TCL 65S517 No Backlight, Picture and Sound OK
  • rebelkustoms
    • Sep 2015
    • 150
    Hi All, I have a TCL 65S517 Roku TV it was brought to me with the following problems. It will turn on, stand by light comes on, tv powers on (sounds and picture are present) but has NO BACKLIGHT.
    I am a novice at this but I am learning a little more each time and I have combed through other threads and solutions and tried to narrow it down. Suspecting a T-Conn board or an LED Strip short, here is what I have done.
    I Power cycled and reset the tv. no change. I opened it up and checked AC power (good) Checked voltage to the main board pins while on.
    Top to bottom on that gray ribbon top right of main board I am getting
    3.26V
    0V
    0V
    0V
    12V
    12V
    12V
    I reseated all the cables and tightened ground screws. I checked some of the pins on the Tconn ribbon cable and I am getting 12v on a few of them but I dont have any reference of what should read what. I checked the onboard fuse right below the ribbon cable on the Tconn and I am getting 12v on both sides of it. I unseated left side ribbon on Tconn and powered on to see if it would make a change in the screen. It did not, nor did the right side.
    I checked the red and white and black and brown cable pins coming from the bottom left PS board (guessing by where they are running these are the LED supply lines) I have 0v on all of those while powered on.
    So that is where I am at I tried to rule out as much as possible before I posted here. Any help is greatly appreciated. Pics will follow.
  • rebelkustoms
    • Sep 2015
    • 150
    Re: TCL 65S517 No Backlight, Picture and Sound OK
    Pics
      There are 14 pins on that red connector,
      Your report on the pins does not help since you do not provide the pin number and also you should look at the bottom side of that power supply board to see if they print the pin names on the bottom side of the board.
      • rebelkustoms
        • Sep 2015
        • 150
        Sorry, I flipped the Main Board when I was first testing to look for pin outs, I hadn't noticed this cord had a double pin set. my mistake. here are voltages and a picture of the bottom of the PS for reference.
        P-Dim=3.26v BL_ON=3.26v
        GND= -34mv P_ON = 2.34v
        NC=0 A_DIM=12mv
        GND=-35mv GND= -35mv
        12V = 12v 12V = 12v
        12V= 12v 12V= 0v
        12V= 12v 3D_En= 0v
        • rebelkustoms
          • Sep 2015
          • 150
          Pics
            Lets see good clear straight shots pictures of the whole bottom side of the power supply board so we can see if the LED connector has pin labels or not.
            • rebelkustoms
              • Sep 2015
              • 150
              Here are the front side and back side photos
              • rebelkustoms
                • Sep 2015
                • 150
                I am not getting any voltage over a few mv on any of the LED backlight plug pins. Same with the LED Backlight plug unplugged. Should I try to test for continuity across the LED strip -/+?
                • Diah
                  • Feb 2013
                  • 6463
                  while the set OFF remove the LED socket from PSU. and measure with Ohm the 2 SMT resistors R581 R580
                    Are you getting about 380 ~ 400 VDC measured between the two legs of the main filter caps CE1, CE2?
                    • rebelkustoms
                      • Sep 2015
                      • 150
                      So I am thinking you mean R681 and R680 (the ones right next to the LED Pinouts) they are both reading 0.1 ohm or 0.2 ohm.
                      • rebelkustoms
                        • Sep 2015
                        • 150
                        HI Budm, I am getting 396 VDC on both of those caps.
                        • budwich
                          • Jul 2015
                          • 3097
                          NC=0 A_DIM=12mv
                          12V = 12v 12V = 12v
                          12V= 12v 12V= 0v
                          12V= 12v 3D_En= 0v
                          you might want to try trace back the one pin that is not showing 12v as that seems rather strange.
                          • rebelkustoms
                            • Sep 2015
                            • 150
                            Here are corrected voltages, I checked again twice, i must have gotten a pin off towards the bottom. That pin did have 12v, also all those 12v are on the same trace.
                            GND= 0v P_ON = 2.34v
                            NC=0 A_DIM=0v
                            GND= -35mv GND= -35mv
                            12V = 12v 12V = 12v
                            12V= 12v 12V= 12v
                            12V= 12v 3D_En= 0v
                              What is the P/N of the LED driver IC U601?
                              Also check that rectangular grey cap C620, it looks like one of the leg did not poke through to the bottoms side of the board.
                              • Dido210
                                • Sep 2020
                                • 9
                                I would first test voltage on the power supply board LED connector pins. disconnect the connection I circled, if you are getting voltage while they are not connected to the board then its going to be bad LED's and would require that you open the display assembly to test. if you don't get any voltage when powering on then the fault is in the Power Supply board.
                                My Company works repairing TCL tv's under warranty so i have gotten lots of experience with these type of issues. my best guess would be that your LED strips are the problem.
                                Best of luck and be careful if you end up opening the screen assembly. the screen is very thin and fragile. especially near the bottom flex cables.
                                • Diah
                                  • Feb 2013
                                  • 6463
                                  yes you are correct R680/R681..
                                  Ov reading at BL socket are 100% open circuit / crack at power boards connection or at printing lines so start with re solder TS3, and also the driver circuit of it at Hot area.
                                  just be sure if you working on Hot area the GND should be taken from same area not from GOLD Area or TV chassis.
                                  • rebelkustoms
                                    • Sep 2015
                                    • 150
                                    Here is what is on the IC from what I can read
                                    OZ9976AGN
                                    CK765K. 1N
                                    1839 A1
                                    Also that was just a bad picture angle on the Capacitor 620, Both legs are through the board and the joints look good.
                                    • rebelkustoms
                                      • Sep 2015
                                      • 150
                                      I am about to resolder TS3, I included a pic there is a resistor on the hot side R649 that has some weird coloring around it. Not sure if it is flux or a light corrosion but it looks odd. Thoughts?
                                      Also when you say resolder the driver circuit what are are we talking about on the hot side?
                                      • Diah
                                        • Feb 2013
                                        • 6463
                                        you can do measure on QW3 /4 if there voltage.. be sure only to use HOT area GND probe
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • JohnML1975
                                          Samsung UA50TU8000W no picture and no sound
                                          by JohnML1975
                                          Hello All
                                          have seen posts on this model in here but my problem sounded different so thought i would create a thread
                                          TV will not turn on
                                          There is no standby light
                                          When I press ON button for remote the red standby light does flash but no picture and no sound
                                          From the back of the TV I can see the red light on the back of the mother board
                                          Holding torch to the screen I cannot see a picture
                                          I removed the back cover
                                          Observing the boards I cannot see any damage
                                          I disconnected the main board from the power supply
                                          the back...
                                          08-30-2025, 09:40 PM
