Packard Bell Kayfo, no picture on screen.
  • nasdaa
    • May 2023
    • 6
    • France
    Hello, I need your help for a failure on a laptop:
    It's a Packard Bell Kayf0, motherboard LA-5021P, Rev 1.0 with graphic issue.
    I received this pc because it was turning on but not displaying anything, the fans are running normally and all chipsets heat up on startup but no picture on screen, no backlight either. I noticed that ENAVDD and ENVDD are not present and that there is no LCDVDD on the connector. I didn't check the screen because, maybe I'm wrong, but if there aren't these signals, even if the screen is good, it can't display anything? I tried heating the gpu for 1min30 with the hot air gun but still nothing, apart from an increase in total current from 800 mA to 1 A, the GPU coil shows 5 ohms at ground. Tell me if it's useless, but I removed the R283 to measure the signal sent by the GPU before the jumper and it's still 0v on both sides, does this mean that neither the GPU nor the screen wants to activate the screen? Also, can the GPU chipset get hot even if it's defective?
    Thanks for your answers.
    Schematic: https://www.badcaps.net/forum/showth...61#post1248261
    Last edited by Vesko356; 06-20-2023, 01:56 AM. Reason: Attached schematic removed and replaced with link.
  • nasdaa
    • May 2023
    • 6
    • France
    Re: Packard Bell Kayfo, no picture on screen.
    Any ideas ?
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      Are you certain the board is posted, does capslock react or can you do ctr alt del and laptop reboots?
      • nasdaa
        • May 2023
        • 6
        • France
        I managed to burn an ic by trying to power the screen, and i've spend too much time on this board so i give up but thank you for your time ! Also, does the capslock reacting necessary means that the board is posted ?
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          Yes then you know if the board is posted and fullfill all recomdations to post.
          Which ic blew up?
          • nasdaa
            • May 2023
            • 6
            • France
            Oh ok now its clearer. When i plug the charger there is an additonnal 500mA consumption and the Clock Generator (U3) is getting very hot so i think it's shorted, but i can't find the datasheet online so that's it. Have a nice day.
            • mon2
              • 14756
              Just found this amazing item on AliExpress. Check it out! US $2.16 | 1pcs/lot New SLG8SP553V QFN
              https://a.aliexpress.com/_mqMP2ZW
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • maxlove70
                Need Bios Packard Bell iSTART 2356
                by maxlove70
                Hello, I'm searching Bios for Packard Bell iSTART 2356.
                Asus for Packard Bell M2NS-NVM (Boston) 0206 BIOS - 6A69NA01
                Manufacturer and model: Asus for Packard Bell M2NS-NVM (Boston)
                Chipset: AMD 1100
                Part number: 6A69NA01
                BIOS ID: 03/05/2007-NF-MCP61-M2NS-NVM-00
                BIOS Release date: 2007-03-05
                BIOS Revision: 0206
                Packard Bell Support for this PC is discontinued.
                Please Help Me !!!!
                Thanks.
                02-16-2023, 11:52 AM
              • arbitarytwist
                Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                by arbitarytwist
                Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                03-01-2025, 01:16 PM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
