Samsung UA50TU8000W no picture and no sound
This topic has been answered.
  • JohnML1975
    • Jul 2025
    • 84
    Hello All
    have seen posts on this model in here but my problem sounded different so thought i would create a thread
    TV will not turn on
    There is no standby light
    When I press ON button for remote the red standby light does flash but no picture and no sound
    From the back of the TV I can see the red light on the back of the mother board
    Holding torch to the screen I cannot see a picture
    I removed the back cover
    Observing the boards I cannot see any damage
    I disconnected the main board from the power supply
    the back lights came on and stayed on
    i reconnected the mainboard to the PSU
    the i disconnected the buffer boards from the main board
    so i think the problem is downstream from the main board
    in the buffer boards or in the screen
    i will try to isolate further
    will try to share some photos
  • Answer selected by JohnML1975 at 08-30-2025, 11:27 PM.
    JohnML1975
    • Jul 2025
    • 84
    Hello All
    This one was solved
    Added sticky tape to the buffer board U shaped flex cable.
    Covered about 6 tracks
    TV is now working fine
    Screen looks good
    Cannot see any lines
    Thank you
    • JohnML1975
      • Jul 2025
      • 84
      Added photos
      • JohnML1975
        • Jul 2025
        • 84
        Hello All
        This one was solved
        Screen looks good
        Thank you
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4562
          • Italy - Milan
          Hello, this is my survey...
          1) How do you clean the screen surface?
          2) Do you have often kitchen smells or do you smoke inside house? (this have to do with the tv flat cables, i'm not out of head)
          thanks.
          • JohnML1975
            • Jul 2025
            • 84
            Hello Davi
            Unfortunately I dont know
            I obtained the TV broken from someone I dont know
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
            • dronerat
              Samsung UE48JU6400W - back light on, sound on, sometimes picture.
              by dronerat
              Hi Guys,
              This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
              PSU: L48S6 FHS BN44-00807D
              T-Con: BN95-01937A
              Panel: CY-GJ048HGLVLH
              MB: NA (Currently as the TV is assembled and forgot to take picture)
              As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
              It was sent to an authorized service for repairs and returned with the...
              05-15-2020, 08:03 AM
            • marekk
              Samsung QE55Q67RAT no sound and bad picture when streaming
              by marekk
              I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
              I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
              Mainboard is based on pcb BN41-02695A BN94-14007B
              I will appreciate any help
              Many thanks
              Marek...
              05-29-2025, 02:23 AM
            • kca
              Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
              by kca
              Hello all ~
              I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
              This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
              No picture. No sound.
              I tested all the voltages coming out of the power supply...
              10-12-2023, 05:23 PM
