Vizio P502UI-B1E No Picture Flashing Standby Light
  • R_J
    • 9535
    Re: Vizio P502UI-B1E No Picture Flashing Standby Light
    If you get a change on PS_ON when you push the power button would suggest the main is at least partly working, and the micro understands the power command and changes the PS_ON pin.
    Also note that the plugs CN9101/3 has two rows of pins (14 pins), and CN9101 has 16 pins .
    Do you get +24 volts when the power button is pressed?
    • JDMRpr78
      • Feb 2018
      • 31
      I do not have a cn9101/3 connector on the power board. I do have cn9201/cn9203 that has 14 pins. (1st pic below)
      Cn9101/cn9102 has 16 pins and has PS_ON and when the set is powered on it has 2.87V. Standing by it gets 80.8mV until power button is pressed when it gets 2.87V.
      • R_J
        • 9535
        I ment cn9101/cn9102. I will just refer to the function and not the plug
        So the PS_ON is the white wire? and it changes from .80 (stby) to 2.87 (ON) correct?
        When the power supply is tured ON do you get 24 volts?
        If you don't get 24 volts, check the voltage on optocoupler ic9103, pin 1 (pin2 should be ground) and see if it changes when the power button is pressed?
        • Kickinwing
          • Apr 2019
          @R_J , Do you have schematics available for these boards?
          • JDMRpr78
            • Feb 2018
            • 31
            Thank you again for the help, greatly appreciated.
            Yes PS_ON is a white wire and yes those readings are correct.
            On c9201/c9203 on the 24V pins they all do get 24V when power is on to the power supply.
            Ok so on pin 1 of ic9103 when set is turned off I get 250mV and when turned on I get 1.13V. That is all.
            • JDMRpr78
              • Feb 2018
              • 31
              So does this sound like a faulty main or power board?
              • R_J
                • 9535
                If the power button controls the PS_ON pin, I would say the microprocessor/eeprom seems to be ok, When the PS_ON goes high it turns on the +24 volts on the power supply, so I would say the power supply is ok.
                Are you sure you don't have audio from any sources? Try connecting an hdmi source as it can usually tell the tv to switch to the correct source.
                When you power on the tv are you sure you don't get a flash of the backlights?
                  https://www.badcaps.net/forum/attach...3&d=1556588282
                  So what Voltage do you have on the ON/OFF (BL-ON) pin, and DIM pin when TV is turned on?
                  Do you also have 12V on the SMD fuse of the T-CON board when TV is turned on?
                  • R_J
                    • 9535
                    I don't think the BL_ON and DIM are used on the power supply, I suspect the main controls the led driver board directly, I don't think his model has wires going to those pins on the power supply
                    I think the BL_ON control is on the main, CN701 pin 14, BL_PWM is pin 13, but they are likely not used either, I believe the main talks to the led driver via CN805.
                      https://www.badcaps.net/forum/attach...8&d=1556390413
                      OK, with better picture now I can see that there are now wires for the ON/OFF and DIM pin.
                      OP: "have confirmed the set is not running and there is no picture on the screen when using a flashlight so definitely not the backlights."
                      So right now he does not have backlights, correct? I wonder why OP indicated that "definitely not the backlights".
                      The MCU should also send the signal to turn on the MOSFET on the main board to supply the switched 12V to the T-CON board.
                      • JDMRpr78
                        • Feb 2018
                        • 31
                        IndicAted this because I've seen many posts leaning towards backlight/eeprom issues and I just wanted to let everyone helping know that i did check for an image with a flashlight and there is not one.
                        I am at work now and will check the inputs tonight when I get home.
                          • 12092
                          • U.S.
                          #32
                          We have learned that it CAN be a backlight issue, EVEN if there is no display on screen wih flashlight, was reminded of this just the other day in a thread here with a successful fix.
                            • 12092
                            • U.S.
                            #33
                            Not saying it is a backlight problem, just saying at least on some tvs it can't be ruled out just cuz theres no image. https://www.badcaps.net/forum/showthread.php?t=67154
                            • JDMRpr78
                              • Feb 2018
                              • 31
                              Ok so I currently have a amazon fire stick connected and turning the tv on with remote or power button doesn’t change a thing. I have tried all hdmi inputs and nothing on the screen at all. I’m using a flashlight again during power on cycle and I do not get any images on the screen. The status light comes on and fades away. EDIT: and no flashes from backlight at all, red light comes on in the optical port.
                              On cn701 pin 13/14 are both empty cavities on the main board connector.
                              • R_J
                                • 9535
                                You could check CN805 pin 8 on the led driver board and see if you get 5 volts when the tv is turned on
                                Check the voltage on R8220 (0Ω) next to cn805
                                CN806 1,2,3,4 should be +V(from power supply) 5,6,7,8 are ground
                                You can also check the main board cn206 pin 44-51 for panel power (12v)
                                • JDMRpr78
                                  • Feb 2018
                                  • 31
                                  Ok I get 5 volts on cn805, r8220.
                                  Cn806 1-4 I get 24 V
                                  I'll check cn206 later I quickly ran my lead over the contacts on the board and never saw 12 volts. May have been going to quickly to leave for work tonoutrun a storm.
                                  Thank you again
                                  • JDMRpr78
                                    • Feb 2018
                                    • 31
                                    Cn206 has such small pins I could only run my positive lead across them and I never saw over 1.5V as the highest reading. I would assume if it is supposed to have 12v something is definitely wrong with my main board?
                                    • x_orange90_x
                                      Vizio E550i-A0 no power, no standby light
                                      by x_orange90_x
                                      I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                      11-20-2023, 09:49 AM
                                    • 7ony
                                      Samsung plasma - flashing standby light
                                      by 7ony
                                      The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                                      Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                                      Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                                      No visible...
                                      08-31-2020, 05:18 PM
                                    • p-top
                                      Vizio, E60u-D3, no standby light, no ps_on
                                      by p-top
                                      Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                                      main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                                      PS voltages
                                      1 VSNS -2mV
                                      2-5 LED-OUT -2mV
                                      6-10 GND -2mV
                                      11 +16VS 16.29V
                                      12 AC-DET 3.929V
                                      13PS-ON -3mV
                                      14 +16VS 16.29V
                                      15 +16VS 16.29V...
                                      11-27-2023, 10:44 AM
                                    • Bloopeta
                                      Samsung UE43KU6400U Flashing Red Standby Light
                                      by Bloopeta
                                      Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                                      Power button does nothing
                                      Have unplugged the mainboard, and backlights illuminate.
                                      Have tried removing panel ribbon cables one at a time, and that makes no change.
                                      With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                                      Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                                      09-11-2023, 02:34 AM
                                    • fuxxy
                                      Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
                                      by fuxxy
                                      This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
                                      Plug the set in, and it will turn on and functions with no issues.
                                      After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
                                      Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
                                      08-02-2022, 09:44 AM
