VIZIO M65-C1 Does Not Turn On
  • Mulp
    • Jan 2024
    Hi All,
    I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
    When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
    I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here. My +24V also shows up as 16.25V. Hoping someone can point me in the right direction. Would love to replace some broken capacitors or diodes but if entire board needs replacing that is good to know as well!
    I am including the measurements with the TV OFF (plugged in) then ON
    CN9101 --------------- OFF ; ON
    PIN 1 - +5V/+3.5V ---- 0V ; 3.47V
    PIN 3 - +12V ------- 13.5V ; 12.87V
    PIN 5 - +12V ------- 13.5V ; 12.86V
    PIN 7 - +12V_A -- 13.51V ; 12.87 V
    PIN 9 - GND ------------ 0V ; 0V
    PIN 11 - GND ----------- 0V ; 0V
    PIN 13 - PS_ON ------- 0V ; 2.49V
    PIN 15 - DIM ------------ 0V ; 2.49V
    CN9102 ---------------- OFF ; ON
    PIN 2 - +5V/+3.5V ----- 0V ; 3.48V
    PIN 4 - +12V ------ 13.51V ; 12.89V
    PIN 6 - +12V ------ 13.51V ; 12.88V
    PIN 8 - +12V_A ---- 13.5V ; 12.89V
    PIN 10 - GND ---------- 0V ; 0V
    PIN 12 - GND ---------- 0V ; 0V
    PIN 14 - PS_ON ------ 0V ; 0V
    PIN 16 - DIM ----------- 0V ; 0.04V
    CN9201 -------------- OFF ; ON
    PIN 1 - ON/OFF ------ 0V ; (NO WIRE)
    PIN 3 - 3D -------------- 0V ; (NO WIRE)
    PIN 5 - GND ----------- 0V ; 0V
    PIN 7 - GND ----------- 0V ; 0V
    PIN 9 - GND ----------- 0V ; (NO WIRE)
    PIN 11 - 3D ------------ 0V ; 16.25V
    PIN 13 - ON/OFF ---- 0V ; 16.26V
    CN9203 -------------- OFF ; ON
    PIN 2 - DIM ------------ 0V ; (NO WIRE)
    PIN 4 - +12V ----- 13.51V ; (NO WIRE)
    PIN 6 - GND ----------- 0V ; 0V
    PIN 8 - GND ----------- 0V ; 0V
    PIN 10 - +24V --------- 0V ; (NO WIRE)
    PIN 12 - +24V --------- 0V ; 16.26V
    PIN 14 - +24V --------- 0V ; 16.27V
  • Storyteller12
    • Jun 2020
    • 625
    These TVs have issues with the main board. Specifically the BGA chips under the large heatsink.
    they get to hot and the solder balls expand and short out
    • diif
      • Feb 2014
      • 6978
      • England
      Yes, it's likely to be a BGA issue but the balls do not expand and short out. The solder joints crack due to expansion and contraction from it's heating/cooling cycle and the the lack of lead in the balls.
      • Storyteller12
        • Jun 2020
        • 625
        They expand as well because there to hot. They crack when cooling after being on and hot for a while. But they short out because they expand. If they just cracked there wouldn’t be shorted. It just wouldn’t make connection.
        • diif
          • Feb 2014
          • 6978
          • England
          No, there is no shorting out due to expansion, the expansion is minimal, it's cracking causing no or intermittent connection.
          if there is any shorting it is due to tin whiskers, which i have encountered once on a PS4.
          • Storyteller12
            • Jun 2020
            • 625
            Not trying to argue as I’m here to learn. But they do short out. Nicks TVs did a video where he shows its shorted on the caps next to the BGA chips. After reflowing them the short is gone and the tv works again.
            • Mulp
              • Jan 2024
              Just a quick update.
              Given the replies I felt like the issue is probably the main board.
              I thought I would just try baking the mainboard before purchasing a replacement online so I removed the mainboard, covered everything apart from the bga chips on top and bottom of board with two pieces of cardboard and baked in oven. I used a thermometer to try and keep the heat to ~350 for 8 minutes. Hit a high of 370. Surprisingly that seemed to have done the trick. I heard this is still a temporary fix so I've kicked the can down the road for another couple months it seems.
              Thanks for all the help everyone!
              • nomoresonys
                • 12276
                • U.S.
                If you can get a fan blowing on your bga it will last a lot longer.
                • Mulp
                  • Jan 2024
                  thanks a bunch, that’s super helpful!
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    07-14-2025, 07:28 PM
                  • wnlewis
                    New wire for my RDE3340 Whirlpool electric range
                    by wnlewis
                    OK. I got the rocker switch figured out thanks to the good advice on this forum.
                    Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                    This is a Whirlpool RDE3340 electric range.
                    The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                    Where may I find parts...
                    01-08-2025, 11:21 PM
                  • emeskay
                    Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                    by emeskay
                    We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                    08-06-2024, 07:13 AM
                  • howardc64
                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                    by howardc64
                    Failure Symptom
                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                    Where is the short?
                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                    05-27-2025, 02:56 PM
