Hi all, got a new set to look at. This one is a Vizio D60-F3 it has no standby light, wont power on and has no pi or sound. I have checked continuity in the fuse. I checked the pinouts to the motherboard several times and I am getting no voltage on any of the pins. Guy who gave it to me told me it was turning on then going off and then it stopped coming on. There are pics of the model and powerboard. Thanks
					VIZIO D60-F3 Wont Power ON, No Standby, No Picture, No Sound
	Tags: None
Re: VIZIO D60-F3 Wont Power ON, No Standby, No Picture, No Sound
Can we see the pictures of the whole backside of the TV showing all the boards so we can see how all the boards are connected together?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Are you getting about 160VDC when measure right between the two legs of main filter cap C2 (no need to turn the TV ON)?Never stop learning
The first thing I would do is remove the power supply from the tv and inspect or resolder the connections on the transformers, they like to develop poor connections and go intermittent.
Also check the solder connections on any of the components mounted to the heat sinks .Last edited by R_J; 10-29-2020, 05:39 PM.Comment
Show us good clear straight shots pictures of the whole bottom side of the power supply board.Never stop learning
You probably already did, maybe check those 2 diodes D102, D106, D103, maybe heat up your electrolytic caps with a hairdryer and see if it wants to start up if it does, you probably have a bad cap or 2 or more, test power cord for continuity. Seems like the caps should be ok tho, they've only been out for 2 years.Last edited by nomoresonys; 10-30-2020, 04:36 AM.Comment
There seems to be a residue of some sort around the large transformer in post #8 poking through the circuit board. Can you see where it has come from?Willing to help but I'm no expert.Comment
The residue just seems to be glue residue that seems to be all over the board. not specific to that area.Comment
checked the diodes, they are all reading within range. just for fun i desoldered that line of caps on the low volt side and tested them with my esr meter and they seem to be ok.You probably already did, maybe check those 2 diodes D102, D106, D103, maybe heat up your electrolytic caps with a hairdryer and see if it wants to start up if it does, you probably have a bad cap or 2 or more, test power cord for continuity. Seems like the caps should be ok tho, they've only been out for 2 years.Comment
I resoldered all 3 transformers, and all the mosfets with heat sinks on the board. still no luck on any of these fixes. i'm getting no stand by light or power to the main set of pins.Comment
Have you checked the 4 diodes under the heatsink. D1, D2, D7 & D8. They appear to supply power to the set along with the bridge rectifier DB1Willing to help but I'm no expert.Comment
You have 170vdc across the main cap, now with negative meter probe on cap negative (M10), Check for voltage on R12, on the end sticking out from under the heatsink. If you have 170vdc on R12, (leave negative probe on M10) check the voltage on D106 cathode (white mark on diode)
Also check the voltage on D3 cathodeLast edited by R_J; 10-31-2020, 09:44 AM.Comment
I have 173V between M10 and R12. M10 to D106 Cathode I get voltage jumping all over, like 3,5,8,9,etc. it never stabilizes.You have 170vdc across the main cap, now with negative meter probe on cap negative (M10), Check for voltage on R12, on the end sticking out from under the heatsink. If you have 170vdc on R12, (leave negative probe on M10) check the voltage on D106 cathode (white mark on diode)
Also check the voltage on D3 cathodeComment
I checked these last night, I didnt take them out of circuit but they all are testing around .5.Comment
Are you getting any voltage on the +16VS on plug CN201? What about the voltage on D3?
Can you read the number on U1?
The voltage on D106 is jumping around because the ic is likely operating in burst mode.Last edited by R_J; 10-31-2020, 02:32 PM.Comment
I am getting jumpy voltage all <1v on bith +16 pins. So No voltage on that.
D3 is 14v
I dont see a U1. is it one of the 3 U2, U102, and U402?Last edited by rebelkustoms; 10-31-2020, 02:44 PM.Comment
			by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
Assuming...7 Photos -
			by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
			Hi All,
Need help.
I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard.... -
			by x_orange90_xI have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
 - Loading...
