there.
    • rebelkustoms
      • Sep 2015
      • 150
      sorry I repeated reply
      • rebelkustoms
        • Sep 2015
        • 150
        Whats the best way to test D201 for a short. Im sorry I dont think I have ever tested one of these. Great time to learn I guess.
        • R_J
          • 9535
          The diode is just two diodes with common anode. just use diode test on the meter. On the top of the board it is marked like a fet but it isn't, so G & S are the anode and the D is the cathode. and it is likely a schottky diode so will read around 0.2xx or 0.3xx
          As for the IC, you can use some alcohol to remove the resin, that sometimes works.
          • rebelkustoms
            • Sep 2015
            • 150
            Yea it is reading .273 both ways
            • R_J
              • 9535
              When you say both ways I suspect you mean both diodes, not the reading across on diode and then reversing the probes.
              You could try replacing C111 and the cap near D3, without the ic's number it's hard to know if the voltages on it are ok. The vcc seems to be ok and the ic should be pulsing the Q1 mosfet which drives the transformer.
              You could check if R13 is ok, it is likely a low ohm resistor, .3Ω ~ 1Ω
              • rebelkustoms
                • Sep 2015
                • 150
                As far as testing that Diode. I am keeping the Black lead on the center pin and testing each other leg. each leg is reading.277 with the black lead on the center.
                R13 is reading .3 I will see if I can get this thick resin off of the IC and try to get a #
                • rebelkustoms
                  • Sep 2015
                  • 150
                  I took out the C111 cap and the other one, put them on my ESR Meter. they are 22uf 50v and they are reading 0.6. SO I assume they are good.
                  • rebelkustoms
                    • Sep 2015
                    • 150
                    I just soldered in the C9 and C111 caps that I took out and tested with the ESR and I plugged in the board without the load to test the pins and the C205 Cap Failed and popped. For what reason I dont know but here is a photo.
                    • R_J
                      • 9535
                      I suspect that C205 was bad, as in shorted and that is what was killing the voltage, If it was caused by anything else I suspect C203 & C204 would also have blown. Remove C205 from the circuit and monitor the +16VS voltage on CN201, I suspect the voltage will now be there. The board will operate without C205 installed for testing
                      The fact the cap blew would suggest there is voltage now getting to it and I bet the power supply is working.
                      • rebelkustoms
                        • Sep 2015
                        • 150
                        Damn, still not getting voltage on any of the pins at CN201 with C205 removed
                          It is strange that you removed and re-installed C9 and C111 which at that point the power supply starts running again but then C205 blew up.
                          • rebelkustoms
                            • Sep 2015
                            • 150
                            Yes I thought the same thing. Was wondering if there was maybe a cold solder joint there and it reconnected when I soldered c9 and c111 back in. But I am not sure why 205 popped. I thought of just recapping all these but not sure if I have another problem or short happening here?
                              • 12156
                              • U.S.
                              #34
                              Probably not but make sure you didn't accidentally put one of the re-soldered caps in backwards.
                              • R_J
                                • 9535
                                Resolder all the connections on that transformer, you don't need to start replacing a bunch of parts for nothing, this circuit needs to function first, It must be close to working if it blew the cap. They don't blow like this unless there is a voltage on them. If you look at the board you will see that all 3 caps are in parallel , so how did just one blow?
                                It could be that C9 & C111 are NFG. and the heat from soldering cause them to work, Replace them or re-heat the two caps with the tip of the soldering iron, then try the power supply again.
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  #36
                                  Check that the white line running along the capacitor has its nearest pin connected to the negative pad "-"
                                  • rebelkustoms
                                    • Sep 2015
                                    • 150
                                    I found the reason the cap blew, dumb mistake on my part, there are 2 different value caps right in that area and when i took them out to test I accidentally swapped spots, so the cap that blew was in the wrong spot and got damaged. My mistake.
                                    I had to order a new cap so I just spent 5 bucks and got new nichion caps for the C9 and C111 spots and ALL the caps down the connector side of the board. With those in and the Transformers resoldered I am still getting 0V on all the pins. No Standby or anything.
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      #38
                                      C205 appears to go to U201 which may have been damaged when the capacitor vented.
                                      Edit
                                      Ignore since it looks like it's the 0V leg that goes to U201.
                                      I would trace the 16V from the connector CN201 back to the rectifying diodes and see if they were damaged.
                                      • R_J
                                        • 9535
                                        The reason C205 blew was because it was in backwards. And there WAS voltage (wrong polarity) across that cap for it to blow up.
                                        • dick_barton
                                          • Aug 2015
                                          • 6642
                                          • Wales
                                          #40
                                          So what is the current state of the power supply after the capacitors being replaced. Are any of the dc output voltages correct?
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • x_orange90_x
                                            Vizio E550i-A0 no power, no standby light
                                            by x_orange90_x
                                            I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                            11-20-2023, 09:49 AM
