70in Vizio m70-c3 replaced led's now picture screwed up.
  • RDC55
    • Dec 2017
    • 180
    Re: 70in Vizio m70-c3 replaced led's now picture screwed up.
    Originally posted by sawilson
    I did not purchase from shopjimmy but it is the identical ones. They were released the instant the screen was removed and hit the pad.
    Well, sounds like you did everything correctly and the most likely answer is the dark spots were there all along, but just not obvious or noted with the bad LED's. It's a win some lose some scenario, just hard to accept sometimes when the unexpected occurs and knowing you put great care in the process.
    • sawilson
      • May 2014
      • 63
      • usa
      #102
      I know. The suction cups were rated at 45lbs. So it was actually less than shopjimmy. I'm gonna keep working with it. I may pull the panel again and see what I can accomplish tinkering with the back of the panel. Hell it can't hurt...
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4461
        • Italy - Milan
        #103
        "If you press on the panel in those spots, they lighten to match the rest of the picture."
        wait, maybe i'm wrong with the leds, under the diffusor sheets was there displaced those white plastic tips that supports the layers on top? In ccfl systems them sadly become cooked by heat and brokes at the minimum pressure, maybe is also the case for l.e.d. systems.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4461
          • Italy - Milan
          #104
          Yes, there are, look at the minute 6:49
          https://www.youtube.com/watch?v=VP7iNYFAgIA
          you can glue at the place toothpicks with bicomponent glue and paint them in white.
          • sawilson
            • May 2014
            • 63
            • usa
            #105
            Yeah, there were quite a few that were unusable. Honestly I'd say about 50%. They just snapped. Would that make a big difference? When I push in on the panel, it lightens up and shows the picture like the rest of the screen but only under where my hand is.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4461
              • Italy - Milan
              #106
              Yes it's vital, the diffusers are studied to be at the right distance.
              • mmartell
                • Oct 2013
                • 3189
                Those sheets between the LCD screen and the backlight make a sandwich of sorts so if it's sagging because they're not propped up properly then yes you can have image problems. When you push on the screen you're closing the gap manually.
                These "props" are in backlit led panels but not Edge lit I think.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4461
                  • Italy - Milan
                  #108
                  A faster way to fix the toothpicks is hot glue gun
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    You are correct also I have seen the props in both backlit and edge lit models. The thie diffusers cannot sag at all.
                    When you see the dark areas of the screen does it look like the perimeter between the dark and where the screen actually works has a Brown tinge to the picture?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4461
                      • Italy - Milan
                      #110
                      Why the f**k they must make them in plastic?? It's better metal..
                      • mmartell
                        • Oct 2013
                        • 3189
                        Lol
                        ...you've inspired me to start a new thread...
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • Pipolups
                          Corsair K70 LUX RGB dying LEDs
                          by Pipolups
                          Hi there !
                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                          10-08-2024, 11:58 AM
                        • SS454
                          vizio e650i-a2 backlight flashes then turns off
                          by SS454
                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                          panel: au optronics T650HVN05.4
                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                          08-20-2020, 03:57 PM
                        • mrtek
                          Vizio M65-C1
                          by mrtek
                          Hi.
                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                          07-14-2025, 07:28 PM
                        • howardc64
                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                          by howardc64
                          Failure Symptom
                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                          Where is the short?
                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                          05-27-2025, 02:56 PM
