Vizio e322vl wont turn on
  • lucas0113
    • Feb 2018
    • 12
    Hello all, I have recently purchased a non-working Vizio E322VL in hopes of getting it to work, and just something to waste time on. But the problems it's been having are really puzzling me. It has a solid orange Vizio logo (doesn't even flash like on most vizio tv's.) And when you press the power button, it doesn't respond in any way. [Even stays orange.] I've taken off the back and looked for any puffed capacitors, but none are visible. I've even shorted the power button pins, thinking maybe that was the problem, to no success.
    I'm quite a novice, but I can solder anything as long as it's not surface-mount.
    Note: I've already tried reseating connectors/cables, and I do not yet own a multimeter to test voltages, but I may be able to borrow one next week :/ And I also really don't feel like paying $50 for a new motherboard.
    Any help would be appreciated.
    Re: Vizio e322vl wont turn on
    http://www.shopjimmy.com/catalogsear...q=Vizio+e322vl
    It may be EEPROM problem but we should at least see the DC Voltage readings on the connector of the power supply board that goes to the main board first to see waht condition they are in.
    You need to the report the readings in this format: Pin name follows by Voltage reading when TV is OFF, and when Power switch is activated
    Example:
    Pin name (I.E. 5V), TV OFF = xxV, TV ON = xx V
    BTW: Upload good clear pictures of the whole backside of the TV showing all the boards will help too.
      • 12306
      • U.S.
      The cheap meters are ok, menards has m for 10 bucks or so.
      • lucas0113
        • Feb 2018
        • 12
        Really? I didn't know you could get them so cheap. And sorry for the [very] late reply, pics will be up soon.
        • lucas0113
          • Feb 2018
          • 12
          Again, sorry for late reply. Here are the images:
          (sorry for the quality)
          • lucas0113
            • Feb 2018
            • 12
            I'm not even sure which pins are which, because they're not really labeled.
              0500-0407-1070 Looks to be your board.
              http://www.shopjimmy.com/vizio-jvc-0...upply-unit.htm
              Connector CN201 has label for each pin.
              Black probe of the meter on the chassis.
              • lucas0113
                • Feb 2018
                • 12
                Finally got my hands on a multimeter. Here are the voltages:
                I checked all the voltages (especially the 0's) a few times to ensure accuracy.
                Shouldn't there be 12v somewhere??
                cn201-1: 5.4v
                cn201-2: 5.4v
                cn201-3: 5.4V
                cn201-4: 0V
                cn201-5: 0v
                cn201-6: 0v
                cn201-7: 0v
                cn201-8: 0v
                cn201-9: 0v
                cn201-10: 0v
                cn201-11: 0v
                cn201-12: 0v
                cn201-13: 0v
                cn201-14: 0v
                • lucas0113
                  • Feb 2018
                  • 12
                  Forgot to mention, there is no change after pressing the power button.
                    Please edit your reading by putting down the pin name for all those pins so I can easily see what they should be.
                    • lucas0113
                      • Feb 2018
                      • 12
                      Pin name? I put what they were labeled from the board.
                      It even says cn201-11 is pson, and so on
                      • lucas0113
                        • Feb 2018
                        • 12
                        8,9, and 10 are supposed to be 12v
                        • lucas0113
                          • Feb 2018
                          • 12
                          And 1,2,3 is supposed to be 5v.
                          • maxvalutech
                            • 804
                            • australia
                            I'd really like to know if these sets,with logo etc first then a blank screen wait until they really start, use a separate memory chip for that logo bit with eeprom kicking in after. Here we have the inverter working with stalled logo showing but PSU not fully turned on probably due main board signal not yet activated because of bad eeprom. Probably the shopjimmy pair would be the fix but much care needed in removal and replacement soldering.
                            • maxvalutech
                              • 804
                              • australia
                              That is a the info budm seeking. The pins should be marked or have a legend nearby or sometimes under the board.
                              • lucas0113
                                • Feb 2018
                                • 12
                                Well here, this image should do.
                                • lucas0113
                                  • Feb 2018
                                  • 12
                                  Wouldn't I need a heat gun to remove something like that?
                                  • will62
                                    • Dec 2016
                                    • 229
                                    • usa
                                    I think he meant to add the pin name to list. Here you go:
                                    1. 5.2vsb : 5.4v
                                    2. 5.2vsb : 5.4v
                                    3. 5.2vsb : 5.4V
                                    4. gnd : 0V
                                    5. gnd : 0v
                                    6. gnd : 0v
                                    7. gnd : 0v
                                    8. 12v : 0v
                                    9. 12v : 0v
                                    10. 12v : 0v
                                    11. pson : 0v
                                    12. i-on/off: 0v
                                    13. lamp : 0v
                                    14. dim : 0v
                                    Edit:
                                    Turn unit off (unplug), put probe on lamp(#13), power on, press on button. Did lamp ever change?
                                    Do same for pson.
                                      I ask to put down the pin name on your reading so I do not have to look back and forth between the pictures and your report.
                                      • maxvalutech
                                        • 804
                                        • australia
                                        Can be done OK with soldering iron but best to watch some videos first - basically add a bit of solder to legs first then melt solder and gently prise up legs one side then work on the other side - must avoid damage to board tracks/attachment points.
                                        • Mulp
                                          VIZIO M65-C1 Does Not Turn On
                                          by Mulp
                                          Hi All,
                                          I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                                          When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                                          I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                                          01-13-2024, 09:57 PM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                        • masoksian
                                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                          by masoksian
                                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                          The system does not turn on, there is no post.
                                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                          The problem continues in the same way.
                                          I tried to turn on the Fn key, nothing came to the screen....
                                          02-15-2025, 12:08 PM
