LG 43UF640V half picture
Re: LG 43UF640V half picture
Input was with aeriel, have found each time tv boots up the bad half of screen has a tint, sometimes green, sometimes purple etc, occasionaly but not often bad half of picture is near perfect, but not perfectComment
will try later to connect from hdmi, may be awkward as i do not have a remote for this tv, dont want to buy one if i can not get the tv working, unless i have toComment
just took this pictures over a period of three or four minutes, each one was taken on powering up the tv, switching off and powering up again each time a diffent tint on the bad side of the screenAttached Filesif you find these attachements useful please consider making a small donation to the site
Not tried any other inputs I just tried ps4 via hdmi but tv is not switching to hdmi so looks like I need a remote to change source, tried several lg remotes I have but none working this tv, (except for power on off), looks like I will have to get a remote for this tv to change its sourceComment
This may work
https://play.google.com/store/apps/d...eapps&hl=en_GBAttached Filesif you find these attachements useful please consider making a small donation to the site
a quick look at the manual appears to indicate you just need an app to control the set.Not tried any other inputs I just tried ps4 via hdmi but tv is not switching to hdmi so looks like I need a remote to change source, tried several lg remotes I have but none working this tv, (except for power on off), looks like I will have to get a remote for this tv to change its sourceComment
will get a remote for it, and take it from there, ie changing source, reset and update etcComment
An hint to get replica remotes at lower prices, search on ebay the remote with the tv model followed by remote, then view some of the results, in some of them there are the remote code, model, then search for that code.. i usually pay them 10 euro with a good replicas...Comment
i have ordered a remote for this tv, so when i get it will try other source, factory reset, update etc.Comment
Did you try that mobile phone app i posted in post 54 its helped me a few times when i didnt have a lg remoteComment
looked at the app but did not try it looked like I had to pair the tv with the app via wifi settings on the tv, can not access any tv settings at the moment
remote I have ordered has been posted first class so should have it tomorrow all being wellComment
I have a VIZIO E70-E3.
Symptoms: Black screen, no picture, but LED backlights are working.
I probed the power board and voltages are as listed on the board.
Main board appears fine, too.
I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
There are two separate ribbon cables feeding the LCD.
If both are connected, the screen is black.
If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by shelby5041hi
i have a samsung lcd tv
it powers on with sound and backlight but no picture
all voltages from PS are good 12v 3.3v and 5v
whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
no 12v at the tcon fuse
i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
the odds of having 2... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... - Loading...
