Vizio e322vl wont turn on
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Re: Vizio e322vl wont turn on
    hi has anyone foubnd out issue for this tv..i have same issue ..the vizio logo is orange but nothng happens when power switch turned on,,,logo stays orange
    tv will not power on
    i have same voltages as original post..i did some research seems the mainboard for this tv is very costly (due to common problenms) so that tells me the issue is more than likely a main issue and not a ps issue....
    1. 5.2vsb : 5.4v
    2. 5.2vsb : 5.4v
    3. 5.2vsb : 5.4V
    4. gnd : 0V
    5. gnd : 0v
    6. gnd : 0v
    7. gnd : 0v
    8. 12v : 0v
    9. 12v : 0v
    10. 12v : 0v
    11. pson : 0v
    12. i-on/off: 0v
    13. lamp : 0v
    14. dim : 0v
    • nomoresonys
      • 12123
      • U.S.
      Could try freezing the eeprom with freeze spray or inverted can of duster then see if tv starts. Can also try heating eeprom and mainboard with hairdryer, heat the capacitors too, might get lucky and be able to narrow down the problem area.
      • shelby5041
        • Feb 2009
        • 1505
        thanks..is that a common part failure on this model tv? i does seem shop jimmy sells the eeprom so that tells me it may be a common issue
        • shelby5041
          • Feb 2009
          • 1505
          per shop jimmy
          IMPORTANT:
          These main boards can have multiple failures, in addition to the EEPROM.
          If EEPROM replacement does not repair your board, there are likely additional problems.
          Symptoms EEPROM replacement CAN fix:
          - Display is frozen on VIZIO logo screen*
          - TV won't power on with remote/buttons when plugged-in (VIZIO is lit in orange, but won't turn to white)
          - TV turns on when first plugged-in, but it won't turn back on after 30 minutes of being off
          - TV shuts off and goes back to standby mode (orange VIZIO lit) after you turn it on
          Symptoms EEPROM replacement CAN NOT Fix:
          - TV turns on but has NO backlight
          - TV turns on AND backlights are on, but has no video display at all
          - HDMI issues
          - Audio issues
          • nomoresonys
            • 12123
            • U.S.
            I always figure 15 bucks is cheaper than 50 but like they say could be other or additional problems, having said that, many times it IS just the eeprom. I would probably be willing to throw 15 bucks at it but not much more, since new tvs are getting so cheap in price.
            • shelby5041
              • Feb 2009
              • 1505
              #26
              you are right..i can get the part for $10 shipped free on ebay....tvs nowadays are worthless..i wont spend more than $25 to fix any tv today...if it costs more i trash the tv..this tv even fixed and working is only worth about $50 max.....more likely about $25...so no reason to spend much money....how can tv repair places stay in business..noone fixes tvs anymore due to they are considered disposable items now
              and no wayy in hell would i spend $50 to buy a new main board..thats just stupid since the tv is worth less than $50 anyways...5-10 years ago i would have done it but not today...
              • nomoresonys
                • 12123
                • U.S.
                #27
                Totally agree, it makes me wonder if it's an industry wide conspiracy to make them last just past a one or two year warranty then go kaput, seems like the led backlights are always overdriven. They burn out and naturally that's one of the biggest jobs to do, they think people will just keep buying their tvs. Yes they try to cut the tv repairman out of the picture so now the tv makers get all the profit and just keep on selling their junk/poorly designed to fail tvs. I much prefer the ccfl tube technology, have a 32 sharp aquos from 2007, used as monitor for 16+ hours a day, never given us a second of trouble, I just blow out the dust every couple of months.
                • shelby5041
                  • Feb 2009
                  • 1505
                  #28
                  Yes the led backlght technolgy is a failed design...and a pain in the ass to fix...inhave cracked many panels trying to change leds
                  • shelby5041
                    • Feb 2009
                    • 1505
                    #29
                    Yes the ccfl backlght lcd tvs are much more reliable ...for sure....ive never seen ccfl go bad..but have seen many many leds fail...and whats worse is anothervfailed design....1 led goes bad out of 100 and all wont power on...pretty,sad design
                    • ecking767
                      • Oct 2009
                      • 492
                      this main board my need the CPU to be reball, try heating up the metal shield for about 2 to 3 minutes.Before power on the power LED should flash amber & white. its a smart TV similar to the M550NV, M470NV and XVT553SV. These model all fail because of the CPU need to be reball.
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #31
                        Hi sony
                        I doubt its ps capacitor issue...they visually look fine and vizio is known for crazy funky mainboard issues...the problem with todays electronics is they are too fancy and complicated with features that are failure prone....and like you said designed to fail....its a built in profit maker by companies so that you buy a new tv every 2-5 yrs instead of every 25yrs which was the case with crt tvs...imo there should be regulations on how long items are designed to last and built to last so that we can help,reduce landfill issues.
                        • nomoresonys
                          • 12123
                          • U.S.
                          #32
                          For sure, pure greed by the tv makers, if this keeps up we will all be aholes to elbows packed in huge urban areas because all the other space will be effing STINKING landfills.
                          • nomoresonys
                            • 12123
                            • U.S.
                            #33
                            I'm thinking bga or eeprom too.
                            • Mulp
                              VIZIO M65-C1 Does Not Turn On
                              by Mulp
                              Hi All,
                              I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                              When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                              I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                              01-13-2024, 09:57 PM
                            • pajdek
                              Lenovo Y700-17ISK turn on and off
                              by pajdek
                              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                              09-20-2023, 02:49 AM
                            • RdeveLabs
                              MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                              by RdeveLabs
                              To all the members here...
                              Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                              So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                              05-05-2025, 04:59 AM
                            • SS454
                              vizio e650i-a2 backlight flashes then turns off
                              by SS454
                              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                              panel: au optronics T650HVN05.4
                              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                              https://www.shopjimmy.com/vizio-56-0...-power-supply/
                              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                              08-20-2020, 03:57 PM
                            • robante15
                              Acer Aspire 4520 won't turn on after reboot
                              by robante15
                              Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                              It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                              The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                              If I remove the...
                              04-06-2024, 06:50 PM
