Re: VIZIO D60-F3 Wont Power ON, No Standby, No Picture, No Sound
Update on this. I have gotten a new power supply as mentioned earlier and I just received my new main board it was a used model from ebay. I am getting voltages on the power supply and at the main board with the new one plugged in now but this replacement has no ready light no optical light and does nothing. How do I rule out anything else before I contact the seller and tell them I believe I have a dead board?
Originally posted by R_J View PostDid you check shopjimmy, depending on the serial number they might have the set of 3 boards.
Originally posted by budm View PostSo yo are not getting PS-ON when all the boards are connected, correct?
and since you do not get any LED indicator on the front panel of the TV either so there is something going on with the main board. Do you see any red light on the Optical port of the main board?
Originally posted by rebelkustoms View PostPicked up a Power Board for this set. Got it all plugged up and it is still dead/no ready light wont turn on etc. However I DO have voltage at the board if I unplug the main board from the power supply. Here is what I get.
Pins:
Pin 1 - Pin 10 show 0v.
Pin 11 - 16.25v
Pin 12 - 4.3v
Pin 13- 0v PS-ON
Pin 14 - 16v
Pin 15 - 16v
Pins:
Pin 11 - 16.25v
Pin 12 - 4.3v
Pin 13- 0v
Pin 14 - 16v
Pin 15 - 16v
At 20-30 bucks on ebay, certainly worth a shot, for a 60 inch tv.Last edited by nomoresonys; 11-18-2020, 05:25 AM.
Final bump on this before I order a PS.
Just getting back to looking at this one today. Does the presence of voltage at HV pin help in any way here?
Originally posted by budm View PostThat is strange that you do have more than enough VCC (14V, per spec sheet the Vstart is between 13.4 ~ 16.4V) for the IC to run, and once it is running the Vcc is supplied by the Aux winding of the transformer to keep it running.
But I also do not expect HV pin to be 0V since it is fed through resistor network so it should have Voltage at that pin.
Right now the IC is dead bu that VCC of 14V is coming from some where.
Normally at startup the HV provide the Vcc to startup the IC and once it is running the Vcc is provided by the Aux winding. Something is not making sense right now.
I would check the resistors connected to HV pin 1 to see if they are OK or not, also check the resistance between hot side circuit ground and IC pins.
Originally posted by rebelkustoms View PostTested a few times here is what I got.
Originally posted by dick_barton View PostHave you checked the components in the red box
Originally posted by budm View PostTEA18363 spec.
Use negative leg of the main filter cap (450450VDC rated cap) as the ground ref. for the Hot side circuit, then report the VDC reading of each pin of the IC.
Be real careful since you are working in the hot deadly side of the circuit so do not touch anything with your body or your hands, at least plug this power supply board by itself into the GFCI outlet, no need to have any other boards connected to this power supply board, also do not let the meter probe slip on you.
TEA18363 spec.
Be real careful since you are working in the hot deadly side of the circuit so do not touch anything with your body or your hands, at least plug this power supply board by itself into the GFCI outlet, no need to have any other boards connected to this power supply board, also do not let the meter probe slip on you.Attached Files
Datasheet
https://cdn.badcaps-static.com/pdfs/...8c3268d871.pdf
Originally posted by budm View PostD201 still tested OK?
BTW, still no luck trying to read the P/N of the SMPS IC?
I was finally able to melt the glue or resin or whatever off the U1 IC. Here is a pic of the number and I will post a datasheet that I think belongs to it.
Originally posted by budm View PostI am curious, what DCV do you get on c205 if you measure the Voltage right between the two legs of the cap?
