70in Vizio m70-c3 replaced led's now picture screwed up.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: 70in Vizio m70-c3 replaced led's now picture screwed up.
    Originally posted by sawilson
    Yeah, there's still some shadowing there. I honestly think the suction cups were the problem. Which pisses me off. I will not use them on a panel again.
    Ok well this blows my theory on VCOM low voltage to the panel.
    • mmartell
      • Oct 2013
      • 3189
      Originally posted by budwich
      you never really answered the question as to whether the suction cups had "valving" for releasing air / vacuum? Also, how did you actually apply them... blaming them for this might not solve any future issue if it was "operator error", regardless of what cup system you used.
      He showed a pic of the ones he used in post 59 in case you missed it - not sure if you can see in the pic what your looking for or not...
      • budwich
        • Jul 2015
        • 3097
        I saw the picture but it does me little as its just a picture without any info associated with it (make/features) plus how he actually used it which is more important.
        • ronhayes
          TV Engineer
          • Mar 2014
          • 458
          Those suction cups are glass suction cups ! You lay the round black rubber base on the glass then squeeze the two handles together to create a suction to the glass .
          They are used to carry heavy sheets of glass safely .
          I am really surprised they did not crack the screen when used ? they are very strong .
          • ecking767
            • Oct 2009
            • 492
            Only used them to move the panel itself. Was very careful. But I've been wondering if that may have caused it. Here are the ones I used.
            How many did you used? No metal bar for support? you had an extra set of hands? right?
            I plan on building one myself with aluminum pipes and about 6 suction cups.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4326
              • Italy - Milan
              #86
              I wonder why if one is not so an expert in repairs he begins to make experience with a giant 70 inches tv. Your problem now it's much probably a bad led replacement i bet one ball of mine.. i bet also that at the end of led replacement you dont have tested for several minutes the backlight without panel and sheets on top. Just fo curiosity, are you wanting to resell it or keep it for your self? At how much you resell it in the USA? In Italy i've sold a 60 inches about 2010 led no smart tv for 400 euro=322$...
              • sawilson
                • May 2014
                • 63
                • usa
                #87
                I only used two. Had another person help me carefully remove it. Its what was instructed to use by shopjimmy.com. the picture is beautiful except for the shadows. I've worked on other smaller Tv's replacing boards and such. Never had a problem till this one. And yes I know the problems I'm facing were self inflicted. Have never denied that. I did check the backlighting before replacing the panel, all looked well. Brightly lit. What's odd is when watching cartoons, the shadow is barely visible. No shadow, just slightly darker colors as the surrounding.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  I've seen this before. This may not be self inflicted.
                  Like I said before I've seen this a few times on trhese 70 inch panels. Even ones that didn't have the surgery.
                  http://vizhdtv.com/display-problems-...e701i-a3e-tvs/
                    • 12187
                    • U.S.
                    #89
                    n/a
                      • 12187
                      • U.S.
                      #90
                      n/a
                      • ecking767
                        • Oct 2009
                        • 492
                        parts for this e701i-a3 and e601i-a3 model Vizio are plentiful on eBay. to me this mean a lot of failed LCD panels or crack screens. I will lean more toward the failed panel than crack screens. I avoid buying these model Vizio TVs unless it power on and I see a clear picture
                        • sawilson
                          • May 2014
                          • 63
                          • usa
                          #92
                          The picture was clear with no flaws just dim backlighting in spots. I replaced the backlight a now have a bright crisp picture except for the shadows. They weren't there before. Its driving me crazy.
                          • sawilson
                            • May 2014
                            • 63
                            • usa
                            #93
                            What's weird is the shadows don't stay black. They change with the changing colors if the scene. Its just the dark scenes are really dark in those spots. If you press on the panel in those spots, they lighten to match the rest of the picture.
                            • budwich
                              • Jul 2015
                              • 3097
                              there is probably some form of distortion (physical) on the plane of one of the layers. I asked earlier about the use of the suction cups... did you use them to lift the entire panel / tv set or just to remove the layers?
                              since your set is somewhat "disfunctional" in its present state, you might consider "re-do" the disassembly of the layers and subsequent re-assembly... maybe some thing happen during reassembly (air pocket / vacuum pocket) that is causing the "pressure pattern".
                              • sawilson
                                • May 2014
                                • 63
                                • usa
                                #95
                                I only lifted the screen/panel out once everything was disconnected. Barely weighed anything at all.
                                • tvsteve2
                                  • Aug 2014
                                  • 25
                                  • usa
                                  #96
                                  No!!!! they are talking about the strips and tabs on the SIDES not the Bottom!!!
                                  • sawilson
                                    • May 2014
                                    • 63
                                    • usa
                                    #97
                                    These are the ones.
                                    • sawilson
                                      • May 2014
                                      • 63
                                      • usa
                                      #98
                                      Here's the picture now.
                                      • RDC55
                                        • Dec 2017
                                        • 180
                                        Did you purchase those from shopjimmy? Everything has specs, and if not perhaps the one's you used applied too much force to the panel. Or as freak mentioned, this may have been there all along as it occurs in this particular panel per the link he provided.
                                        Note: shopjimmy states their version is rated for 55lbs. Also note this info provided by shopjimmy:
                                        "IMPORTANT: Release the cups' suction from the screen when not in active use."
                                        They don't say why to release them, but if it's important it must cause damage or that statement would not have been added.
                                        • sawilson
                                          • May 2014
                                          • 63
                                          • usa
                                          #100
                                          I did not purchase from shopjimmy but it is the identical ones. They were released the instant the screen was removed and hit the pad.
                                          • Pipolups
                                            Corsair K70 LUX RGB dying LEDs
                                            by Pipolups
                                            Hi there !
                                            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                            10-08-2024, 11:58 AM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
