Shifted Screen
  • Phillydubv35
    • Apr 2020
    • 8
    Shifted Screen
    Hello, I have just replaced the LED strips in my Sharp LC-50LB481U. However, the menu/picture is now completely shifted on the screen. Any suggestions?
    Re: Shifted Screen
    What do mean by 'shifted'? Show us the pictures.
    • Phillydubv35
      • Apr 2020
      • 8
      Re: Shifted Screen
      The screen shifted to the right and down and now has lines. Once I started to put it back together, is when the picture screwed up. I had a perfect picture once I switched out the lights and screened it up to see what it looked like. However, after putting it back together is when I turned it on to see the screen. The more I mess with it now, the more the picture becomes distorted.
      • Phillydubv35
        • Apr 2020
        • 8
        Re: Shifted Screen
        Additional pics
        • R_J
          • 9535
          Re: Shifted Screen
          The picture is not shifted, you damaged the lcd screen, top left corner and likely elsewhere
          • CapLeaker
            Leaking Member
            • 8126
            Re: Shifted Screen
            Yep, I agree with RJ. That does suck though, breaking it while putting it back together.
            • Phillydubv35
              • Apr 2020
              • 8
              Re: Shifted Screen
              Really? The screen looks fine though, I see no evidence of damage.
                • 12128
                • U.S.
                Re: Shifted Screen
                Take it back down so you can see the whole screen and look it over real closely, flashlight laser light magnifying glass or glasses etc. it IS very easy to damage the screen or tabs on re-assembly, anyone who's never broke one is VERY lucky.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4303
                  • Italy - Milan
                  Re: Shifted Screen
                  But what flashlight...??
                  THE SCREEN I BROKEN IN PIECES!! I BET MY ENTIRE BANK ACCOUNT..
                    • 12128
                    • U.S.
                    Re: Shifted Screen
                    If it was broken in pieces the OP would know it, DON'T YOU THINK???...THEN THERE GOES YOUR WHOLE BANK WAD.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4303
                      • Italy - Milan
                      Re: Shifted Screen
                      Whatch the number of posts: 8... this is the anwser...
                        • 12128
                        • U.S.
                        Re: Shifted Screen
                        NOT doubting it's broken, just not in a million pieces.
                        • budwich
                          • Jul 2015
                          • 3097
                          Re: Shifted Screen
                          what do you mean "mess with it" ... what are you messing with? Good chance that if you put on your glasses and check the seating of the ribbon cables at the tcon and panel, you may find the problem. Also ensure no frame members are touching any of the boards in the "wrong places"... also the right length of screw was put back in the right place. Check around the left bottom corner area.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4303
                            • Italy - Milan
                            Re: Shifted Screen
                            "Lesson 1: how to prolong an agony.."
                            no way..
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • arbitarytwist
                              Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                              by arbitarytwist
                              Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                              Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                              03-01-2025, 01:16 PM
                            • nasdaa
                              Packard Bell Kayfo, no picture on screen.
                              by nasdaa
                              Hello, I need your help for a failure on a laptop:
                              It's a Packard Bell Kayf0, motherboard LA-5021P, Rev 1.0 with graphic issue.
                              I received this pc because it was turning on but not displaying anything, the fans are running normally and all chipsets heat up on startup but no picture on screen, no backlight either. I noticed that ENAVDD and ENVDD are not present and that there is no LCDVDD on the connector. I didn't check the screen because, maybe I'm wrong, but if there aren't these signals, even if the screen is good, it can't display anything? I tried heating the...
                              06-20-2023, 01:27 AM
                            • burbutsalos
                              LG 55sk8000 plb ..snow in the middle of screen but can see that picture exists there
                              by burbutsalos
                              Hello everyone.
                              I have this TV set which has this issue. It shows a vertical bar im the middle of the screen.
                              The panel has 12 cofs and the problem seems to be on the territory of the first cof on the right side.
                              The tv fires up and you can see a good picture exept that vertical part where multicoloured pixels exist.
                              The strange thing there is that you can see behind that snow that it shows picture but as if there are these pixels in front so you cannot see clearly.
                              The effect is there even on a completely black screen.
                              The screen...
                              10-21-2023, 02:57 AM
