Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
  • fuxxy
    • 318
    This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
    Plug the set in, and it will turn on and functions with no issues.
    After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
    Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes to turn off gets shorter for each cycle.
    I purchased a LED strip tester, and both strips show the same voltage - 162V. I'm assuming the LED strips are not the culprit this time because the voltage displayed on both strips are identical.
    I've unplugged the jumper from the PSU to the mainboard and the backlights DO turn on.
  • nomoresonys
    • 12086
    • U.S.
    Re: Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
    how bout some clear straight on pictures of each board and one of the whole back, as to see how everything is connected.
    • nomoresonys
      • 12086
      • U.S.
      check the little fuse on the tcon board by the connector, see if you have about 12 steady volts on each side, neg. probe on metal chassis ground, pos. probe on each side, want to see if it's getting there with no problems.
      • nomoresonys
        • 12086
        • U.S.
        next time it goes off, try wiggling the cable from powerboard to mainboard, inspect that cable for any burn marks, can do a continuity test for each wire also, just be careful not to get the connections out of shape from pushing the probes in, I use stripped bread ties if needed.
        • fuxxy
          • 318
          Thanks for the suggestions, I'll definately take that into account.
          I'll take some high-res photos of the boards as I can take them off.
          The unit has been unplugged for a month now, I'm currently performing a burn-in as it has not shown any issues since I plugged it in earlier today.
          • nomoresonys
            • 12086
            • U.S.
            BE VERY CAREFUL what you touch with your hands, the hot/primary side of powerboard and inverter board next to it have high voltages that can easily kill.
            • 7ony
              Samsung plasma - flashing standby light
              by 7ony
              The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
              Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
              Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
              No visible...
              08-31-2020, 05:18 PM
            • Bloopeta
              Samsung UE43KU6400U Flashing Red Standby Light
              by Bloopeta
              Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
              Power button does nothing
              Have unplugged the mainboard, and backlights illuminate.
              Have tried removing panel ribbon cables one at a time, and that makes no change.
              With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
              Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
              09-11-2023, 02:34 AM
            • ChristianBr01
              LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
              by ChristianBr01
              I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
              The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
              What I already found is that the 12.8V are not an the connector to the main board connector to the power...
              04-23-2025, 01:48 AM
            • esqmooo
              HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
              by esqmooo
              Hello everyone.
              This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
              Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
              Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
              I tried long pressing on the power button, after several seconds it would go off then when the button is released...
              03-11-2025, 03:57 PM
            • AleMonti
              LG 55EG910V - no power and no standby light
              by AleMonti
              I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
              I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
              The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
              After checking the basics I did the following:
              • I measured all voltages and as expected the only active supply is the 3.5V standby. It
              11-04-2024, 05:02 PM
